I need full instruction or tutorial to solve this problem.
Hi @gg1331, welcome to the Community! Could you give us a bit more details? When do you get this error and where?
Hi… I am using qubes os 4.0.4 on external hard HDD 500 .
yesterday after writing the first password I had found this problem
Hey @gg1331, could you post the error you get? Also, could you add your current hardware configuration and a rundown of changes you (might have) made to relevant components?
I think need more detalis for this solution
okay so what you see is emergency dracut shell, in the shell run lvm lvscan
example you found :
$ lvm lvscan
inactive '/dev/qubes_dom0/root'
inactive '/dev/qubes_dom0/vm'
inactive '/dev/qubes_dom0/swap'
if lvm is founded and you see inactive simply active it by issuing :
lvm lvchange -a y qubes_dom0/root
lvm lvchange -a y qubes_dom0/vm
lvm lvchange -a y qubes_dom0/swap
swapon /dev/qubes_dom0/swap
run lvconvert --repair qubes_dom0/pool00, an please provide all the LV,
are you customizing disk when installing ?
as far i remember, it should be qubes_dom0/root-pool, pool00 is created because we do something to volume group.
This problem appeared after upgrading the templates . And I shutdown the device forcely due to system disruption
if vm is the problem try adding this to kernel option when you in grub menu qubes.skip_autostart so your kernel option is something like ............rhgb quiet qubes.skip_autostart
After writing …
lvm lvscan
try this instead.
lvm lvscan > a
less a
take a pict all of them.
after that, try this directly :
please don’t issue any command
sorry, add lvm so it be lvm lvconvert --repair qubes_dom0/pool00
if there’s no error anymore then
after that type exit.
Any update for this problem?
Still have the same problem
from redhat doc,
Issue
- System failed to boot with below error messages
dracut: Read-only locking type set. Write locks are prohibited.
dracut: Can't get lock for VG
Resolution
Boot system using rdshell option
Verify that locking_type is 4 in dracut lvm.conf file
Manually override locking_type using lvm vgchange -ay --config ' global {locking_type=1} ' command
boot system as root volume group is activated
Change locking_type to 1 ( or to 3 incase clustered locking) in /etc/lvm/lvm.conf file
Rebuild dracut image using dracut -v -f
Root Cause
lvm locking type was mistakenly set to 4 in lvm.conf present in initramfs image and lvm metadata modification operation was happening at boot time.
# grep locking_type /etc/lvm/lvm.conf
locking_type = 4
Are you using external drive for other use too ?
