Looks like this was indeed the case. I have now edited your post and replaced the issue. I’ll flag this on meta.discourse.org. I guess their parser only cares about what it thinks is a character separator. In this case the ----- in salt output seems to cause the error.
Thank you @unman, I added - match: nodegroup and it worked.
I’m new to salt and qubes, I followed in a bit chaotic manner the documentation and excellent setp-by-setp available (linked from the forum), but it got me to the following warnings (I might have skipped some initial config):
1. not able to run qubesctl without sudo
# qubesctl top.enabled
[WARNING ] Failed to open log file, do you have permission to write to /var/log/salt/minion?
[CRITICAL] Specified ext_pillar interface qvm_prefs is unavailable
Cannot write to process directory. Do you have permission to write to /var/cache/salt/minion/proc/20231220091327803815 ?
DOM0 configuration failed, not continuing
2. always get warning on top_file_merging_strategy
# sudo qubesctl state.highstate # or state.apply
[WARNING ] top_file_merging_strategy is set to 'merge' and multiple top files were found. Merging order is not deterministic, it may be desirable to either set top_file_merging_strategy to 'same' or use the 'env_order' configuration parameter to specify the merging order.
local:
I also can’t figure out when adding match: nodegroup in .top files is beneficial or not. I’ve been searching the QubesOS forums, and seen lots of examples of .top files with and without it…
It’s needed for dom0 because in the Qubes configuration dom0 is the name
of a nodegroup - the other default nodegroup is vm - defined as not dom0.
You can see this in /etc/salt/minion.d/f_defaults.conf
