Installation instructions1. Use ISO Qubes-4.0.4-x86_64.iso
- When booting to install, select “Install Qubes OS"
- Finish installation and boot into OS.
Remarks
The important things work:
- Fedora 32/33
- Debian 10
- Whonix
- Ethernet (on the laptop and on the docking station)
- Wifi
- Microphone
- Bluetooth
One thing : USB work only if you select “DISABLE” in BIOS option “USB 3.0” (“auto” and “enable” won’t work)
Anti-Evil-Maid doesn’t work even if I follow the github instructions … (failed to seal and unseal secrets)
