Qubes won't boot after audio qube creation
I was trying to get qubes to work with bluetooth headphones: using the following guides
I was successfully able to set up the audio qube but audio stopped working, so I passed the 00:00.5 AMD Audio Coprocessor to the sys-audio qube and then the system crashed, and it won’t boot now, it shows the qubes logo and the progress bar, once the progress bar is complete it shows a black screen.
I don’t care about bluetooth working I just want to get qubes to the state it was before without having to reinstall/reconfigure the system.
Hello, can you try disabling autostart for VMs temporarily and see if it Qubes OS boot ,since sys-audio wouldn’t auto start this way and steal the passed device , you can remove assigned PCI device once you get it to start:slightly_smiling_face:
See the attached guide :
