Qrexec-daemon startup failed - sys-net fails to start on fresh install of qubes
I’ve ran Qubes before on this exact Laptop, with no issues. I then switched to another Linux distro for a while and am now trying to re-install Qubes. The installation works fine just as before; I’ve assigned more than enough RAM and space.
After booting, however, I get riddled with errors stating:
qrexec-daemon startup failed: <date> qrexec-daemon[15025]: qrexec-daemon.c:135:sigchld_parent_handler:
Connection to the VM failed
I have researched the above extensively, and found not solutions. I investigated the behaviour myself, and found the following details:
  • It is not caused by lack of memory or space as suspected in other similar threads
  • The error is caused by sys-net primarily, as far as I can tell.
  • Creating and running a new debian-11 qube with no NetVM works just fine.
  • Given the above, I tried creating a “new” sys-net manually. Created a new qube that provides network connectivity and uses Virt mode hvm: works and boots fine.
  • As soon as I go to Devices for the new qube, and add the NIC, the qube fails to start and that same error occurs, leading me to the conclusion that the device is somehow causing the error. I find this odd since as stated, I had a working installation for many months and haven’t touched the NIC of the laptop since.
The Network Controller device used is:
Network Controller: Realtek Semiconductor Co., Ltd. RTL8821CE 802.11ac PCIe Wireless Network Adapter
Based on various threads I’ve read, I also tried booting into my test-sys-net qube to disable the kernel module rtw88_8821ce. This was to no avail, since after adding the /etc/modprobe.d/blacklist.conf file and powering off, it was then deleted by the next boot. Not sure what the issue there is, maybe it’s intended behaviour, but it was a long shot anyways.
I would appreciate any insight or suggestions on this one; it has got me scratching my head and quite frustrated, given that it was working just fine previously.
Here’s some more debug info.
Dmesg:
loop0: detected capacity change from 0 to 952192
loop1: detected capacity change from 0 to 952192
pciback 0000:02:00.0: xen_pciback: vpci: assign to virtual slot 0
pciback 0000:02:00.0: registering for 20
xen-blkback: backend/vbd/20/51712: using 1 queues, protocol 1 (x86_64-abi) persisten grants
xen: registering gsi 17 triggering 0 polarity 1
Already setup the GSI :17
xen-blkback: backend/vbd/20/51728: using 1 queues, protocol 1 (x86_64-abi) persistent grants
xen-blkback: backend/vbd/20/51744: using 1 queues, protocol 1 (x86_64-abi) persistent grants
xen-blkback: backend/vbd/20/51760: using 1 queues, protocol 1 (x86_64-abi) persistent grants
audit: type=1103 audit(1685796477.766:405): pid=17982 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_rootok acct="redacted" exe="/usr/sbin/runuser" hostname=? addr=? terminal=? res=success'
audit: type=1105 audit(1685796477.766:405): pid=17982 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_open grantors=pam_keyinit,pam_limits,pam_unix acct="redacted" exe="/usr/sbin/runuser" hostname=? addr=? terminal=? res=success'
audit: type=1106 audit(1685796477.766:405): pid=17982 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_close grantors=pam_keyinit,pam_limits,pam_unix acct="redacted" exe="/usr/sbin/runuser" hostname=? addr=? terminal=? res=success'
audit: type=1104 audit(1685796477.766:405): pid=17982 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_rootok acct="redacted" exe="/usr/sbin/runuser" hostname=? addr=? terminal=? res=success'
xen-blkback: backend/cbd/19/51712: using 2 queues, protocol 1 (x86_64-abi) persistent grants
xen-blkback: backend/cbd/19/51728: using 2 queues, protocol 1 (x86_64-abi) persistent grants
xen-blkback: backend/cbd/19/51744: using 2 queues, protocol 1 (x86_64-abi) persistent grants
xen-blkback: backend/cbd/19/51760: using 2 queues, protocol 1 (x86_64-abi) persistent grants
/var/log/xen/console/guest-sys-net.log:
[2023-06-03 12:47:54] Logfile Opened
[2023-06-03 12:47:58] [    0.000000] Linux version 5.15.94-1.qubes.fc32.x86_64 (mockbuild@789905c09e0c4394afa45853cebe9fb2) (gcc (GCC) 10.3.1 20210422 (Red Hat 10.3.1-1), GNU ld version 2.34-6.fc32) #1 SMP Sun Feb 19 07:18:46 CET 2023
[2023-06-03 12:47:58] [    0.000000] Command line: root=/dev/mapper/dmroot ro nomodeset console=hvc0 rd_NO_PLYMOUTH rd.plymouth.enable=0 plymouth.enable=0 xen_scrub_pages=0  apparmor=1 security=apparmor
[2023-06-03 12:47:58] [    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[2023-06-03 12:47:58] [    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[2023-06-03 12:47:58] [    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[2023-06-03 12:47:58] [    0.000000] x86/fpu: Supporting XSAVE feature 0x020: 'AVX-512 opmask'
[2023-06-03 12:47:58] [    0.000000] x86/fpu: Supporting XSAVE feature 0x040: 'AVX-512 Hi256'
[2023-06-03 12:47:58] [    0.000000] x86/fpu: Supporting XSAVE feature 0x080: 'AVX-512 ZMM_Hi256'
[2023-06-03 12:47:58] [    0.000000] x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
[2023-06-03 12:47:58] [    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[2023-06-03 12:47:58] [    0.000000] x86/fpu: xstate_offset[5]:  832, xstate_sizes[5]:   64
[2023-06-03 12:47:58] [    0.000000] x86/fpu: xstate_offset[6]:  896, xstate_sizes[6]:  512
[2023-06-03 12:47:58] [    0.000000] x86/fpu: xstate_offset[7]: 1408, xstate_sizes[7]: 1024
[2023-06-03 12:47:58] [    0.000000] x86/fpu: xstate_offset[9]: 2432, xstate_sizes[9]:    8
[2023-06-03 12:47:58] [    0.000000] x86/fpu: Enabled xstate features 0x2e7, context size is 2440 bytes, using 'compacted' format.
[2023-06-03 12:47:58] [    0.000000] signal: max sigframe size: 3632
[2023-06-03 12:47:58] [    0.000000] BIOS-provided physical RAM map:
[2023-06-03 12:47:58] [    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009fbff] usable
[2023-06-03 12:47:58] [    0.000000] BIOS-e820: [mem 0x000000000009fc00-0x000000000009ffff] reserved
[2023-06-03 12:47:58] [    0.000000] BIOS-e820: [mem 0x00000000000f0000-0x00000000000fffff] reserved
[2023-06-03 12:47:58] [    0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000001e3fefff] usable
[2023-06-03 12:47:58] [    0.000000] BIOS-e820: [mem 0x000000001e3ff000-0x000000001e3fffff] reserved
[2023-06-03 12:47:58] [    0.000000] BIOS-e820: [mem 0x00000000fc000000-0x00000000fc00afff] ACPI NVS
[2023-06-03 12:47:58] [    0.000000] BIOS-e820: [mem 0x00000000fc00b000-0x00000000ffffffff] reserved
[2023-06-03 12:47:58] [    0.000000] NX (Execute Disable) protection: active
[2023-06-03 12:47:58] [    0.000000] SMBIOS 2.4 present.
[2023-06-03 12:47:58] [    0.000000] DMI: Xen HVM domU, BIOS 4.14.5 03/07/2023
[2023-06-03 12:47:58] [    0.000000] Hypervisor detected: Xen HVM
[2023-06-03 12:47:58] [    0.000000] Xen version 4.14.
[2023-06-03 12:47:58] [    0.000000] platform_pci_unplug: Netfront and the Xen platform PCI driver have been compiled for this kernel: unplug emulated NICs.
[2023-06-03 12:47:58] [    0.000000] platform_pci_unplug: Blkfront and the Xen platform PCI driver have been compiled for this kernel: unplug emulated disks.
