Generally, we try to use minimal external dependencies (Python standard library is quite extensive), and even if some, we require it to be available as distribution packages. We do not fetch random stuff from pypi or similar.
Mostly yes. There are very few exceptions where we package them ourselves (for example GitHub - QubesOS/qubes-python-qasync - needed by Qubes Manager), where we check the library manually.
Python standard library (part of the Python project) has very high standards.
This is not what reproducible are used for. Here we are talking about source code commit, not building it. If you look at the repository I linked before, you can find there is actually source code hash file committed to ensure its integrity, and it’s covered by signed tag, like all of the code in qubes repos.
Signature proves who made the change and committed it. Whether you trust that person/organization is up to you. If you choose to not trust particular developer(s), you are free to review/verify/scan/whatever particular code yourself, or simply not use it. More on this here: Verifying signatures | Qubes OS
Independent reviewer can provide their own set of tags, but that needs to happen in their forked repository (or using some other method) - we do not allow just anybody pushing tags to the official repositories.
The hash covers the whole source archive, which means any change to the source would result in a different hash. Read more at Cryptographic hash function - Wikipedia
We do use fuzzing where it makes sense (especially where some API function is exposed to untrusted data), mostly using oss-fuzz. It doesn’t make sense for the library I used as a example, as it’s a GUI integration (Qt) that does not touch untrusted data and doesn’t really expose external API (and also GUI fuzzing is not really an effective technique).
It interacts with the user (via various APIs, but not crossing trust boundary), not with other (untrusted) VMs.
Anyway, I feel like this discussion is getting more and more abstract and offtopic. If you want to ask some specific question about any of the processes, please make it specific. I believe I answered your original question already. If you want to propose some improvement to the process, you are also free to do so, but remember Qubes OS is a free and open source project that is built by a community.
It sounds like you’re asking for mathematical proof that a human performed some cognitive labor. That doesn’t really make sense, at least not without a lot of further specification about what you mean.
Even if you had mathematical proof that a human performed a manual scan of the source code, it wouldn’t necessarily be of any value to you. I, knowing nothing about the source code, can perform a manual scan and report: “Source code exists.” Suppose I could also somehow give you mathematical proof that this occurred. This is not useful to you, because the existence of the source code was not in question. What you need is assurance not that the some manual scan was performed but, presumably, that certain desirable security properties are present or certain undesirable flaws are absent.
Even if you had what you’re asking for, you’d still have to trust the developers, because they’re the ones who would be performing the manual scans that you want to mathematically prove occurred.
It sounds like you’re looking for formal verification. If that’s what you’re expecting, then I think your expectations are off. It’s sort of like going to the car dealership down the street and asking which models can fly. Is it possible to build a flying car? Sure, but it’s not common or practical for the cars any normal person can actually purchase and drive today. Perhaps someday it will be.
