with R4.2 there’s often the problem that my AppVM’s or Templates have a starting date of Wed Dec 6 01:00:00 CET 2023 (Fri Nov 10 12:26:00 AM UTC 2023 for whonix)
Some VM’s manage to update their time manually. (Firefox in a dispVM complains about invalid certificate|date/time in the future on forum.qubes-os.org but loads properly after a couple of seconds).
Some don’t (e.g. vault).
That’s also a problem for updating whonix, complaining about “invalid certificate chaining” deb.kicksecure.com while fedora-38 and dom0 update without clocksync problems.
I know about sudo qvm-sync-clock, but adding it to /rw/config/rc.local does not seem to be the proper solution.
Function: pkg.uptodate
Result: False
Comment: E: Failed to fetch tor+https://deb.debian.org/debian/dists/bookworm/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate chain uses not yet valid certificate. Could not handshake: Error in the certificate verification. [IP: 127.0.0.1 8082]
E: Failed to fetch tor+https://deb.debian.org/debian/dists/bookworm-updates/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate chain uses not yet valid certificate. Could not handshake: Error in the certificate verification. [IP: 127.0.0.1 8082]
E: Failed to fetch tor+https://deb.debian.org/debian-security/dists/bookworm-security/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate chain uses not yet valid certificate. Could not handshake: Error in the certificate verification. [IP: 127.0.0.1 8082]
E: Failed to fetch tor+https://deb.debian.org/debian/dists/bookworm-backports/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate chain uses not yet valid certificate. Could not handshake: Error in the certificate verification. [IP: 127.0.0.1 8082]
E: Failed to fetch tor+https://fasttrack.debian.net/debian/dists/bookworm-fasttrack/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate chain uses not yet valid certificate. Could not handshake: Error in the certificate verification. [IP: 127.0.0.1 8082]
E: Failed to fetch tor+https://deb.kicksecure.com/dists/bookworm/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate chain uses not yet valid certificate. Could not handshake: Error in the certificate verification. [IP: 127.0.0.1 8082]
E: Failed to fetch tor+https://deb.whonix.org/dists/bookworm/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate chain uses not yet valid certificate. Could not handshake: Error in the certificate verification. [IP: 127.0.0.1 8082]
E: Failed to fetch https://deb.qubes-os.org/r4.2/vm/dists/bookworm/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate chain uses not yet valid certificate. Could not handshake: Error in the certificate verification. [IP: 127.0.0.1 8082]
E: Some index files failed to download. They have been ignored, or old ones used instead.
Started: 00:25:56.415523
Duration: 27328.863 ms
Changes:
Clock qube: sys-net (i checked “disposable” during installation IIRC)
$ timedatectl
Local time: Thu 2024-01-18 10:41:10 CET
Universal time: Thu 2024-01-18 09:41:10 UTC
RTC time: Thu 2024-01-18 09:41:10
Time zone: Europe/Berlin (CET, +0100)
System clock synchronized: yes
NTP service: active
RTC in local TZ: no
Maybe of further interest: I do have Windows installed parallel. The time there is -1 hour (compared to real time/qubes) which I don’t change, and I disabled time synchronization there. It’s mainly for some gaming.
I somehow broke the bug with sudo qvm-sync-clock to use sudo apt-get in e.g. whonix-gateway-17.
If it reappears I’ll post again.
whonix-gateway-17 template:
timedatectl
Local time: Thu 2024-01-18 11:44:20 UTC
Universal time: Thu 2024-01-18 11:44:20 UTC
RTC time: n/a
Time zone: Etc/UTC (UTC, +0000)
System clock synchronized: no
NTP service: n/a
RTC in local TZ: no
timedatectl
Local time: Wed 2023-12-06 01:28:24 CET
Universal time: Wed 2023-12-06 00:28:24 UTC
RTC time: n/a
NTP service: inactive
RTC in local TZ: no
Whonix updates don’t work again.