[2023-06-03 12:47:58] [    0.000000] You might have to change the root device
[2023-06-03 12:47:58] [    0.000000] from /dev/hd[a-d] to /dev/xvd[a-d]
[2023-06-03 12:47:58] [    0.000000] in your root= kernel command line option
[2023-06-03 12:47:58] [    0.017412] tsc: Fast TSC calibration using PIT
[2023-06-03 12:47:58] [    0.017413] tsc: Detected 2803.281 MHz processor
[2023-06-03 12:47:58] [    0.017414] tsc: Detected 2803.228 MHz TSC
REDACTED
[2023-06-03 12:47:58] [    0.025899] ACPI: Reserving SSDT table memory at [mem 0xfc00a610-0xfc00a640]
[2023-06-03 12:47:58] [    0.027177] No NUMA configuration found
[2023-06-03 12:47:58] [    0.027184] Faking a node at [mem 0x0000000000000000-0x000000001e3fefff]
[2023-06-03 12:47:58] [    0.027194] NODE_DATA(0) allocated [mem 0x1dd0c000-0x1dd36fff]
[2023-06-03 12:47:58] [    0.027869] Zone ranges:
[2023-06-03 12:47:58] [    0.027870]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[2023-06-03 12:47:58] [    0.027872]   DMA32    [mem 0x0000000001000000-0x000000001e3fefff]
[2023-06-03 12:47:58] [    0.027873]   Normal   empty
[2023-06-03 12:47:58] [    0.027874]   Device   empty
[2023-06-03 12:47:58] [    0.027875] Movable zone start for each node
[2023-06-03 12:47:58] [    0.027877] Early memory node ranges
[2023-06-03 12:47:58] [    0.027878]   node   0: [mem 0x0000000000001000-0x000000000009efff]
[2023-06-03 12:47:58] [    0.027879]   node   0: [mem 0x0000000000100000-0x000000001e3fefff]
[2023-06-03 12:47:58] [    0.027881] Initmem setup node 0 [mem 0x0000000000001000-0x000000001e3fefff]
[2023-06-03 12:47:58] [    0.027885] On node 0, zone DMA: 1 pages in unavailable ranges
[2023-06-03 12:47:58] [    0.027908] On node 0, zone DMA: 97 pages in unavailable ranges
[2023-06-03 12:47:58] [    0.028602] On node 0, zone DMA32: 7169 pages in unavailable ranges
[2023-06-03 12:47:58] [    0.029936] ACPI: PM-Timer IO Port: 0xb008
[2023-06-03 12:47:58] [    0.029984] IOAPIC[0]: apic_id 1, version 17, address 0xfec00000, GSI 0-47
[2023-06-03 12:47:58] [    0.029987] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[2023-06-03 12:47:58] [    0.029988] ACPI: INT_SRC_OVR (bus 0 bus_irq 5 global_irq 5 low level)
[2023-06-03 12:47:58] [    0.029989] ACPI: INT_SRC_OVR (bus 0 bus_irq 10 global_irq 10 low level)
[2023-06-03 12:47:58] [    0.029990] ACPI: INT_SRC_OVR (bus 0 bus_irq 11 global_irq 11 low level)
[2023-06-03 12:47:58] [    0.029993] ACPI: Using ACPI (MADT) for SMP configuration information
[2023-06-03 12:47:58] [    0.029994] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[2023-06-03 12:47:58] [    0.029997] TSC deadline timer available
[2023-06-03 12:47:58] [    0.029998] smpboot: Allowing 2 CPUs, 0 hotplug CPUs
[2023-06-03 12:47:58] [    0.030005] [mem 0x1e400000-0xfbffffff] available for PCI devices
[2023-06-03 12:47:58] [    0.030006] Booting paravirtualized kernel on Xen HVM
[2023-06-03 12:47:58] [    0.030008] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns
[2023-06-03 12:47:58] [    0.034250] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:2 nr_cpu_ids:2 nr_node_ids:1
[2023-06-03 12:47:58] [    0.034337] percpu: Embedded 61 pages/cpu s212992 r8192 d28672 u1048576
[2023-06-03 12:47:58] [    0.034363] PV qspinlock hash table entries: 256 (order: 0, 4096 bytes, linear)
[2023-06-03 12:47:58] [    0.034367] Built 1 zonelists, mobility grouping on.  Total pages: 121711
[2023-06-03 12:47:58] [    0.034368] Policy zone: DMA32
[2023-06-03 12:47:58] [    0.034369] Kernel command line: root=/dev/mapper/dmroot ro nomodeset console=hvc0 rd_NO_PLYMOUTH rd.plymouth.enable=0 plymouth.enable=0 xen_scrub_pages=0  apparmor=1 security=apparmor
[2023-06-03 12:47:58] [    0.034391] You have booted with nomodeset. This means your GPU drivers are DISABLED
[2023-06-03 12:47:58] [    0.034392] Any video related functionality will be severely degraded, and you may not even be able to suspend the system properly
[2023-06-03 12:47:58] [    0.034393] Unless you actually understand what nomodeset does, you should reboot without enabling it
[2023-06-03 12:47:58] [    0.034448] Unknown kernel command line parameters "rd_NO_PLYMOUTH", will be passed to user space.
[2023-06-03 12:47:58] [    0.034464] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[2023-06-03 12:47:58] [    0.034473] Inode-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[2023-06-03 12:47:59] [    0.034509] mem auto-init: stack:byref_all(zero), heap alloc:on, heap free:on
[2023-06-03 12:47:59] [    0.034510] mem auto-init: clearing system memory may take some time...
[2023-06-03 12:47:59] [    0.070297] Memory: 426484K/495220K available (16393K kernel code, 3517K rwdata, 5700K rodata, 3604K init, 5784K bss, 68476K reserved, 0K cma-reserved)
[2023-06-03 12:47:59] [    0.071722] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[2023-06-03 12:47:59] [    0.071770] ftrace: allocating 51430 entries in 201 pages
[2023-06-03 12:47:59] [    0.087213] ftrace: allocated 201 pages with 4 groups
[2023-06-03 12:47:59] [    0.087383] rcu: Hierarchical RCU implementation.
[2023-06-03 12:47:59] [    0.087384] rcu: 	RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=2.
[2023-06-03 12:47:59] [    0.087385] 	Trampoline variant of Tasks RCU enabled.
[2023-06-03 12:47:59] [    0.087385] 	Rude variant of Tasks RCU enabled.
[2023-06-03 12:47:59] [    0.087385] 	Tracing variant of Tasks RCU enabled.
[2023-06-03 12:47:59] [    0.087387] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
[2023-06-03 12:47:59] [    0.087387] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[2023-06-03 12:47:59] [    0.091314] NR_IRQS: 524544, nr_irqs: 512, preallocated irqs: 16
[2023-06-03 12:47:59] [    0.091352] xen:events: Using FIFO-based ABI
[2023-06-03 12:47:59] [    0.091357] xen:events: Xen HVM callback vector for event delivery is enabled
[2023-06-03 12:47:59] [    0.091501] random: crng init done
[2023-06-03 12:47:59] [    0.139832] Console: colour VGA+ 80x25
[2023-06-03 12:47:59] [    0.141609] printk: console [hvc0] enabled
[2023-06-03 12:47:59] [    0.141631] ACPI: Core revision 20210730
[2023-06-03 12:47:59] [    0.141733] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 30580167144 ns
[2023-06-03 12:47:59] [    0.141811] APIC: Switch to symmetric I/O mode setup
[2023-06-03 12:47:59] [    0.142373] x2apic: IRQ remapping doesn't support X2APIC mode
[2023-06-03 12:47:59] [    0.144693] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=0 pin2=0
[2023-06-03 12:47:59] [    0.149071] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x28682a57772, max_idle_ns: 440795340794 ns
[2023-06-03 12:47:59] [    0.149097] Calibrating delay loop (skipped), value calculated using timer frequency.. 5606.45 BogoMIPS (lpj=2803228)
[2023-06-03 12:47:59] [    0.149119] pid_max: default: 32768 minimum: 301
[2023-06-03 12:47:59] [    0.149144] LSM: Security Framework initializing
[2023-06-03 12:47:59] [    0.149161] Yama: becoming mindful.
[2023-06-03 12:47:59] [    0.150113] AppArmor: AppArmor initialized
[2023-06-03 12:47:59] [    0.150132] Mount-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
[2023-06-03 12:47:59] [    0.150148] Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
[2023-06-03 12:47:59] [    0.151138] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[2023-06-03 12:47:59] [    0.151229] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
[2023-06-03 12:47:59] [    0.151242] Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
[2023-06-03 12:47:59] [    0.151260] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[2023-06-03 12:47:59] [    0.151281] Spectre V2 : Mitigation: Enhanced IBRS
[2023-06-03 12:47:59] [    0.151291] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[2023-06-03 12:47:59] [    0.151308] Spectre V2 : Spectre v2 / PBRSB-eIBRS: Retire a single CALL on VMEXIT
[2023-06-03 12:47:59] [    0.151325] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[2023-06-03 12:47:59] [    0.151343] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[2023-06-03 12:47:59] [    0.163772] Freeing SMP alternatives memory: 44K
[2023-06-03 12:47:59] [    0.163824] clocksource: xen: mask: 0xffffffffffffffff max_cycles: 0x1cd42e4dffb, max_idle_ns: 881590591483 ns
[2023-06-03 12:47:59] [    0.163856] installing Xen timer for CPU 0
[2023-06-03 12:47:59] [    0.163914] smpboot: CPU0: 11th Gen Intel(R) Core(TM) i7-1165G7 @ 2.80GHz (family: 0x6, model: 0x8c, stepping: 0x1)
[2023-06-03 12:47:59] [    0.163956] cpu 0 spinlock event irq 52
[2023-06-03 12:47:59] [    0.164078] Performance Events: unsupported p6 CPU model 140 no PMU driver, software events only.
[2023-06-03 12:47:59] [    0.164094] rcu: Hierarchical SRCU implementation.
