Trying to update dom0 I get a long list of “No space left on device”, but the hard disk icon on the panel tells that total disk usage is only 23.4%
lvm 23.4% 195.4GiB/835.8 GIB varlibqubes.
with more detail the error message is:
tar: var: Cannot mkdir: No space left on device
df -h tells that Use % is lower than 1% or 0% for all items, except
/dev/sda1 that is 25%. So even on this side everything seems ok
only 23.4%
And what about the disk space left on the updateVM ? (probably sys-firewall)
Many thanks Ludovic
did not think this may be a problem. Aren’t files downloaded to dom0 for dom0 update?
Anyway, on sys-firewall df -h gives
Filesystem /dev/xvda3 Size 9.6G Used 5.2G Avail 4.0G Use% 57% Mounted on /
Filesystem none Size 9.6G Used 5.2G Avail 4.0G Use% 57% Mounted on /usr/lib/modules
for all other items use is less than 1%
