Its been awhile since I used it but I recently tried using qvm-screenshot-tool and had some issues. I looked on the forum and did see one post from someone that I think was trying to use it from within an appvm but thats it I think?
So i tried running it in dom0 and nothing so then i made sure the qubes-repo-contrib was installed:
[bob@dom0 Pictures]$ sudo qubes-dom0-update qubes-repo-contrib
Using sys-firewall as UpdateVM for Dom0
Downloading packages. This may take a while...
Unable to detect release version (use '--releasever' to specify release version)
Fedora 37 - x86_64 8.6 MB/s | 70 MB 00:08
Fedora 37 - x86_64 - Updates 18 MB/s | 43 MB 00:02
Qubes OS Contrib Repository for dom0 (updates) 29 kB/s | 27 kB 00:00
Qubes Host Repository (updates) 604 kB/s | 3.3 MB 00:05
Package qubes-repo-contrib-4.2.14-1.fc37.noarch is already installed.
Dependencies resolved.
Nothing to do.
Complete!
No packages downloaded
Qubes OS Repository for Dom0 2.7 MB/s | 3.0 kB 00:00
Nothing to do.
Complete!
then tried to install the app/script:
[bob@dom0 Pictures]$ sudo qubes-dom0-update --clean qvm-screenshot-tool
28 files removed
Fedora 37 - x86_64 22 MB/s | 70 MB 00:03
Fedora 37 - x86_64 - Updates 15 MB/s | 43 MB 00:02
Qubes OS Contrib Repository for dom0 (updates) 27 kB/s | 27 kB 00:00
Qubes Host Repository (updates) 949 kB/s | 3.3 MB 00:03
No match for argument: qvm-screenshot-tool
Error: Unable to find a match: qvm-screenshot-tool
so tried to manually download it, copy it over to dom0, and run it but got a zenity not installed error so installed zenity and am now getting:
[EXIT] "ImageMagic" (display) not found
So now I am not sure. I seem to remember some rather manual ways to take a screenshot but this tool was soo useful!