[2023-06-03 12:47:59] [    0.164094] NMI watchdog: Perf NMI watchdog permanently disabled
[2023-06-03 12:47:59] [    0.164094] smp: Bringing up secondary CPUs ...
[2023-06-03 12:47:59] [    0.164094] installing Xen timer for CPU 1
[2023-06-03 12:47:59] [    0.164094] x86: Booting SMP configuration:
[2023-06-03 12:47:59] [    0.164094] .... node  #0, CPUs:      #1
[2023-06-03 12:47:59] [    0.164497] cpu 1 spinlock event irq 57
[2023-06-03 12:47:59] [    0.164497] smp: Brought up 1 node, 2 CPUs
[2023-06-03 12:47:59] [    0.164497] smpboot: Max logical packages: 1
[2023-06-03 12:47:59] [    0.164497] smpboot: Total of 2 processors activated (11212.91 BogoMIPS)
[2023-06-03 12:47:59] [    0.165240] devtmpfs: initialized
[2023-06-03 12:47:59] [    0.165240] x86/mm: Memory block size: 128MB
[2023-06-03 12:47:59] [    0.165259] ACPI: PM: Registering ACPI NVS region [mem 0xfc000000-0xfc00afff] (45056 bytes)
[2023-06-03 12:47:59] [    0.165259] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[2023-06-03 12:47:59] [    0.165259] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[2023-06-03 12:47:59] [    0.165259] pinctrl core: initialized pinctrl subsystem
[2023-06-03 12:47:59] [    0.165324] PM: RTC time: 12:47:59, date: 2023-06-03
[2023-06-03 12:47:59] [    0.165440] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[2023-06-03 12:47:59] [    0.165526] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
[2023-06-03 12:47:59] [    0.165545] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[2023-06-03 12:47:59] [    0.165563] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[2023-06-03 12:47:59] [    0.165585] audit: initializing netlink subsys (disabled)
[2023-06-03 12:47:59] [    0.165608] audit: type=2000 audit(1685796479.056:1): state=initialized audit_enabled=0 res=1
[2023-06-03 12:47:59] [    0.165608] thermal_sys: Registered thermal governor 'fair_share'
[2023-06-03 12:47:59] [    0.165608] thermal_sys: Registered thermal governor 'bang_bang'
[2023-06-03 12:47:59] [    0.165608] thermal_sys: Registered thermal governor 'step_wise'
[2023-06-03 12:47:59] [    0.166113] thermal_sys: Registered thermal governor 'user_space'
[2023-06-03 12:47:59] [    0.166133] cpuidle: using governor menu
[2023-06-03 12:47:59] [    0.166190] ACPI: bus type PCI registered
[2023-06-03 12:47:59] [    0.166562] PCI: Using configuration type 1 for base access
[2023-06-03 12:47:59] [    0.167432] Kprobes globally optimized
[2023-06-03 12:47:59] [    0.167459] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[2023-06-03 12:47:59] [    0.167459] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[2023-06-03 12:47:59] [    0.264196] cryptd: max_cpu_qlen set to 1000
[2023-06-03 12:47:59] [    0.265183] alg: No test for 842 (842-generic)
[2023-06-03 12:47:59] [    0.265183] alg: No test for 842 (842-scomp)
[2023-06-03 12:47:59] [    0.267291] raid6: skip pq benchmark and using algorithm avx512x4
[2023-06-03 12:47:59] [    0.267291] raid6: using avx512x2 recovery algorithm
[2023-06-03 12:47:59] [    0.267291] ACPI: Added _OSI(Module Device)
[2023-06-03 12:47:59] [    0.267291] ACPI: Added _OSI(Processor Device)
[2023-06-03 12:47:59] [    0.267291] ACPI: Added _OSI(3.0 _SCP Extensions)
[2023-06-03 12:47:59] [    0.267291] ACPI: Added _OSI(Processor Aggregator Device)
[2023-06-03 12:47:59] [    0.267291] ACPI: Added _OSI(Linux-Dell-Video)
[2023-06-03 12:47:59] [    0.268098] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[2023-06-03 12:47:59] [    0.268108] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[2023-06-03 12:47:59] [    0.271189] ACPI: 3 ACPI AML tables successfully acquired and loaded
[2023-06-03 12:47:59] [    0.272988] ACPI: Interpreter enabled
[2023-06-03 12:47:59] [    0.273005] ACPI: PM: (supports S0 S3 S5)
[2023-06-03 12:47:59] [    0.273014] ACPI: Using IOAPIC for interrupt routing
[2023-06-03 12:47:59] [    0.273035] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[2023-06-03 12:47:59] [    0.273298] ACPI: Enabled 2 GPEs in block 00 to 0F
[2023-06-03 12:47:59] [    0.279238] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[2023-06-03 12:47:59] [    0.279272] acpi PNP0A03:00: _OSC: OS supports [ASPM ClockPM Segments MSI EDR HPX-Type3]
[2023-06-03 12:47:59] [    0.279296] acpi PNP0A03:00: fail to add MMCONFIG information, can't access extended PCI configuration space under this bridge.
[2023-06-03 12:47:59] [    0.279520] PCI host bridge to bus 0000:00
[2023-06-03 12:47:59] [    0.279533] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[2023-06-03 12:47:59] [    0.279549] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[2023-06-03 12:47:59] [    0.279578] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[2023-06-03 12:47:59] [    0.279595] pci_bus 0000:00: root bus resource [mem 0xf0000000-0xfbffffff window]
[2023-06-03 12:47:59] [    0.279616] pci_bus 0000:00: root bus resource [bus 00-ff]
[2023-06-03 12:47:59] [    0.279873] pci 0000:00:00.0: [8086:1237] type 00 class 0x060000
[2023-06-03 12:47:59] [    0.281916] pci 0000:00:01.0: [8086:7000] type 00 class 0x060100
[2023-06-03 12:47:59] [    0.284099] pci 0000:00:01.1: [8086:7010] type 00 class 0x010180
[2023-06-03 12:47:59] [    0.285598] pci 0000:00:01.1: reg 0x20: [io  0xc300-0xc30f]
[2023-06-03 12:47:59] [    0.286099] pci 0000:00:01.1: legacy IDE quirk: reg 0x10: [io  0x01f0-0x01f7]
[2023-06-03 12:47:59] [    0.286118] pci 0000:00:01.1: legacy IDE quirk: reg 0x14: [io  0x03f6]
[2023-06-03 12:47:59] [    0.286133] pci 0000:00:01.1: legacy IDE quirk: reg 0x18: [io  0x0170-0x0177]
[2023-06-03 12:47:59] [    0.286151] pci 0000:00:01.1: legacy IDE quirk: reg 0x1c: [io  0x0376]
[2023-06-03 12:47:59] [    0.286752] pci 0000:00:01.3: [8086:7113] type 00 class 0x068000
[2023-06-03 12:47:59] [    0.288482] pci 0000:00:01.3: quirk: [io  0xb000-0xb03f] claimed by PIIX4 ACPI
[2023-06-03 12:47:59] [    0.288541] pci 0000:00:01.3: quirk: [io  0xb100-0xb10f] claimed by PIIX4 SMB
[2023-06-03 12:47:59] [    0.289439] pci 0000:00:02.0: [5853:0001] type 00 class 0xff8000
[2023-06-03 12:47:59] [    0.290487] pci 0000:00:02.0: reg 0x10: [io  0xc000-0xc0ff]
[2023-06-03 12:47:59] [    0.291099] pci 0000:00:02.0: reg 0x14: [mem 0xf0000000-0xf0ffffff pref]
[2023-06-03 12:47:59] [    0.295297] pci 0000:00:04.0: [1234:1111] type 00 class 0x030000
[2023-06-03 12:47:59] [    0.296024] pci 0000:00:04.0: reg 0x10: [mem 0xf1000000-0xf1ffffff pref]
[2023-06-03 12:47:59] [    0.296837] pci 0000:00:04.0: reg 0x18: [mem 0xf2022000-0xf2022fff]
[2023-06-03 12:47:59] [    0.299029] pci 0000:00:04.0: reg 0x30: [mem 0xf2000000-0xf200ffff pref]
[2023-06-03 12:47:59] [    0.299219] pci 0000:00:04.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[2023-06-03 12:47:59] [    0.299822] pci 0000:00:05.0: [8086:24cd] type 00 class 0x0c0320
[2023-06-03 12:47:59] [    0.300625] pci 0000:00:05.0: reg 0x10: [mem 0xf2023000-0xf2023fff]
[2023-06-03 12:47:59] [    0.304684] pci 0000:00:06.0: [10ec:c821] type 00 class 0x028000
[2023-06-03 12:47:59] [    0.307109] pci 0000:00:06.0: reg 0x10: [io  0xc200-0xc2ff]
[2023-06-03 12:47:59] [    0.311109] pci 0000:00:06.0: reg 0x18: [mem 0xf2010000-0xf201ffff 64bit]
[2023-06-03 12:47:59] [    0.319164] pci 0000:00:06.0: supports D1 D2
[2023-06-03 12:47:59] [    0.320825] ACPI: PCI: Interrupt link LNKA configured for IRQ 5
[2023-06-03 12:47:59] [    0.321082] ACPI: PCI: Interrupt link LNKB configured for IRQ 10
[2023-06-03 12:47:59] [    0.321325] ACPI: PCI: Interrupt link LNKC configured for IRQ 11
[2023-06-03 12:47:59] [    0.321561] ACPI: PCI: Interrupt link LNKD configured for IRQ 5
[2023-06-03 12:47:59] [    0.323122] xen:balloon: Initialising balloon driver
[2023-06-03 12:47:59] [    0.323168] iommu: Default domain type: Translated
[2023-06-03 12:47:59] [    0.323168] iommu: DMA domain TLB invalidation policy: lazy mode
[2023-06-03 12:47:59] [    0.323176] pci 0000:00:04.0: vgaarb: setting as boot VGA device
[2023-06-03 12:47:59] [    0.323191] pci 0000:00:04.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[2023-06-03 12:47:59] [    0.323211] pci 0000:00:04.0: vgaarb: bridge control possible
[2023-06-03 12:47:59] [    0.323225] vgaarb: loaded
[2023-06-03 12:47:59] [    0.323285] SCSI subsystem initialized
[2023-06-03 12:47:59] [    0.323305] ACPI: bus type USB registered
[2023-06-03 12:47:59] [    0.323305] usbcore: registered new interface driver usbfs
[2023-06-03 12:47:59] [    0.323305] usbcore: registered new interface driver hub
[2023-06-03 12:47:59] [    0.323305] usbcore: registered new device driver usb