Template whonix-gateway-17:
timedatectl
Local time: Fri 2023-11-10 00:29:36 UTC
Universal time: Fri 2023-11-10 00:29:36 UTC
RTC time: n/a
NTP service: n/a
RTC in local TZ: no
Took some time, because sometimes it works, sometimes it doesn’t, then it works again …
qvm-run --pass-io --user root whonix-gateway-17 'journalctl -b -u qubes-sync-time.service'
Nov 10 00:25:52 host systemd[1]: qubes-sync-time.service - Update time from ClockVM was skipped because of an unmet condition check (ConditionPathExists=!/etc/sdwdate.d/qubes-sync-time-disabled-by-sdwdate.marker).
What’s the output of timedatectl in your clock qube (sys-net?)? Does it have correct time?
Check the output of timedatectl in your clock qube and logs in your vault AppVM at the same time.
Get your GPS clock working and sync when neccessary and you will not have these things happening. This is a very old turd since 2016. If you want Qubes history search for Whonix boot clock randomization. The JR’s theory won the Voitila price for excelence in brainwashing. It does wonders for Kerberos and friends (OTP TOTP etc). The only fool is you for expecting the developers not to sell out. This is life!
You might have to sync the BIOS clock too with your local time.
sudo hwclock -l systohc
My BIOS clock was set to UTC. I’ve been messing with a few motherboards lately and don’t know what caused what, but it took me forever to figure out why the BIOS and OS clock were out of sync sometimes and not others. I thought syncing the OS clock would automatically fix the BIOS clock but that wasn’t the case.
$ timedatectl
Local time: Tue 2024-01-30 01:58:16 CET
Universal time: Tue 2024-01-30 00:58:16 UTC
RTC time: Tue 2024-01-30 00:58:16
NTP service: active
RTC in local TZ: no
$ sudo journalctl -b -u qubes-sync-time.service
-- No entries --
vault (incorrect time):
$ timedatectl
Local time: Mon 2024-01-22 01:14:40 CET
Universal time: Mon 2024-01-22 00:14:40 UTC
RTC time: n/a
RTC in local TZ: no
Jan 22 01:00:22 vault systemd[1]: Starting qubes-sync-time.service - Update time from ClockVM...
Jan 22 01:00:18 vault systemd[1]: qubes-sync-time.service: Deactivated successfully.
Jan 22 01:00:18 vault systemd[1]: Finished qubes-sync-time.service - Update time from ClockVM.
$ timedatectl
Local time: Fri 2024-02-02 02:18:09 CET
Universal time: Fri 2024-02-02 01:18:09 UTC
RTC time: n/a
RTC in local TZ: no
$ qrexec-client-vm --filter-escape-chars-stderr '@default' qubes.GetDate+nanoseconds
2024-02-02T14:09:49,439237555+00:00
It’s based on fedora-38-xfce, same as sys-net.
How do I check for policy errors in dom0?
dom0:
$ sudo journalctl -b|grep -i policy
Feb 02 02:10:47 localhost kernel: Policy zone: Normal
Feb 02 02:10:47 localhost kernel: iommu: DMA domain TLB invalidation policy: lazy mode
Feb 02 02:10:47 localhost usbguard-daemon[420]: [1706836247.826] (W) PERMISSIONS CHECK ON POLICY FILE ARE TURNED OFF!
Feb 02 02:11:08 dom0 usbguard-daemon[2761]: [1706836268.885] (W) PERMISSIONS CHECK ON POLICY FILE ARE TURNED OFF!
Feb 02 02:11:09 dom0 polkitd[2838]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
Feb 02 02:11:09 dom0 systemd[1]: Started qubes-qrexec-policy-daemon.service - Qubes remote exec policy daemon.
