I’m not sure that using a probabilistic model (which will fail, for sure, at some point) is relevant to proving certain properties of code ![]()
Well, we have two methods here, one of which is mathematically sound, and one
that is at least covering the majority of vulnerabilities that would fit inside of a normal
bell curve distribution.
The probabilistic (fuzzing) model, as you described will not catch every vulnerability
under the bell curve but it is still important in testing functions and in actually
discovering those statistical edge cases where the function’s behaviour and output
is unexpected.
No I was talking about LLMs, that are probabilistics models, and the idea of translating code with them to prove something. That sounds weird to me, but I’ll be happy to be wrong ![]()
You are saying that the LLM will not accurately convert from one language to another
with 100% accuracy? The converted statements would have to be verified some other
way?
Yes that’s how LLMs work ![]()
What about fuzzing a function before the conversion and after the conversion and
comparing the output of both to ensure they are identical?
What if each element of output from both fuzzing samples (before and after) was
passed as a parameter into a string comparison function and compared for
perfect accuracy.
What I’m trying to say here is that you have a function and then convert it using the
LLM to “coq”(formal langauge), then you fuzz the before and after conversion and
compare the output to ensure they are identical. So you have python function output in
one parameter of a stringcompare and then you have the coq function output in the
other parameter. The output of both functions must be identical.
Is the OSS-fuzz tool compiled with the python libraries? Is it compiled into dom0?
Do users have access to these fuzzing functions via dom0?