[2023-06-03 12:47:59] [    0.323305] pps_core: LinuxPPS API ver. 1 registered
[2023-06-03 12:47:59] [    0.323305] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[2023-06-03 12:47:59] [    0.323305] PTP clock support registered
[2023-06-03 12:47:59] [    0.323305] EDAC MC: Ver: 3.0.0
[2023-06-03 12:47:59] [    0.324422] NetLabel: Initializing
[2023-06-03 12:47:59] [    0.324422] NetLabel:  domain hash size = 128
[2023-06-03 12:47:59] [    0.324422] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[2023-06-03 12:47:59] [    0.324422] NetLabel:  unlabeled traffic allowed by default
[2023-06-03 12:47:59] [    0.324422] PCI: Using ACPI for IRQ routing
[2023-06-03 12:47:59] [    0.325351] hpet: 3 channels of 0 reserved for per-cpu timers
[2023-06-03 12:47:59] [    0.325351] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[2023-06-03 12:47:59] [    0.325351] hpet0: 3 comparators, 64-bit 62.500000 MHz counter
[2023-06-03 12:47:59] [    0.327160] clocksource: Switched to clocksource xen
[2023-06-03 12:47:59] [    0.332021] VFS: Disk quotas dquot_6.6.0
[2023-06-03 12:47:59] [    0.332038] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[2023-06-03 12:47:59] [    0.453850] AppArmor: AppArmor Filesystem Enabled
[2023-06-03 12:47:59] [    0.453881] pnp: PnP ACPI init
[2023-06-03 12:47:59] [    0.453928] system 00:00: [mem 0x00000000-0x0009ffff] could not be reserved
[2023-06-03 12:47:59] [    0.453977] system 00:01: [io  0x08a0-0x08a3] has been reserved
[2023-06-03 12:47:59] [    0.454011] system 00:01: [io  0x0cc0-0x0ccf] has been reserved
[2023-06-03 12:47:59] [    0.454027] system 00:01: [io  0x04d0-0x04d1] has been reserved
[2023-06-03 12:47:59] [    0.454173] system 00:06: [io  0xae00-0xae0f] has been reserved
[2023-06-03 12:47:59] [    0.454188] system 00:06: [io  0xb044-0xb047] has been reserved
[2023-06-03 12:47:59] [    0.455184] pnp: PnP ACPI: found 7 devices
[2023-06-03 12:47:59] [    0.466835] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[2023-06-03 12:47:59] [    0.466902] NET: Registered PF_INET protocol family
[2023-06-03 12:47:59] [    0.466925] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[2023-06-03 12:47:59] [    0.467028] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
[2023-06-03 12:47:59] [    0.467049] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[2023-06-03 12:47:59] [    0.467068] TCP established hash table entries: 4096 (order: 3, 32768 bytes, linear)
[2023-06-03 12:47:59] [    0.467089] TCP bind hash table entries: 4096 (order: 4, 65536 bytes, linear)
[2023-06-03 12:47:59] [    0.467096] TCP: Hash tables configured (established 4096 bind 4096)
[2023-06-03 12:47:59] [    0.467148] MPTCP token hash table entries: 512 (order: 1, 12288 bytes, linear)
[2023-06-03 12:47:59] [    0.467170] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[2023-06-03 12:47:59] [    0.467186] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[2023-06-03 12:47:59] [    0.467214] NET: Registered PF_UNIX/PF_LOCAL protocol family
[2023-06-03 12:47:59] [    0.467231] NET: Registered PF_XDP protocol family
[2023-06-03 12:47:59] [    0.467246] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[2023-06-03 12:47:59] [    0.467261] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[2023-06-03 12:47:59] [    0.467276] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[2023-06-03 12:47:59] [    0.467291] pci_bus 0000:00: resource 7 [mem 0xf0000000-0xfbffffff window]
[2023-06-03 12:47:59] [    0.467373] pci 0000:00:01.0: PIIX3: Enabling Passive Release
[2023-06-03 12:47:59] [    0.467430] pci 0000:00:00.0: Limiting direct PCI/PCI transfers
[2023-06-03 12:47:59] [    0.467498] pci 0000:00:01.0: Activating ISA DMA hang workarounds
[2023-06-03 12:47:59] [    0.468702] PCI: CLS 0 bytes, default 64
[2023-06-03 12:47:59] [    0.468754] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x28682a57772, max_idle_ns: 440795340794 ns
[2023-06-03 12:47:59] [    0.468892] Trying to unpack rootfs image as initramfs...
[2023-06-03 12:47:59] [    0.534335] Freeing initrd memory: 6884K
[2023-06-03 12:47:59] [    0.535072] Initialise system trusted keyrings
[2023-06-03 12:47:59] [    0.535089] Key type blacklist registered
[2023-06-03 12:47:59] [    0.535148] workingset: timestamp_bits=36 max_order=17 bucket_order=0
[2023-06-03 12:47:59] [    0.535848] zbud: loaded
[2023-06-03 12:47:59] [    0.536209] integrity: Platform Keyring initialized
[2023-06-03 12:47:59] [    0.542229] NET: Registered PF_ALG protocol family
[2023-06-03 12:47:59] [    0.542241] xor: automatically using best checksumming function   avx
[2023-06-03 12:47:59] [    0.542258] Key type asymmetric registered
[2023-06-03 12:47:59] [    0.542266] Asymmetric key parser 'x509' registered
[2023-06-03 12:47:59] [    0.542288] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[2023-06-03 12:47:59] [    0.542335] io scheduler mq-deadline registered
[2023-06-03 12:47:59] [    0.542345] io scheduler kyber registered
[2023-06-03 12:47:59] [    0.542365] io scheduler bfq registered
[2023-06-03 12:47:59] [    0.542792] atomic64_test: passed for x86-64 platform with CX8 and with SSE
[2023-06-03 12:47:59] [    0.542919] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input0
[2023-06-03 12:47:59] [    0.542953] ACPI: button: Power Button [PWRF]
[2023-06-03 12:47:59] [    0.542982] input: Sleep Button as /devices/LNXSYSTM:00/LNXSLPBN:00/input/input1
[2023-06-03 12:47:59] [    0.543005] ACPI: button: Sleep Button [SLPF]
[2023-06-03 12:47:59] [    0.559751] xen:grant_table: Grant tables using version 1 layout
[2023-06-03 12:47:59] [    0.559839] Grant table initialized
[2023-06-03 12:47:59] [    0.559977] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[2023-06-03 12:47:59] [    0.560873] Non-volatile memory driver v1.3
[2023-06-03 12:47:59] [    0.560919] Linux agpgart interface v0.103
[2023-06-03 12:47:59] [    0.585068] ata_piix 0000:00:01.1: enabling device (0000 -> 0001)
[2023-06-03 12:47:59] [    0.586134] scsi host0: ata_piix
[2023-06-03 12:47:59] [    0.586228] scsi host1: ata_piix
[2023-06-03 12:47:59] [    0.586247] ata1: PATA max MWDMA2 cmd 0x1f0 ctl 0x3f6 bmdma 0xc300 irq 14
[2023-06-03 12:47:59] [    0.586262] ata2: PATA max MWDMA2 cmd 0x170 ctl 0x376 bmdma 0xc308 irq 15
[2023-06-03 12:47:59] [    0.587321] usbcore: registered new interface driver usbserial_generic
[2023-06-03 12:47:59] [    0.587340] usbserial: USB Serial support registered for generic
[2023-06-03 12:47:59] [    0.587371] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[2023-06-03 12:47:59] [    0.589339] serio: i8042 KBD port at 0x60,0x64 irq 1
[2023-06-03 12:47:59] [    0.589353] serio: i8042 AUX port at 0x60,0x64 irq 12
[2023-06-03 12:47:59] [    0.589402] mousedev: PS/2 mouse device common for all mice
[2023-06-03 12:47:59] [    0.591295] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
[2023-06-03 12:47:59] [    0.591362] rtc_cmos 00:02: registered as rtc0
[2023-06-03 12:47:59] [    0.591400] rtc_cmos 00:02: setting system clock to 2023-06-03T12:47:59 UTC (1685796479)
[2023-06-03 12:47:59] [    0.654317] rtc_cmos 00:02: alarms up to one day, 114 bytes nvram
[2023-06-03 12:47:59] [    0.654343] device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
[2023-06-03 12:47:59] [    0.654378] device-mapper: uevent: version 1.0.3
[2023-06-03 12:47:59] [    0.654418] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[2023-06-03 12:47:59] [    0.654468] intel_pstate: CPU model not supported
[2023-06-03 12:47:59] [    0.654519] hid: raw HID events driver (C) Jiri Kosina
[2023-06-03 12:47:59] [    0.654546] usbcore: registered new interface driver usbhid
[2023-06-03 12:47:59] [    0.654558] usbhid: USB HID core driver
[2023-06-03 12:47:59] [    0.654607] drop_monitor: Initializing network drop monitor service
[2023-06-03 12:47:59] [    0.654664] Initializing XFRM netlink socket
[2023-06-03 12:47:59] [    0.654719] NET: Registered PF_INET6 protocol family
[2023-06-03 12:47:59] [    0.654913] process '/usr/bin/busybox' started with executable stack
[2023-06-03 12:47:59] [    0.655645] Segment Routing with IPv6
[2023-06-03 12:47:59] [    0.655657] RPL Segment Routing with IPv6
[2023-06-03 12:47:59] [    0.655671] In-situ OAM (IOAM) with IPv6
[2023-06-03 12:47:59] [    0.655695] mip6: Mobile IPv6
[2023-06-03 12:47:59] [    0.655705] NET: Registered PF_PACKET protocol family
[2023-06-03 12:47:59] [    0.661301] IPI shorthand broadcast: enabled
[2023-06-03 12:47:59] [    0.661321] AVX2 version of gcm_enc/dec engaged.
