When booting to install, select “Install Qubes OS"
Finish installation and boot into OS.
Remarks
The important things work:
Fedora 32/33
Debian 10
Whonix
Ethernet (on the laptop and on the docking station)
Wifi
Microphone
One thing : sys-usb don’t work, i’m currently trying to see why, maybe i have to check something in the BIOS because the VM will boot if there is no PCI (USB) device in “device” option.
[edit] : USB work only if you select “DISABLE” in BIOS option “USB 3.0” (auto and enable won’t work)
One thing : sys-usb don't work, i'm currently trying to see why, maybe i
PCI (USB) device in "device" option.
