I’m attempting to modify the Salt configuration in R4.1. My understanding is that /etc/salt/master is the place to do that, but the changes I make don’t seem to have any effect.
Specifically, I’m attempting to silence the following warning:
# dom0
sudo qubesctl state.apply
# [WARNING] top_file merging strategy is set to 'merge' and multiple top files were found. Merging order in not deterministic, it may be desirable to either set top_file_merging_strategy to 'same' or use the 'env_order' configuration parameter to specify the merging order.
I’ve tried without success at removing the warning:
- Creating `/etc/salt/master.d/user.conf as follows:
top_file_merging_strategy: merge
env_order: ['base', 'user', 'dev', 'prod']
- Editing
/etc/salt/masteras follows:
- # top_file_merging_strategy: merge
+ top_file_merging_strategy: merge
- # env_order: ['base', 'dev', 'prod']
+ env_order: ['base', 'user', 'dev', 'prod']
- Editing
/etc/salt/masteras follows (just to try):
+ top_file_merging_strategy: same
Docs I’ve been referring to:
Loosely related to: What is the pillar import path when using Salt user directories?