[2023-06-03 12:47:59] [    0.661430] AES CTR mode by8 optimization enabled
[2023-06-03 12:47:59] [    0.667071] sched_clock: Marking stable (617427443, 49633855)->(873875071, -206813773)
[2023-06-03 12:47:59] [    0.667182] registered taskstats version 1
[2023-06-03 12:47:59] [    0.667247] Loading compiled-in X.509 certificates
[2023-06-03 12:47:59] [    0.667716] Loaded X.509 cert 'Build time autogenerated kernel key: 90fe2fa76ad832b7c3ae4247794ad0841b4b9aaa'
[2023-06-03 12:47:59] [    0.667770] zswap: loaded using pool lzo/zbud
[2023-06-03 12:47:59] [    0.667886] page_owner is disabled
[2023-06-03 12:47:59] [    0.667933] Key type .fscrypt registered
[2023-06-03 12:47:59] [    0.667943] Key type fscrypt-provisioning registered
[2023-06-03 12:47:59] [    0.668129] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=yes
[2023-06-03 12:47:59] [    0.668151] Key type big_key registered
[2023-06-03 12:47:59] [    0.668817] Key type encrypted registered
[2023-06-03 12:47:59] [    0.668829] AppArmor: AppArmor sha1 policy hashing enabled
[2023-06-03 12:47:59] [    0.668844] ima: No TPM chip found, activating TPM-bypass!
[2023-06-03 12:47:59] [    0.668858] Loading compiled-in module X.509 certificates
[2023-06-03 12:47:59] [    0.669259] Loaded X.509 cert 'Build time autogenerated kernel key: 90fe2fa76ad832b7c3ae4247794ad0841b4b9aaa'
[2023-06-03 12:47:59] [    0.669283] ima: Allocated hash algorithm: sha256
[2023-06-03 12:47:59] [    0.669301] ima: No architecture policies found
[2023-06-03 12:47:59] [    0.669319] evm: Initialising EVM extended attributes:
[2023-06-03 12:47:59] [    0.669330] evm: security.selinux
[2023-06-03 12:47:59] [    0.669339] evm: security.SMACK64 (disabled)
[2023-06-03 12:47:59] [    0.669350] evm: security.SMACK64EXEC (disabled)
[2023-06-03 12:47:59] [    0.669361] evm: security.SMACK64TRANSMUTE (disabled)
[2023-06-03 12:47:59] [    0.669373] evm: security.SMACK64MMAP (disabled)
[2023-06-03 12:47:59] [    0.669384] evm: security.apparmor
[2023-06-03 12:47:59] [    0.669392] evm: security.ima
[2023-06-03 12:47:59] [    0.669401] evm: security.capability
[2023-06-03 12:47:59] [    0.669409] evm: HMAC attrs: 0x1
[2023-06-03 12:47:59] [    0.669561] xenbus_probe_frontend: Device with no driver: device/vbd/51712
[2023-06-03 12:47:59] [    0.669576] xenbus_probe_frontend: Device with no driver: device/vbd/51728
[2023-06-03 12:47:59] [    0.669591] xenbus_probe_frontend: Device with no driver: device/vbd/51744
[2023-06-03 12:47:59] [    0.669605] xenbus_probe_frontend: Device with no driver: device/vbd/51760
[2023-06-03 12:47:59] [    0.669627] PM:   Magic number: 11:731:783
[2023-06-03 12:47:59] [    0.669655] acpi LNXCPU:6d: hash matches
[2023-06-03 12:47:59] [    0.669699] RAS: Correctable Errors collector initialized.
[2023-06-03 12:47:59] [    0.753829] Freeing unused decrypted memory: 2036K
[2023-06-03 12:47:59] [    0.754176] Freeing unused kernel image (initmem) memory: 3604K
[2023-06-03 12:47:59] [    0.754192] Write protecting the kernel read-only data: 24576k
[2023-06-03 12:47:59] [    0.754521] Freeing unused kernel image (text/rodata gap) memory: 2036K
[2023-06-03 12:47:59] [    0.754607] Freeing unused kernel image (rodata/data gap) memory: 444K
[2023-06-03 12:47:59] [    0.754623] rodata_test: all tests were successful
[2023-06-03 12:47:59] [    0.754638] Run /init as init process
[2023-06-03 12:47:59] Qubes initramfs script here:
[2023-06-03 12:47:59] [    0.756547] Invalid max_queues (4), will use default max: 2.
[2023-06-03 12:47:59] [    0.927944] blkfront: xvda: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
[2023-06-03 12:47:59] [    0.931635]  xvda: xvda1 xvda2 xvda3
[2023-06-03 12:47:59] [    0.942984] blkfront: xvdb: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
[2023-06-03 12:47:59] [    0.945360] blkfront: xvdc: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
[2023-06-03 12:47:59] [    0.956325] blkfront: xvdd: barrier or flush: disabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
[2023-06-03 12:47:59] Waiting for /dev/xvda* devices...
[2023-06-03 12:47:59] Qubes: Doing R/W setup for TemplateVM...
[2023-06-03 12:48:00] [    1.239298]  xvdc: xvdc1 xvdc3
[2023-06-03 12:48:00] Setting up swapspace version 1, size = 1073737728 bytes
[2023-06-03 12:48:00] UUID=845ee1b8-6e15-4017-b6c6-dd65002a9be5
[2023-06-03 12:48:00] Qubes: done.
[2023-06-03 12:48:00] modprobe: module ext4 not found in modules.dep
[2023-06-03 12:48:00] [    1.276258] EXT4-fs (xvda3): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[2023-06-03 12:48:00] Waiting for /dev/xvdd device...
[2023-06-03 12:48:00] [    1.279486] EXT4-fs (xvdd): mounting ext3 file system using the ext4 subsystem
[2023-06-03 12:48:00] [    1.280108] EXT4-fs (xvdd): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[2023-06-03 12:48:00] mount: can't read '/proc/mounts': No such file or directory
[2023-06-03 12:48:00] libbpf: failed to find valid kernel BTF
[2023-06-03 12:48:00] libbpf: Error loading vmlinux BTF: -3
[2023-06-03 12:48:00] libbpf: failed to load object 'iterators_bpf'
[2023-06-03 12:48:00] libbpf: failed to load BPF skeleton 'iterators_bpf': -3
[2023-06-03 12:48:00] Failed load could be due to wrong endianness
[2023-06-03 12:48:00] [    1.406895] systemd[1]: systemd 247.3-7+deb11u1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[2023-06-03 12:48:00] [    1.406976] systemd[1]: Detected virtualization xen.
