Recommend 2024-2025 laptop for qubes
My current qubes computers are 5-7 years old and I’d like a new laptop. However almost every HCL I see for newer laptops has issues and even qubes certified laptops have users on here saying stuff stopped working and the manufacturer wasn’t able to help.
For example, I thought novacustom would be promising but then saw this post
Is there a laptop made in 2024-2025 that reliably runs qubes 4.3 rc2 and 4.2.4 ?
Same certified devices may be not suitable for your use case, so you should double check before order.
