Any help welcome, so I use Qubes 4.1 on my x220
dom0: 1560 MB ram
sys-net: 384 MB ram
sys-firewall-mirage: 60 MB ram
sys-vpn-wireguard: 384 MB ram
sys-whonix: 384 MB ram (never used)
sys-usb: 284 MB ram
any minimal web browsing surf vm (firefox, qutebrowser) ~ 400MB
any minimal programming vm (neovim) ~ 400MB
so I have < 8GB memory used on my laptop,
56 cpu and 6 hours of battery
Are you using Fedora or Debian for the templates? Minimal?
fedora-34-minimal, also it possible to minimize whonix
I am a fan of minimal templates 1 in Qubes OS, as it allows one-app-per-qube compartmentalization without extra overhead (RAM, disk usage, package count). By “minimal” I consider all non-app-specific Whonix security/privacy/anti-fingerprinting...
and maybe any grub tweaks on minimal templates for faster startup
dom0 use only 700mb ram
best combination :
install qubes 4.1 and change btrfs as default
install fedora-35-minimal vm as template for sys-net,sys-firewall and sys-usb
packages :
qubes-core-agent-qrexec qubes-core-agent-passwordless-root qubes-core-agent-systemd
qubes-core-agent-networking polkit qubes-core-agent-network-manager less pciutils xclip terminus-fonts dejavu-sans-fonts dejavu-sans-mono-fonts
notification-daemon qubes-core-agent-dom0-updates
iwlXXX-firmware qubes-input-proxy-sender iproute iputils
NetworkManager-wwan NetworkManager-wifi network-manager-applet
Set new template as template for sys-vms
qvm-shutdown --all --wait --timeout 120
qvm-prefs --set sys-usb template $systemplate
qvm-prefs --set sys-net template $systemplate
qvm-prefs --set sys-firewall template $systemplate
Change in /etc/default/grub dom0 maxmem to 1576 ( maybe to 700, will try)
remove everything else, install Debian 11 minimal, Gentoo minimal and arch minimal templates
optional: build whonix-minimal
enjoy your lastest Qubes on old hardware
fuel_can:
iwlXXX-firmware
Does XXX stand for anything?
Edit: This package appears to be related to wifi capability and since I use a wired connection, this doesn’t really apply for me at current time. Are there any othere packages which are wifi-specific that I could leave out?
I’m curious about how you can run firefox with just 400MB. Won’t it be extremely laggy?
What do you mean by you “have 56 cpu”?
Also, can you or someone else write up a [GUIDE] post about this setup here in this forum?
