[r43-rc1] [upgrade BUG] Problems with qube at second drive (pool)
Before upgrade I have one VM at second drive (storage pool).
Now, I can’t start it:
volume qubes_dom0/vm-XXXX-private missing
What possible to do? How to restore it (change pool)? Sorry, don’t know a lot about storage pools at qubes.
EDIT: qvm-prefs don’t have anything about storage “pool”.
sudo pvs show me that i have 2 pools, but AppVM don’t have this settings.
Don’t see it at qubes-manages settings also
EDIT: I found with sudo lvdisplay the path…
After that sudo mount /dev/qubes/vm-XXXX-private /mnt/ttt
cd /mnt/ttt/ and i see my files…
The question how to restore my VM with this private image(?)… Seems need to change pool for this VM. How to do this
… and obvious bug of RC1…
Any ideas?
Could you describe your setup more in depth? I don’t really understand what you did exactly, something stopped working but what does it mean “one VM at a second storage pool”?
I have 2 SSDs.
One main SSD has Qubes and all AppVMs. The second SSD (thin pool) is for storage for one AppVM with a large amount of data in it. After the upgrade, it’s not possible to start the AppVM from the second SSD. As described above, the vm-XXXX-private file is present on the second SSD, but the AppVM, after the upgrade, searches for it at some other location (I guess).
I found that at /var/lib/qubes/qubes.xml for this qube all volume settings were lost.
Now, it point to main pool (vm-pool) by mistake and parameters “revisions_to_keep” also lost, it was set to 1(0) before update…
should I edit this file manually now (at least path) and reboot or how to force qubes re-read the file and/or apply new settings with correct path?
Is there any other places where I should edit thinpool for this appvm?
Interesting that at sudo lvs -av it have right thinpool for this qube (second pool as expected), but at qubes.xml as said before everything wrong.
@solene @unman any ideas please ? thanks
Also the question: sudo lvs -av show me qubes_dom0 as VG. This also used at qubes.xml as part of the path.
Second drive at my system is qubes (VG) (name: poolssd). Can I rename this qubes (VG) name to qubes_second? Is it possible to do?
Issue fixed. I found that there are backups of qubes.xml and copy&past old lines then rebooted.
1795:        <volume name="private" pool="poolssd" vid="qubes/vm-public-zzz-private" revisions_to_keep="0" rw="True" save_on_stop="True" size="54546923520"/>
1796:        <volume name="volatile" pool="poolssd" vid="qubes/vm-public-zzz-volatile" revisions_to_keep="1" rw="True" size="10737418240"/>
this is by the way content of my file… And this is obvious bug, because I lose this state after update