[2023-06-03 12:48:00] [    1.406992] systemd[1]: Detected architecture x86-64.
[2023-06-03 12:48:00] Welcome to .[1mDebian GNU/Linux 11 (bullseye).[0m!
[2023-06-03 12:48:00] [    1.408503] systemd[1]: No hostname configured.
[2023-06-03 12:48:00] [    1.408528] systemd[1]: Set hostname to <localhost>.
[2023-06-03 12:48:00] [    1.513302] systemd[1]: /lib/systemd/system/qubes-db.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[2023-06-03 12:48:00] [    1.521214] input: ImExPS/2 Generic Explorer Mouse as /devices/platform/i8042/serio1/input/input4
[2023-06-03 12:48:00] [    1.538693] systemd[1]: /lib/systemd/system/qubes-gui-agent.service:15: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[2023-06-03 12:48:00] [    1.550207] systemd[1]: Queued start job for default target Multi-User System.
[2023-06-03 12:48:00] [    1.551074] systemd[1]: Created slice system-getty.slice.
[2023-06-03 12:48:00] [.[0;32m  OK  .[0m] Created slice .[0;1;39msystem-getty.slice.[0m.
[2023-06-03 12:48:00] [    1.551271] systemd[1]: Created slice system-modprobe.slice.
[2023-06-03 12:48:00] [.[0;32m  OK  .[0m] Created slice .[0;1;39msystem-modprobe.slice.[0m.
[2023-06-03 12:48:00] [    1.551436] systemd[1]: Created slice system-serial\x2dgetty.slice.
[2023-06-03 12:48:00] [.[0;32m  OK  .[0m] Created slice .[0;1;39msystem-serial\x2dgetty.slice.[0m.
[2023-06-03 12:48:00] [    1.551567] systemd[1]: Created slice User and Session Slice.
[2023-06-03 12:48:00] [.[0;32m  OK  .[0m] Created slice .[0;1;39mUser and Session Slice.[0m.
[2023-06-03 12:48:00] [    1.551653] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[2023-06-03 12:48:00] [.[0;32m  OK  .[0m] Started .[0;1;39mDispatch Password …ts to Console Directory Watch.[0m.
[2023-06-03 12:48:00] [    1.551731] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[2023-06-03 12:48:00] [.[0;32m  OK  .[0m] Started .[0;1;39mForward Password R…uests to Wall Directory Watch.[0m.
[2023-06-03 12:48:00] [    1.551865] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[2023-06-03 12:48:00] [.[0;32m  OK  .[0m] Set up automount .[0;1;39mArbitrary…s File System Automount Point.[0m.
[2023-06-03 12:48:00] [    1.551938] systemd[1]: Reached target Local Encrypted Volumes.
[2023-06-03 12:48:00] [.[0;32m  OK  .[0m] Reached target .[0;1;39mLocal Encrypted Volumes.[0m.
[2023-06-03 12:48:00] [    1.551995] systemd[1]: Reached target Remote File Systems.
[2023-06-03 12:48:00] [.[0;32m  OK  .[0m] Reached target .[0;1;39mRemote File Systems.[0m.
[2023-06-03 12:48:00] [    1.552036] systemd[1]: Reached target Slices.
[2023-06-03 12:48:00] [.[0;32m  OK  .[0m] Reached target .[0;1;39mSlices.[0m.
[2023-06-03 12:48:00] [    1.552129] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[2023-06-03 12:48:00] [.[0;32m  OK  .[0m] Listening on .[0;1;39mDevice-mapper event daemon FIFOs.[0m.
[2023-06-03 12:48:00] [    1.552212] systemd[1]: Listening on LVM2 poll daemon socket.
[2023-06-03 12:48:00] [.[0;32m  OK  .[0m] Listening on .[0;1;39mLVM2 poll daemon socket.[0m.
[2023-06-03 12:48:00] [    1.552301] systemd[1]: Listening on Syslog Socket.
[2023-06-03 12:48:00] [.[0;32m  OK  .[0m] Listening on .[0;1;39mSyslog Socket.[0m.
[2023-06-03 12:48:00] [    1.552370] systemd[1]: Listening on fsck to fsckd communication Socket.
[2023-06-03 12:48:00] [.[0;32m  OK  .[0m] Listening on .[0;1;39mfsck to fsckd communication Socket.[0m.
[2023-06-03 12:48:00] [    1.552432] systemd[1]: Listening on initctl Compatibility Named Pipe.
[2023-06-03 12:48:00] [.[0;32m  OK  .[0m] Listening on .[0;1;39minitctl Compatibility Named Pipe.[0m.
[2023-06-03 12:48:00] [    1.552531] systemd[1]: Listening on Journal Audit Socket.
[2023-06-03 12:48:00] [.[0;32m  OK  .[0m] Listening on .[0;1;39mJournal Audit Socket.[0m.
[2023-06-03 12:48:00] [    1.552613] systemd[1]: Listening on Journal Socket (/dev/log).
[2023-06-03 12:48:00] [.[0;32m  OK  .[0m] Listening on .[0;1;39mJournal Socket (/dev/log).[0m.
[2023-06-03 12:48:00] [    1.552691] systemd[1]: Listening on Journal Socket.
[2023-06-03 12:48:00] [.[0;32m  OK  .[0m] Listening on .[0;1;39mJournal Socket.[0m.
[2023-06-03 12:48:00] [    1.552778] systemd[1]: Listening on udev Control Socket.
[2023-06-03 12:48:00] [.[0;32m  OK  .[0m] Listening on .[0;1;39mudev Control Socket.[0m.
[2023-06-03 12:48:00] [    1.552851] systemd[1]: Listening on udev Kernel Socket.
[2023-06-03 12:48:00] [.[0;32m  OK  .[0m] Listening on .[0;1;39mudev Kernel Socket.[0m.
[2023-06-03 12:48:00] [    1.553229] systemd[1]: Mounting Huge Pages File System...
[2023-06-03 12:48:00]          Mounting .[0;1;39mHuge Pages File System.[0m...
[2023-06-03 12:48:00] [    1.553668] systemd[1]: Mounting POSIX Message Queue File System...
[2023-06-03 12:48:00]          Mounting .[0;1;39mPOSIX Message Queue File System.[0m...
[2023-06-03 12:48:00] [    1.715019] systemd[1]: Mounting Kernel Debug File System...
[2023-06-03 12:48:00]          Mounting .[0;1;39mKernel Debug File System.[0m...
[2023-06-03 12:48:00] [    1.715470] systemd[1]: Mounting Kernel Trace File System...
[2023-06-03 12:48:00]          Mounting .[0;1;39mKernel Trace File System.[0m...
[2023-06-03 12:48:00] [    1.715622] systemd[1]: Finished Availability of block devices.
[2023-06-03 12:48:00] [.[0;32m  OK  .[0m] Finished .[0;1;39mAvailability of block devices.[0m.
[2023-06-03 12:48:00] [    1.716073] systemd[1]: Starting Enable swap on /dev/xvdc1 early...
[2023-06-03 12:48:00]          Starting .[0;1;39mEnable swap on /dev/xvdc1 early.[0m...
[2023-06-03 12:48:00] [    1.716832] systemd[1]: Starting Set the console keyboard layout...
[2023-06-03 12:48:00]          Starting .[0;1;39mSet the console keyboard layout.[0m...
[2023-06-03 12:48:00] [    1.717270] systemd[1]: Starting Create list of static device nodes for the current kernel...
[2023-06-03 12:48:00]          Starting .[0;1;39mCreate list of st…odes for the current kernel.[0m...
[2023-06-03 12:48:00] [    1.717639] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[2023-06-03 12:48:00]          Starting .[0;1;39mMonitoring of LVM…meventd or progress polling.[0m...
[2023-06-03 12:48:00] [    1.718063] systemd[1]: Starting Load Kernel Module configfs...
[2023-06-03 12:48:00]          Starting .[0;1;39mLoad Kernel Module configfs.[0m...
[2023-06-03 12:48:00] [    1.718459] systemd[1]: Starting Load Kernel Module drm...
[2023-06-03 12:48:00]          Starting .[0;1;39mLoad Kernel Module drm.[0m...
[2023-06-03 12:48:00] [    1.718828] systemd[1]: Starting Load Kernel Module fuse...
[2023-06-03 12:48:00]          Starting .[0;1;39mLoad Kernel Module fuse.[0m...
[2023-06-03 12:48:00] [    1.719453] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[2023-06-03 12:48:00] [    1.720185] systemd[1]: Starting Journal Service...
[2023-06-03 12:48:00]          Starting .[0;1;39mJournal Service.[0m...
[2023-06-03 12:48:00] [    1.725919] systemd[1]: Starting Load Kernel Modules...
[2023-06-03 12:48:00]          Starting .[0;1;39mLoad Kernel Modules.[0m...
