Qvm-copy-to-vm NOT broken after upgrade
This is for maybe helping people who may encounter the same situation.
I’ve been using Qubes OS for a few months and it’s really a useful OS for me.
I’m used to make screen captures and then to copy them from dom0/Pictures to a VM where I use Gimp for instance.
I’ve tried to do so and got this as return:
stat filename
sh: zenity: command not found
EOF
I first thought it could be due to an upgrade I’ve done the day before it happened.
The cause was as stupid as that: I forgot to go to the appropriate directory before typing my qvm-copy-to-vm command.
When in the directory, everything worked fine.
The message command not found made me think there was something broken in my system. It’s NOT the case. Everything works fine.
Maybe it can help other beginners like me to put this searchable here.
Feel free to delete if you don’t think so.
Your’s gratefully,
Userssd
You can also use the -o option, e.g. (run in a dom0 terminal):
sleep 2 && xfce4-screenshooter -f -o 'qvm-copy-to-vm gimpVM'
where gimpVM is the name of your VM that has gimp installed; the screenshot will thus be taken 2 seconds after executing the command and automagically sent to that VM (find it in the folder ~/QubesIncoming/dom0).
Even more fancy:
sleep 2 && file=$(xfce4-screenshooter -f -o echo) && qvm-copy-to-vm gimpVM "$file" && qvm-run gimpVM -- gimp "QubesIncoming/dom0/$(basename $file)" &
This will take the screenshot (fullscreen) after 2 seconds, send it to your “gimpVM” (change name to the one you use for that vm) and automagically open the new screenshot in gimp there.
In case you don’t want fullscreen screenshots, use the -w option (for screenshots of only the window in focus) or -r option (for screenshots according to a rectangle you draw) instead of the -f option in the above commands.
Thx a lot.
If you want an interactive way, I’ve been using the following script for years and it’s very handy:
#!/bin/sh
# Take screenshot in Qubes Dom0, auto copy to AppVM, upload to imgurl service
# Qubes R4.1 version
# Dependencies: zenity, deepin-screenshot at dom0 (sudo qubes-dom0-update deepin-screenshot)
# zenity at dom0 and at AppVM
# (c) https://github.com/evadogstar/qvm-screenshot-tool/ 2021
version="0.9"
DOM0_SHOTS_DIR=$HOME/Pictures
APPVM_SHOTS_DIR="\$HOME/QubesIncoming/dom0"
QUBES_DOM0_APPVMS=/var/lib/qubes/appvms/
IMGURL_LOG="\$HOME/imgurl.log"
LAST_ACTION_LOG_CONFIG="$HOME/.config/qvm-screenshot-lastaction.cfg"
DOM0_URLSHISTORY_LOG_FILE="$HOME/.config/qvm-screenshot-logs-urls-history.log"
rightdom0dir=$(xdg-user-dir PICTURES)
if [[ "$rightdom0dir" =~ ^/home/user* ]]; then
DOM0_SHOTS_DIR=$rightdom0dir
fi
TEMPEDITORFILE="$DOM0_SHOTS_DIR/0000-SAVE-EDITED-SHOT-HERE-TO-PROCESS.png"
UPLOADHELPER=$(cat <<'EOFFILE'
#!/bin/bash
# Eva Dog Star imgurl uploader
imgur_anon_id="ea6c0ef2987808e"
# check arguments
if [ $# == 0 ]; then
   echo "[ERROR] No file specified" >&2
   exit 16
fi
# check curl is available
type curl >/dev/null 2>/dev/null || {
   echo "[ERROR] Couln't find curl, which is required at AppVM." >&2
   exit 17
file="$1"
logfile="$2"
   # check file exists
   if [ ! -f "$file" ]; then
      echo "[ERROR] file '$file' doesn't exist at AppVM" >&2
      exit 18
   fi
   response="$(curl --compressed --connect-timeout "7" -m "250" --retry "1" -fsSL --stderr - -H "Authorization: Client-ID ${imgur_anon_id}" -F "image=@$file" https://api.imgur.com/3/image)"
   if egrep -q '"success":\s*true' <<<"${response}"; then
       img_id="$(egrep -o '"id":\s*"[^"]+"' <<<"${response}" | cut -d "\"" -f 4)"
       img_ext="$(egrep -o '"link":\s*"[^"]+"' <<<"${response}" | cut -d "\"" -f 4 | rev | cut -d "." -f 1 | rev)" # "link" itself has ugly '\/' escaping and no https!
