What performance should I expect if I decide to install Qubes OS on corebooted Lenovo ThinkPad X220 with the specs: Intel Core i5-2540M, 16 GB RAM, SATA SSD and on the second PC with 32 GB RAM, Intel Core i7-8750H CPU, NVME disk?
Can I run every task like running Docker containers, IDEs on the Qubes like I did on the Arch Linux, Gentoo?
Can Qubes OS be customized to run on ZFS or btrfs for example and to use some favorite lightweight window manager instead of Xfce?
Can I do GPU passthrough on Qubes and Qubes OS be used for running LLMs, compiling larger apps, playing games, commercial applications without significantly degrading performance if I run this stuff on top PC with spec like AMD Ryzen 9 9950X and 128 GB RAM?
The answer is: Yes, you can, but I advise you not to…
… unless you are a systems and security and Qubes OS guru and you have a lot of free time.
If you’ve got several machines, that might be a good starting point to install Qubes OS on the best-suited one (see HCL & documentation & contributions here) and start using it for use cases aligned with what Qubes OS is intended for: protecting our security, anonymity (when necessary and feasible), and data.