[2023-06-03 12:48:00] [    1.726315] systemd[1]: Starting Coldplug All udev Devices...
[2023-06-03 12:48:00]          Starting .[0;1;39mColdplug All udev Devices.[0m...
[2023-06-03 12:48:00] [    1.727037] systemd[1]: Mounted Huge Pages File System.
[2023-06-03 12:48:00] [.[0;32m  OK  .[0m] Mounted .[0;1;39mHuge Pages File System.[0m.
[2023-06-03 12:48:00] [    1.727136] systemd[1]: Mounted POSIX Message Queue File System.
[2023-06-03 12:48:00] [.[0;32m  OK  .[0m] Mounted .[0;1;39mPOSIX Message Queue File System.[0m.
[2023-06-03 12:48:00] [    1.727204] systemd[1]: Mounted Kernel Debug File System.
[2023-06-03 12:48:00] [.[0;32m  OK  .[0m] Mounted .[0;1;39mKernel Debug File System.[0m.
[2023-06-03 12:48:00] [    1.727266] systemd[1]: Mounted Kernel Trace File System.
[2023-06-03 12:48:00] [.[0;32m  OK  .[0m] Mounted .[0;1;39mKernel Trace File System.[0m.
[2023-06-03 12:48:00] [    1.727423] systemd[1]: Finished Create list of static device nodes for the current kernel.
[2023-06-03 12:48:00] [.[0;32m  OK  .[0m] Finished .[0;1;39mCreate list of st… nodes for the current kernel.[0m.
[2023-06-03 12:48:00] [    1.727566] systemd[1]: modprobe@configfs.service: Succeeded.
[2023-06-03 12:48:00] [    1.727665] systemd[1]: Finished Load Kernel Module configfs.
[2023-06-03 12:48:00] [.[0;32m  OK  .[0m] Finished .[0;1;39mLoad Kernel Module configfs.[0m.
[2023-06-03 12:48:00] [    1.728022] systemd[1]: Mounting Kernel Configuration File System...
[2023-06-03 12:48:00]          Mounting .[0;1;39mKernel Configuration File System.[0m...
[2023-06-03 12:48:00] [    1.730432] systemd[1]: Mounted Kernel Configuration File System.
[2023-06-03 12:48:00] [.[0;32m  OK  .[0m] Mounted .[0;1;39mKernel Configuration File System.[0m.
[2023-06-03 12:48:00] [    1.738496] Adding 1048572k swap on /dev/xvdc1.  Priority:-2 extents:1 across:1048572k SSFS
[2023-06-03 12:48:00] [    1.738955] systemd[1]: Condition check resulted in /dev/xvdc1 being skipped.
[2023-06-03 12:48:00] [    1.738992] systemd[1]: Unnecessary job for /dev/xvdc1 was removed.
[2023-06-03 12:48:00] [    1.739025] systemd[1]: Reached target Swap.
[2023-06-03 12:48:00] [.[0;32m  OK  .[0m] Reached target .[0;1;39mSwap.[0m.
[2023-06-03 12:48:00] [    1.740065] lp: driver loaded but no devices found
[2023-06-03 12:48:00] [    1.741423] fuse: init (API version 7.34)
[2023-06-03 12:48:00] [    1.743829] systemd[1]: dev-xvdc1-swap.service: Succeeded.
[2023-06-03 12:48:00] [    1.915818] systemd[1]: Finished Enable swap on /dev/xvdc1 early.
[2023-06-03 12:48:00] [.[0;32m  OK  .[0m] Finished .[0;1;39mEnable swap on /dev/xvdc1 early.[0m.
[2023-06-03 12:48:00] [    1.916078] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[2023-06-03 12:48:00] [    1.917193] systemd[1]: Starting Remount Root and Kernel File Systems...
[2023-06-03 12:48:00]          Starting .[0;1;39mRemount Root and Kernel File Systems.[0m...
[2023-06-03 12:48:00] [    1.917471] systemd[1]: modprobe@drm.service: Succeeded.
[2023-06-03 12:48:00] [    1.917582] systemd[1]: Finished Load Kernel Module drm.
[2023-06-03 12:48:00] [.[0;32m  OK  .[0m] Finished .[0;1;39mLoad Kernel Module drm.[0m.
[2023-06-03 12:48:00] [    1.917746] systemd[1]: modprobe@fuse.service: Succeeded.
[2023-06-03 12:48:00] [    1.917849] systemd[1]: Finished Load Kernel Module fuse.
[2023-06-03 12:48:00] [.[0;32m  OK  .[0m] Finished .[0;1;39mLoad Kernel Module fuse.[0m.
[2023-06-03 12:48:00] [    1.918295] systemd[1]: Mounting FUSE Control File System...
[2023-06-03 12:48:00]          Mounting .[0;1;39mFUSE Control File System.[0m...
[2023-06-03 12:48:00] [    1.924333] systemd[1]: Started Journal Service.
[2023-06-03 12:48:00] [.[0;32m  OK  .[0m] Started .[0;1;39mJournal Service.[0m.
[2023-06-03 12:48:00] [.[0;32m  OK  .[0m] Mounted .[0;1;39mFUSE Control File System.[0m.
[2023-06-03 12:48:00] [    1.924993] EXT4-fs (xvda3): re-mounted. Opts: discard. Quota mode: none.
[2023-06-03 12:48:00] [    1.954237] ppdev: user-space parallel port driver
[2023-06-03 12:48:01] [.[0;32m  OK  .[0m] Finished .[0;1;39mRemount Root and Kernel File Systems.[0m.
[2023-06-03 12:48:01] [.[0;32m  OK  .[0m] Finished .[0;1;39mSet the console keyboard layout.[0m.
[2023-06-03 12:48:01]          Starting .[0;1;39mFlush Journal to Persistent Storage.[0m...
[2023-06-03 12:48:01]          Starting .[0;1;39mCreate System Users.[0m...
[2023-06-03 12:48:01] [    1.961141] xen:xen_evtchn: Event-channel device installed
[2023-06-03 12:48:01] [    1.963457] systemd-journald[246]: Received client request to flush runtime journal.
[2023-06-03 12:48:01] [.[0;32m  OK  .[0m] Finished .[0;1;39mLoad Kernel Modules.[0m.
[2023-06-03 12:48:01]          Starting .[0;1;39mQubes DB agent.[0m...
[2023-06-03 12:48:01]          Starting .[0;1;39mApply Kernel Variables.[0m...
[2023-06-03 12:48:01] [.[0;32m  OK  .[0m] Finished .[0;1;39mColdplug All udev Devices.[0m.
[2023-06-03 12:48:01]          Starting .[0;1;39mHelper to synchronize boot up for ifupdown.[0m...
[2023-06-03 12:48:01] [.[0;32m  OK  .[0m] Finished .[0;1;39mCreate System Users.[0m.
[2023-06-03 12:48:01]          Starting .[0;1;39mCreate Static Device Nodes in /dev.[0m...
[2023-06-03 12:48:01] [    1.984551] memmap_init_zone_device initialised 32768 pages in 0ms
[2023-06-03 12:48:01] [.[0;32m  OK  .[0m] Finished .[0;1;39mHelper to synchronize boot up for ifupdown.[0m.
[2023-06-03 12:48:01] [.[0;32m  OK  .[0m] Started .[0;1;39mQubes DB agent.[0m.
[2023-06-03 12:48:01]          Starting .[0;1;39mInit Qubes Services settings.[0m...
[2023-06-03 12:48:01]          Starting .[0;1;39mLoad/Save Random Seed.[0m...
[2023-06-03 12:48:01] [.[0;32m  OK  .[0m] Finished .[0;1;39mApply Kernel Variables.[0m.
[2023-06-03 12:48:01] [.[0;32m  OK  .[0m] Finished .[0;1;39mCreate Static Device Nodes in /dev.[0m.
[2023-06-03 12:48:01]          Starting .[0;1;39mRule-based Manage…for Device Events and Files.[0m...
[2023-06-03 12:48:01] [.[0;32m  OK  .[0m] Finished .[0;1;39mLoad/Save Random Seed.[0m.
[2023-06-03 12:48:01] [.[0;32m  OK  .[0m] Finished .[0;1;39mInit Qubes Services settings.[0m.
[2023-06-03 12:48:01]          Starting .[0;1;39mInitialize and mount /rw and /home.[0m...
[2023-06-03 12:48:01]          Starting .[0;1;39mAdjust root filesystem size.[0m...
[2023-06-03 12:48:01] [    2.165718] EXT4-fs (xvdb): mounted filesystem with ordered data mode. Opts: discard. Quota mode: none.
[2023-06-03 12:48:01] [.[0;32m  OK  .[0m] Finished .[0;1;39mAdjust root filesystem size.[0m.
[2023-06-03 12:48:01] [.[0;32m  OK  .[0m] Started .[0;1;39mRule-based Manager for Device Events and Files.[0m.
[2023-06-03 12:48:01] [    2.336697] piix4_smbus 0000:00:01.3: SMBus Host Controller not enabled!