       del_id="$(egrep -o '"deletehash":\s*"[^"]+"' <<<"${response}" | cut -d "\"" -f 4)"
       imgurl="https://i.imgur.com/${img_id}.${img_ext}"
       imgdeleteurl="https://imgur.com/delete/${del_id}"
       curdate=$(date +%d-%b-%Y\ %H:%M)
      echo -e "$curdate screenshot:\n\n$imgurl\n\nRemove: $imgdeleteurl\n" > $logfile
      echo "[success] imgurl: $imgurl" >&2
      echo "[success] remove: $imgdeleteurl" >&2
   else # upload failed
       err_msg="$(egrep -o '"error":\s*"[^"]+"' <<<"${response}" | cut -d "\"" -f 4)"
       test -z "${err_msg}" && err_msg="${response}"
       echo "[ERROR] $err_msg"
       echo "[RESPONSE] $response"
     echo -e "Error: \n\n$err_msg \n\nImgurl Server response: \n\n$response\n\n\n \nQubes Screenshot Tool - EvaDogStar 2020" > $logfile
       #echo ${err_msg}
   fi
(which xclip &>/dev/null && echo -n "$imgurl" | xclip -selection clipboard ) || echo "[NOTE] no xclip at AppVM"
EOFFILE
print_help()
    echo "Usage: $(basename "$0") OPTIONS [[--imgurl|--vm-nautilus] --vm APPVMNAME]"
    echo "  -h | --help"
    echo "  FIRST DIALOG OPTIONS:"
    echo "  -r | --region-only"
    echo "  --fullscreen"
    echo "  --lastdialog"
    echo "  SECOND DIALOG OPTIONS:"
    echo "  --upload-to-appvm-only"
    echo "  --imgurl (request -vm NAME)"
    echo "  --vm-nautilus (request -vm NAME)"
    echo "  --keep-screenshot-at-dom0"
    echo "  -vm | --virtualmachine NAME"
    exit 1
write_last_action_config()
touch "$LAST_ACTION_LOG_CONFIG"
cat <<EOF > $LAST_ACTION_LOG_CONFIG
# last app vm used to upload image
appvm=$appvm
logfile=$logfile
EOF
write_dom0_urlhistory_log()
[ ! -e $DOM0_URLSHISTORY_LOG_FILE ] && touch "$DOM0_URLSHISTORY_LOG_FILE"
RESULTTEXT+="
ex -s -c "1i|$appvm - $RESULTTEXT" -c x $DOM0_URLSHISTORY_LOG_FILE
read_last_action_config()
[ -e $LAST_ACTION_LOG_CONFIG ] && source $LAST_ACTION_LOG_CONFIG
open_imgulr_upload_dialog_at_destination_appvm
if [ "$appvm" == "" ]; then
      printf "Last action not available \n"
      zenity --info --modal --text "Last action not available. Please, upload some image with this AppVM first." &>/dev/null
fi
exit 1
open_dom0_log()
  [ ! -e $DOM0_URLSHISTORY_LOG_FILE ] && zenity --info --text "Currently no log file available at dom0." && exit 1
  zenity --text-info --width=500 --height=480 --modal --filename=$DOM0_URLSHISTORY_LOG_FILE --text Ready
  exit 1
open_imgulr_upload_dialog_at_destination_appvm()
   qvm-run $appvm "zenity --text-info --width=500 --height=180 --modal --filename=$logfile --text Ready"
checkdeepinscreenshot()
   (which deepin-screenshot &>/dev/null ) || {
      warn="[EXIT] no \"deepin-screenshot\" tool at dom0 installed use: \n\nsudo qubes-dom0-update deepin-screenshot \n\ncommand to add it first"
      printf "$warn\n"
      zenity --info --modal --text "$warn" &>/dev/null
      exit 1
start_ksnapshoot()
  PID="$(pgrep ksnapshot)"
  if [ "$PID" == "" ]; then
   ksnapshot &
   sleep 1
  fi
  # setGrabMode notes: 0=full-screen, 1=window, 2=region
  #kstart ksnapshot
  #kdialog --radiolist "Now you can user Snapshot tool to make screenshots. When and only when you will be ready with screenshot (check preview area) click OKEY. Confirm only if you are ready!" READY READY READY --default continue --title "$program" --nograb --noxim
  zenity --question --text "Move this window away and make screenshot. When you are ready to upload image click OK"