Feb 02 02:11:09 dom0 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-qrexec-policy-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Feb 02 02:11:09 dom0 qrexec-policy-daemon[2894]: warning: !compat-4.0 directive in file /etc/qubes/policy.d/35-compat.policy line 16 is transitional and will be deprecated
Feb 02 02:11:18 dom0 qrexec-policy-daemon[2894]: qrexec: qubes.InputKeyboard+: sys-usb -> @adminvm: allowed to dom0
Feb 02 02:11:18 dom0 qrexec-policy-daemon[2894]: qrexec: qubes.InputMouse+: sys-usb -> @adminvm: allowed to dom0
Feb 02 02:11:21 dom0 at-spi-bus-launcher[4423]: Policy to allow eavesdropping in /usr/share/defaults/at-spi2/accessibility.conf +15: Eavesdropping is deprecated and ignored
Feb 02 02:11:21 dom0 at-spi-bus-launcher[4423]: Policy to allow eavesdropping in /usr/share/defaults/at-spi2/accessibility.conf +17: Eavesdropping is deprecated and ignored
Feb 02 02:11:24 dom0 qrexec-policy-daemon[2894]: qrexec: qubes.GetDate+nanoseconds: sys-usb -> @default: allowed to dom0
Feb 02 02:11:24 dom0 at-spi-bus-launcher[4559]: Policy to allow eavesdropping in /usr/share/defaults/at-spi2/accessibility.conf +15: Eavesdropping is deprecated and ignored
Feb 02 02:11:24 dom0 at-spi-bus-launcher[4559]: Policy to allow eavesdropping in /usr/share/defaults/at-spi2/accessibility.conf +17: Eavesdropping is deprecated and ignored
Feb 02 02:11:25 dom0 systemd[1]: Starting rtkit-daemon.service - RealtimeKit Scheduling Policy Service...
Feb 02 02:11:25 dom0 systemd[1]: Started rtkit-daemon.service - RealtimeKit Scheduling Policy Service.
Feb 02 02:11:25 dom0 polkitd[2838]: Registered Authentication Agent for unix-session:2 (system bus name :1.40 [/usr/libexec/xfce-polkit], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale de_DE.utf8)
Feb 02 02:11:31 dom0 qrexec-policy-daemon[2894]: qrexec: qubes.WindowIconUpdater+: sys-usb -> @adminvm: allowed to dom0
Feb 02 02:11:37 dom0 qrexec-policy-daemon[2894]: qrexec: qubes.WindowIconUpdater+: vault -> @adminvm: allowed to dom0
Feb 02 02:11:37 dom0 qrexec-policy-daemon[2894]: qrexec: qubes.WindowIconUpdater+: sys-net -> @adminvm: allowed to dom0
Feb 02 02:11:41 dom0 qrexec-policy-daemon[2894]: qrexec: qubes.GetDate+nanoseconds: vault -> @default: allowed to dom0
Feb 02 02:11:43 dom0 qrexec-policy-daemon[2894]: qrexec: qubes.WindowIconUpdater+: sys-whonix -> @adminvm: allowed to dom0
Feb 02 02:11:47 dom0 qrexec-policy-daemon[2894]: qrexec: qubes.WindowIconUpdater+: disp7630 -> @adminvm: allowed to dom0
Feb 02 02:11:52 dom0 qrexec-policy-daemon[2894]: qrexec: qubes.GetDate+nanoseconds: disp7630 -> @default: allowed to dom0
Feb 02 02:13:18 dom0 qrexec-policy-daemon[2894]: qrexec: qubes.GetDate+nanoseconds: vault -> @default: allowed to dom0
Feb 02 02:17:34 dom0 qrexec-policy-daemon[2894]: qrexec: qubes.GetDate+nanoseconds: vault -> @default: allowed to dom0
Feb 02 02:17:37 dom0 qrexec-policy-daemon[2894]: qrexec: qubes.GetDate+nanoseconds: vault -> @default: allowed to dom0
Feb 02 02:18:13 dom0 qrexec-policy-daemon[2894]: qrexec: qubes.GetDate+nanoseconds: vault -> @default: allowed to dom0
I don’t know if this matters:
On boot only sys-usb boots up. Only after I login, other qubes are loaded (sys-net, vault, …)
