I switches my setup and I am using static disposable VMs for sys-usb and sys-firewall (Based on an own template which has been cloned from a fedora-33-minimal template + the bare minimal packages).
I also would like to make my sys-net a disposable VM but without the hazzle to enter my wifi credentials each time when I am connecting to the wifi network.
Is there a way to initiate a wifi connection via dom0 and passing the credentials for the wifi network?
qvm-run --pass-io --auto sys-net âcommand1 && commands && [âŚ] command nâ with passing credentials via piping from Dom0 ?
Basically I am looking how I can initiate a new wifi connection from the CLI.
If I know this, I can combine a script myself which will pass the relevant information from Dom0 to the sys-net.
And one more question:
Wouldnât it be much better if we always use disposable.sys-Vms when this is possible?
network.
qvm-run --pass-io --auto sys-net 'command1 && commands && [...] command n'
CLI.
Possibly an nmcli command run in the disposable template could do that?
Your sys-net is a named disposable VM, which is based on an AppVM that has the "template_for_dispvm" property set true. This AppVM is in turn based on your fedora-33-minimal clone.
The reason you have an AppVM as template for disposable VMs is the ability to do customization. So here is what I do:
AppVM:
1) set virt_mode to 'hvm'
2) attach wifi via qvm-pci
3) launch
4) connect to wifi (this will safe the password)
5) shutdown
6) detach wifi
7) set virt_mode to 'pvh'
sys-net:
1) attach the wifi again
2) start
... from now on your sys-net will automatically connect to your Wifi. I do this for my home wifi and my hotspot.
i dont like many icon on my panel so i did hide nmcli-applet.
â You received this message because you are subscribed to the Google Groups âqubes-usersâ group. To unsubscribe from this group and stop receiving emails from it, send an email to . To view this discussion on the web visit .