  # while [ "$PID" == "" ]; do PID="$(pgrep -n ksnapshot)"; done
  # ksnap pid changed after using region selection tool
  program="org.kde.ksnapshot-${PID}"
  qdbus $program /KSnapshot save $2
  printf "[+] ksnapshot saved at: $2\n"
  qdbus $program /KSnapshot exit
# check dependencies
 (which zenity &>/dev/null ) || {
    warn="[FATAL] no \"zenity\" tool at dom0 installeted use: \n\nsudo qubes-dom0-update zenity command to add it first"
    printf "$warn\n"
    exit 1
 (which display &>/dev/null ) || {
    warn="[EXIT] no \"ImageMagic\" (display) package at dom0 installeted use: \n\nsudo qubes-dom0-update ImageMagic \n\ncommand to add it first"
    printf "$warn\n"
    exit 1
 (which import &>/dev/null ) || {
    warn="[EXIT] no \"ImageMagic\" (import) package at dom0 installeted use: \n\nsudo qubes-dom0-update ImageMagic \n\ncommand to add it first"
    printf "$warn\n"
    exit 1
program="`basename $0`"
shotslist=""
mkdir -p $DOM0_SHOTS_DIR ||exit 1
while true; do
   d=`date +"%Y-%m-%d-%H%M%S"`
# check ksnapshoot exists
  ksnapshottxt="FALSE Ksnapshot"
  (which ksnapshot &>/dev/null ) || {
     ksnapshottxt=""
# PROCESS COMMAND LINE ARGS
ans=""
anssecond=""
appvm=""
## GETTING OPTIONS START
declare -a TEMPARR
 while [[ $# -gt 0 ]]; do
    key="$1"
    case "$key" in
        -h|--help)
        print_help
        exit 1
        -r|--region-only)
          ans="Region or Window"
        -f|--fullscreen)
          ans="Fullscreen"
        -l|--lastdialog)
         ans="Open last dialog"
        --homelog)
         ans="Open dom0 log"
        --eraselog)
         ans="Erase dom0 log"
        -vm|--vm|--virtualmachine)
        shift
        appvm="$1"
        --upload-to-appvm-only)
         TEMPARR=("${TEMPARR[@]}" "Upload to AppVM only")  # Add an element
        --editscreenshot)
         TEMPARR=("${TEMPARR[@]}" "Edit Screenshot")  # Add an element
        --imgurl)
         TEMPARR=("${TEMPARR[@]}" "Upload to Imgurl")  # Add an element
        --vm-nautilus)
         TEMPARR=("${TEMPARR[@]}" "Start Nautilus at AppVM")  # Add an element
        --keep-screenshot-at-dom0)
         TEMPARR=("${TEMPARR[@]}" "Keep screenshot at dom0")  # Add an element
        ## This is an arg=value type option. Will catch -o=value or --output-file=value
        ##-o=*|--output-file=*)
        ## No need to shift here since the value is part of the same string
        ##OUTPUTFILE="${key#*=}"
        # Do whatever you want with extra options
        echo "Unknown option '$key'"
        exit 1
    esac
    # Shift after checking all the cases to get the next option
    shift
done
# implode an array with params
anssecond="$(printf "%s)|(" "${TEMPARR[@]}")"
anssecond="${anssecond%)|(}"
unset TEMPARR
## GETTING OPTIONS END
# if [ "$1" = "--region-only" ] ; then
#   ans="Region or Window"
#   shift
# elif [ "$1" = "--fullscreen" ]; then
#   ans="Fullscreen"
#   shift
#fi
if [ "$ans" = "" ] ; then
   ans=$(zenity --list --height=240 --modal --text "Choose capture mode of capturing \n Use:" --radiolist --column "Pick" --column "Option" \
   $ksnapshottxt \
   TRUE "Region or Window" \
   FALSE "Fullscreen" \
   FALSE "Open last dialog" \
   FALSE "Open dom0 log" \
   FALSE "Erase dom0 log" \
fi
#   echo $ans
  if [ X"$ans" == X"Ksnapshot" ]; then
   printf "[+] starting ksnapshot..."
