Qubes 4.3 r4 - inconsistent installation - sys-bluetooth missing
Hello,
While i am reinstalling the same ISO (usb-install) onto the same system.
there was an inconsistency during installation.
previously, i had a Bluetooth AppVM created during various installations.
this last installation, it was not created…
(note: i do not recall an option to install sys-bluetooth)
is there a way to recreate the bluetooth AppVM post-install ?
thanks
Hi @curious_cat_8P ,
a sys-bluetoth Qube is not (and was not) part of the default created VMs.
see additionally Installation guide — Qubes OS Documentation
I must have stepped into another dimension - it am quite sure that it was created in a previous installation.
I never had a “sys-bluetooth”. I have been using QubesOS since version
4.1 days, and I only recall having:
  • sys-usb
  • sys-net
  • sys-firewall
  • sys-whonix
Thanks for confirmation -
The Bluetooth device is held by sys-usb, if you want to use audio (from Bluetooth or not), there is a guide to create a sys-audio Qube. By default sound is from Dom0 and Bluetooth in sys-usb so it does not mix well together.
A link to the guide in question, if you need it: Audio qube. ; )
Thanks everyone,
After i ‘translated’ my own notes ( yes - :scream: - i do use notes on paper )
QuBes 4.3 installation exposes the Bluetooth, and with the ‘AutoAttach’ settings:
it is super easy to have a sys-bluetooth
moving on, next, i should tackle bluetooth headsets
