Dear community,
i’m searching for a good soul that can help me.
In short:
There was an update (i think was about dom0, not sure)
I worked as usual, than I shut down the system (not sure if i suspended it)
Today it doesn’t boot
I insert my disk password
After some long time this is what i get
Warning: /dev/mapper/qubes_dom0-root does not exist
Warning: /dev/qubes_dom0/root does not existGenerating “/run/initramfs/rdsosreport.txt”
Entering emergency mode. Exit the shell to continue.
Type “journalctl” to view system logs.
You might wanti to save “/run/initramfs/rdsosreport.txt” to a USB stick or /boot
after mounting them and attach it to a bug report.Press ENTER form maintenance
(or press Control-D to continue):
— [after Control-D]
Warning: Not all disks have been found.
Warning: You might want to regenerate your initramfs.
This is what i tried:
(1)
$ lvm lvscan
A get the list of my vm, everyhing is inactive except /dev/qubes_dom0/swap
(2)
I tried the recovery procedure using a live usb installation
It say that the linux partition was not found.
I tried fdisk -l from the console, and I see the partitions (phew)
(3) I tried several suggestions from other posts, but it seems that those refer for older versions of qubes. I use v4.1
I tried everything I could try using my very limited knowledge of linux systems, and i don’t know what to do.
My last backup was 2 weeks ago, but i have new data i really need to recover.
My priority is to access my user data from several of those VM
My best scenario is to have my system up and running again…
Please help ![]()
------[ UPDATE 1 ]-------
I recovered my data, it was easier than expected ![]()
I used a live ubuntu USB to access the encrypted partition.
Now the most difficult part, I need to understand how to solve that boot error…