   start_ksnapshoot 4 $DOM0_SHOTS_DIR/$shotname || break
  elif [ X"$ans" == X"Region or Window" ]; then
     checkdeepinscreenshot || break
     echo "[+] capturing window, click on it to select"
     deepin-screenshot --save-path $DOM0_SHOTS_DIR/$shotname || break
  elif [ X"$ans" == X"Fullscreen" ]; then
     echo "[+] capturing fullscreen desktop"
     #deepin-screenshot --fullscreen --save-path $DOM0_SHOTS_DIR/$shotname || break
     import -window root $DOM0_SHOTS_DIR/$shotname || break
  elif [ X"$ans" == X"Open last dialog" ]; then
     echo "[+] opening last dialog at AppVM with uploaded urls if exists"
     read_last_action_config || break
     exit 1
  elif [ X"$ans" == X"Open dom0 log" ]; then
     echo "[+] opening log at dom0 with all upload and download urls"
     open_dom0_log || break
     exit 1
  elif [ X"$ans" == X"Erase dom0 log" ]; then
     echo "[+] erasing log at dom0 with all upload and download urls"
     rm $DOM0_URLSHISTORY_LOG_FILE || break
     exit 1
  else
     echo "You must select some mode to continue" && exit 1
  fi
  if [ -f "$DOM0_SHOTS_DIR/$shotname" ]
  then
      echo "[+] Success at dom0. Screenshot saved at $DOM0_SHOTS_DIR/$shotname" || break
  else
   echo "[ERROR] Something has gone wrong and screenshot has not been saved at dom0."
   $(zenity --info --modal --text "Something has gone wrong and screenshot has NOT been saved at dom0")
   exit 12
  fi
   shotslist="$shotname"
   #shotslist="${shotslist}${shotname}:"
   break
done
if [ "$anssecond" = "" ] ; then
 anssecond=$(zenity --list --modal --width=200 --height=290 --text "Screenshot saved at dom0 \nWhat do you want to do next?\nSelect or multiselect some options:" --checklist --column "Pick" --column "Options" \
   FALSE Exit \
   FALSE "Upload to AppVM only" \
   FALSE "Edit Screenshot" \
   FALSE "Upload to Imgurl" \
   FALSE "Start Nautilus at AppVM" \
   FALSE "Keep screenshot at dom0"
fi
   #echo "xxx $anssecond xxx"
[[ X"$anssecond" == X"" ]] && exit 1
mode_exit=0
mode_onlyupload=0
mode_edit=0
mode_nautilus=0
mode_imgurl=0
mode_not_delete_screen_at_dom=0
IFSDEFAULT=$IFS
IFS='|'; for val in $anssecond;
do
#echo "variable: $val and $1"
case $val in
  'Exit') mode_exit=1;exit 1 ;;
  'Upload to AppVM only') mode_onlyupload=1;  ;;
  'Edit Screenshot') mode_edit=1;  ;;
  'Upload to Imgurl') mode_imgurl=1;  ;;
  'Start Nautilus at AppVM') mode_nautilus=1;  ;;
  'Keep screenshot at dom0') mode_not_delete_screen_at_dom=1;  ;;
 # -r) mode_region=1;  ;;
  *) echo "Never Good Bye!"; exit 1 ;;
esac done
# editing screenshot with IM
if [ $mode_edit -eq 1 ]; then
  echo "[-] editing screenshot started. Click on the image to get the edit menu. Use the tool. When you will be ready save the screenshot to predefined place. Then Exit from IM to continue"
  echo "" > $TEMPEDITORFILE
  display "$DOM0_SHOTS_DIR/$shotname"
  # check if user save his image changes to special SAVE slot that we monitor
 size=$(stat --printf="%s" $TEMPEDITORFILE )
 # if [ $size -ge 20 ]; then
 #   # user stored new image
 # fi
     echo "[+] changed screenshot found. Continue with it"
     mv $TEMPEDITORFILE $DOM0_SHOTS_DIR/$shotname
   else
    #clianup tempfile
    rm $TEMPEDITORFILE
  fi
  sleep 1
  echo "[-] thanks for editing. Now we continue."
