Question about sys whonix and vpnQube to do different tasks for each Qubes
I have a question about Phonix workstations and gateways. I want to work on a cube that is completely unrelated. For example, I want to do completely different work on cube A and cube B so that outsiders don’t know the connection between cube A and cube B at all. Therefore, I am thinking of using different templates for each cube.
However, Whonix has two elements: a workstation and a gateway. I’m thinking of making workstations possible by creating multiple workstation templates. But in this case, you don’t know how to handle the gateway. I know the gateway is connected to syswhonix.
However, I have not connected the other cubes to the gateway. Is it okay to continue like this? In this case, how can the gateway be more anonymous? By the way, both Cube A and Cube B are assumed to use the same syswhonix.
I am also thinking of using Fedora as a.NET cube to make a VPN connection. Do I still need to change the Fedora Net cube, VPN, VPN account, etc. that I want to connect to each cube?
You should ask this on Whonix forum as per:
http://forums.dds6qkxpwdeubwucdiaord2xgbbeyds25rbsgr73tbfpqpt4a6vjwsyd.onion/
I understand. Thank you
