Qvm-copy-to-vm no longer works in dom0 on Qubes 4.2.4
Hi all,
I’m running Qubes OS 4.2.4. I used to copy screenshots from dom0 to a VM using:
qvm-copy-to-vm <target-vm> <file>
This always worked before, but now it returns:
qvm-copy-to-vm: command not found
Nothing else seems broken. I recently updated all my templates, but since this command runs in dom0, I assume that’s unrelated.
Has anyone seen this before? I have searched the forum and found this post Qvm-copy-to-vm NOT broken after upgrade - #4 by DVM but this doesn’t seem to be the similar issue to my problem.
Thanks.
I just looked at the latest RPM spec files and it shows that the file should be present at /usr/bin/qvm-copy-to-vm
So, are you sure the file exists? Are you able to find the command by yourself, i.e. using which? Maybe try /usr/bin/qvm-copy-to-vm instead?
Yes, I ran:
which qvm-copy-to-vm
and it returned
So the file does exist.
so
if that works then check if you have /usr/bin in $PATH
echo $PATH
don’t show it here as it contains yours username for Dom0, just tell if it’s there.
I’m fairly sure, that which will search $PATH and print what matches the argument to which … so since which returned
then /usr/bin should be in $PATH. :-/
:slight_smile:
You are too modest, since you are completely correct.
On my system (4.2.4 – updated this morning) everything is there, as well:
[user@dom0 ~]$ which qvm-copy-to-vm
and
[user@dom0 ~]$ echo $PATH
/home/user/.local/bin:/home/user/bin:/usr/local/bin:/usr/local/sbin:/usr/bin:/usr/sbin
so, @sinartus , did you run
in Dom0 terminal?
Your problem is with some script?
I have checked all of the suggestions above and everything is all accounted for and present. I have /usr/bin in $PATH
I am executing this in Dom0 terminal as such:
qvm-copy-to-personal /home/user/Pictures/Screenshot_xxx.png
and the result I am getting is bash: qvm-copy-to-personal: command not found.
I am sure I am doing something wrong here. I might just be off a letter or something.
You used qvm-copy-to-vm personal /home/user/Pictures/Screenshot_xxx.png before, right?
And what is the output of the following?
[user@dom0]$ ls -l /home/user/Pictures/Screenshot_xxx.png
As @parulin hinted:
Mind the syntax!
Ahh…I knew the fault must be mine.
I was missing the “-vm”
Thank you @OvalZero and @parulin for pointing that out!
You could always alias ‘qvm-copy-to-vm personal’ to ‘qvm-copy-to-personal’ so you can make this mistake with impunity in the future. In fact, if you copy to that particular vm often, you may find it a timesaver.
Wait… This issue isn’t solved, right? Because the first post was correct about the syntax.
@parulin In my first post, I copied the syntax from the Qubes OS documentation, but I assumed that "vm" should be replaced with the VM’s actual name, similar to what @SteveC showed, changing
to
qvm-copy-to-personal.
In the past, I had always included the -vm in the command but in haste, I made that mistake.
@SteveC To create the alias, should I add the following line to my ~/.bashrc file in dom0?
alias qvm-copy-to-personal='qvm-copy-to-vm personal'
:sweat_smile:
Next time copy the exact output please…
Will do! Thank you @parulin
I can’t be positive you got the syntax absolutely right, but yes that’s what I would do if I wanted that alias. (I have similar aliases for copying things FROM a very specific qube (that’s almost as isolated as Vault) that holds config files for my installation.)
