Is the documentation on this [page] to enable the rpmfusion repos still relevant?
Doing "sudo dnf config-manager --set-enabled rpmfusion-free", gives me an error, "Error: No matching repo to modify: rpmfusion-free".
This appears to be specific to the Fedora-xx-minimal template. I don't know why, can someone give me a pointer?
relevant?Doing “sudo dnf config-manager --set-enabled rpmfusion-free”, gives me
an error, “Error: No matching repo to modify: rpmfusion-free”.This appears to be specific to the Fedora-xx-minimal template. I don’t
Fedora minimal will not include the rpmfusion-.repo file/repo because it’s supposed to be “minimal” while the rpmfusion are “extras”. You can of course copy the rpmfusion-.repo files over to your minimal template if you like. You can find these files in this path in the normal fedora template:
/etc/yum.repos.d/rpmfusion-free.repo
They are generally disabled so that including them by mistake is not a security risk. Anything in the rpmfusion repository generally carries more risk because it is less vetted than the normal fedora repository.
an error, "Error: No matching repo to modify: rpmfusion-free".This appears to be specific to the Fedora-xx-minimal template. I don't
know why, can someone give me a pointer?Fedora minimal will not include the rpmfusion-*.repo file/repo because it's
supposed to be "minimal" while the rpmfusion are "extras". You can of
course copy the rpmfusion-*.repo files over to your minimal template if you
like. You can find these files in this path in the normal fedora template:/etc/yum.repos.d/rpmfusion-free.repo
Yes thank you now i remember.
Here is a snip of my "sudo dnf install ...." with the last output,
(351/352): libreoffice-core-7.3.4.2-4.fc36.x86_64.rpm 440 kB/s | 111 MB 04:17
(352/352): thunderbird-91.12.0-1.fc36.x86_64.rpm 249 kB/s | 97 MB 06:40