fi
  echo "[+] Good Bye!"
fi
IFS=$IFSDEFAULT
choiceappvm=`ls $QUBES_DOM0_APPVMS |sed 's/\([^ ]*\)/FALSE \1 /g'`
#appvm=`kdialog --radiolist "Select destination AppVM" $choice --title "$program"`
if [ "$appvm" = "" ] ; then
appvm=$(zenity --list --modal  --width=200 --height=390  --text "Select destination AppVM (unix based):" --radiolist --column "Pick" --column "AppVM" $choiceappvm )
fi
#echo $appvm
if [ X"$appvm" != X"" ]; then
   echo "[-] start AppVM: $appvm"
   destdir=$(qvm-run -a --pass-io $appvm $APPVM_SHOTS_DIR)
   if [[ "$destdir" =~ ^/home/user* ]]; then
    APPVM_SHOTS_DIR=$destdir
   fi
   qvm-run $appvm "mkdir -p $APPVM_SHOTS_DIR"
   if [ $mode_nautilus -eq 1 ]; then
      echo "[-] running nautilus in AppVM"
      qvm-run $appvm "nautilus $APPVM_SHOTS_DIR"
      sleep 1
   fi
   shot=$shotslist
   echo "[-] copying screenshot to $APPVM_SHOTS_DIR/$shot"
   cat $DOM0_SHOTS_DIR/$shot \
      |qvm-run --pass-io $appvm "cat > $APPVM_SHOTS_DIR/$shot"
   [[ $mode_not_delete_screen_at_dom -eq 0 ]] && rm -f $DOM0_SHOTS_DIR/$shot && echo "[+] Screen at dom0 deleted $DOM0_SHOTS_DIR/$shot"
   [[ $mode_onlyupload -eq 1 ]] && exit 1
   [[ $mode_imgurl -eq 0 ]] && exit 1
   echo "[-] copying imgurl uploader to AppVM $appvm"
#      echo $UPLOADHELPER \
#          | qvm-run --pass-io $appvm "echo $UPLOADHELPER > $APPVM_SHOTS_DIR/autouplodertemp.sh"
   uploadername='evauploadermgur.sh'
   logfile="$APPVM_SHOTS_DIR/$IMGURL_LOG"
   echo "$UPLOADHELPER" | qvm-run --pass-io $appvm "cat > $APPVM_SHOTS_DIR/$uploadername"
   qvm-run --pass-io $appvm "chmod +x $APPVM_SHOTS_DIR/$uploadername"
   RESULT="$(qvm-run --pass-io $appvm "$APPVM_SHOTS_DIR/$uploadername $APPVM_SHOTS_DIR/$shot $logfile")"
   RESULTTEXT="$(qvm-run --pass-io $appvm "cat $logfile")"
   qvm-run $appvm "rm $APPVM_SHOTS_DIR/$uploadername"
   #qvm-run $appvm "gedit $logfile"
   echo $RESULTTEXT
   # write AppVM name and log file at AppVM to the dom0 config to open it again
   #done
else
   echo "[-] no AppVM name provided"
fi
echo "[*] Qubes Screenshot Tool said Good Bye"
I tweaked it a little bit to send all screenshots to $HOME/QubesIncoming/dom0 in the target.
I use it with the -r option to capture a specific part of the screen.
Create a keybind for this script using the Print key, and you’ll be able to take quick screenshots and send them wherever you want.