[2023-06-03 12:48:01] [    2.347158] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[2023-06-03 12:48:01] [    2.347626] input: PC Speaker as /devices/platform/pcspkr/input/input5
[2023-06-03 12:48:01] [    2.348912] ehci-pci: EHCI PCI platform driver
[2023-06-03 12:48:01] [    2.350267] ehci-pci 0000:00:05.0: EHCI Host Controller
[2023-06-03 12:48:01] [    2.354553] ehci-pci 0000:00:05.0: new USB bus registered, assigned bus number 1
[2023-06-03 12:48:01] [    2.355235] ehci-pci 0000:00:05.0: irq 39, io mem 0xf2023000
[2023-06-03 12:48:01] [    2.357480] FDC 0 is a S82078B
[2023-06-03 12:48:01] [    2.364578] ehci-pci 0000:00:05.0: USB 2.0 started, EHCI 1.00
[2023-06-03 12:48:01] [    2.391532] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[2023-06-03 12:48:01] [    2.391693] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[2023-06-03 12:48:01] [    2.393129] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[2023-06-03 12:48:01] [    2.393151] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[2023-06-03 12:48:01] [    2.393168] usb usb1: Product: EHCI Host Controller
[2023-06-03 12:48:01] [    2.393180] usb usb1: Manufacturer: Linux 5.15.94-1.qubes.fc32.x86_64 ehci_hcd
[2023-06-03 12:48:01] [    2.393197] usb usb1: SerialNumber: 0000:00:05.0
[2023-06-03 12:48:01] [    2.398240] hub 1-0:1.0: USB hub found
[2023-06-03 12:48:01] [    2.400324] hub 1-0:1.0: 6 ports detected
[2023-06-03 12:48:01] [    2.420595] Error: Driver 'pcspkr' is already registered, aborting...
[2023-06-03 12:48:01] [    2.457957] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[2023-06-03 12:48:01] [.[0;32m  OK  .[0m] Finished .[0;1;39mFlush Journal to Persistent Storage.[0m.
[2023-06-03 12:48:01] [.[0;32m  OK  .[0m] Found device .[0;1;39m/dev/hvc0.[0m.
[2023-06-03 12:48:01] [.[0;32m  OK  .[0m] Listening on .[0;1;39mLoad/Save RF …itch Status /dev/rfkill Watch.[0m.
[2023-06-03 12:48:01] [    2.620272] rtw_8821ce 0000:00:06.0: Firmware version 24.8.0, H2C version 12
[2023-06-03 12:48:01] [.[0;32m  OK  .[0m] Finished .[0;1;39mInitialize and mount /rw and /home.[0m.
[2023-06-03 12:48:01] [    2.638826] BUG: kernel NULL pointer dereference, address: 000000000000003c
[2023-06-03 12:48:01] [    2.638845] #PF: supervisor read access in kernel mode
[2023-06-03 12:48:01] [    2.638857] #PF: error_code(0x0000) - not-present page
[2023-06-03 12:48:01] [    2.638870] PGD 0 P4D 0
[2023-06-03 12:48:01] [    2.638877] Oops: 0000 [#1] SMP NOPTI
[2023-06-03 12:48:01] [    2.638887] CPU: 0 PID: 345 Comm: systemd-udevd Not tainted 5.15.94-1.qubes.fc32.x86_64 #1
[2023-06-03 12:48:01] [    2.638905] Hardware name: Xen HVM domU, BIOS 4.14.5 03/07/2023
[2023-06-03 12:48:01] [    2.638920] RIP: 0010:rtw_pci_probe+0x1da/0x1f2 [rtw88_pci]
[2023-06-03 12:48:01] [    2.638936] Code: 00 00 48 c7 c1 80 a8 3d c0 e8 62 6a d9 e0 5a 85 c0 0f 85 89 02 00 00 48 83 c4 08 5b 5d 41 5c 41 5d 41 5e 41 5f c3 cc cc cc cc <66> 81 7b 3c 86 80 0f 85 65 ff ff ff c6 85 20 7a 00 00 01 e9 59 ff
[2023-06-03 12:48:01] [    2.638976] RSP: 0018:ffffb2fd003c7bf0 EFLAGS: 00010246
[2023-06-03 12:48:01] [    2.638988] RAX: 0000000000000000 RBX: 0000000000000000 RCX: 0000000000000000
[2023-06-03 12:48:01] [    2.639005] RDX: ffff8b750c065453 RSI: ffff8b750c062b32 RDI: ffff8b750c06233e
[2023-06-03 12:48:01] [    2.639022] RBP: ffff8b750c062020 R08: 0000000000000000 R09: 0000000000000003
[2023-06-03 12:48:01] [    2.639039] R10: ffff8b750c065453 R11: ffff8b750c062b32 R12: ffff8b750c066cd8
[2023-06-03 12:48:01] [    2.639055] R13: ffff8b7501bde000 R14: ffff8b750c060820 R15: ffff8b750c067658
[2023-06-03 12:48:01] [    2.639072] FS:  0000758a1215e8c0(0000) GS:ffff8b751d200000(0000) knlGS:0000000000000000
[2023-06-03 12:48:01] [    2.639091] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[2023-06-03 12:48:01] [    2.639107] CR2: 000000000000003c CR3: 0000000002f80003 CR4: 0000000000770ef0
[2023-06-03 12:48:01] [    2.639126] PKRU: 55555554
[2023-06-03 12:48:01] [    2.639132] Call Trace:
[2023-06-03 12:48:01] [    2.639140]  <TASK>
[2023-06-03 12:48:01] [    2.639148]  local_pci_probe+0x42/0x80
[2023-06-03 12:48:01] [    2.639166]  ? __cond_resched+0x16/0x50
[2023-06-03 12:48:01] [    2.639179]  pci_call_probe+0x51/0xf0
[2023-06-03 12:48:01] [    2.639189]  pci_device_probe+0xa9/0xf0
[2023-06-03 12:48:01] [    2.639199]  call_driver_probe+0x21/0xd0
[2023-06-03 12:48:01] [    2.639210]  really_probe+0x1eb/0x310
[2023-06-03 12:48:01] [    2.639220]  __driver_probe_device+0x105/0x180
[2023-06-03 12:48:01] [    2.639232]  driver_probe_device+0x1e/0x90
[2023-06-03 12:48:01] [    2.639243]  __driver_attach+0xd2/0x1b0
[2023-06-03 12:48:01] [    2.639253]  ? __device_attach_driver+0x110/0x110
[2023-06-03 12:48:01] [    2.639265]  bus_for_each_dev+0x86/0xd0
[2023-06-03 12:48:01] [    2.639275]  bus_add_driver+0x13a/0x200
[2023-06-03 12:48:01] [    2.639285]  driver_register+0x8f/0xf0
[2023-06-03 12:48:01] [    2.639295]  ? 0xffffffffc02bd000
[2023-06-03 12:48:01] [    2.639304]  do_one_initcall+0x54/0x200
[2023-06-03 12:48:01] [    2.639315]  do_init_module+0x4c/0x250
[2023-06-03 12:48:01] [    2.639326]  __do_sys_finit_module+0xae/0x110
[2023-06-03 12:48:01] [    2.639339]  do_syscall_64+0x38/0x90
[2023-06-03 12:48:01] [    2.639349]  entry_SYSCALL_64_after_hwframe+0x61/0xcb
[2023-06-03 12:48:01] [    2.639362] RIP: 0033:0x758a126152e9
[2023-06-03 12:48:01] [    2.639372] Code: 00 c3 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 77 8b 0d 00 f7 d8 64 89 01 48
[2023-06-03 12:48:01] [    2.639412] RSP: 002b:00007ffd36feb768 EFLAGS: 00000246 ORIG_RAX: 0000000000000139
[2023-06-03 12:48:01] [    2.639430] RAX: ffffffffffffffda RBX: 000063abcbecd160 RCX: 0000758a126152e9
[2023-06-03 12:48:01] [    2.639446] RDX: 0000000000000000 RSI: 0000758a127b2e2d RDI: 0000000000000014
[2023-06-03 12:48:01] [    2.639463] RBP: 0000000000020000 R08: 0000000000000000 R09: 000063abcbf49c30
[2023-06-03 12:48:01] [    2.639480] R10: 0000000000000014 R11: 0000000000000246 R12: 0000758a127b2e2d
[2023-06-03 12:48:01] [    2.639497] R13: 0000000000000000 R14: 000063abcbdb81b0 R15: 000063abcbecd160
[2023-06-03 12:48:01] [    2.639514]  </TASK>
[2023-06-03 12:48:01] [    2.639520] Modules linked in: ghash_clmulni_intel(+) rtw88_8821ce(+) rtw88_8821c rtw88_pci rtw88_core mac80211 libarc4 snd_pcm snd_timer drm_vram_helper drm_ttm_helper cfg80211 ttm snd drm_kms_helper soundcore ehci_pci ehci_hcd pcspkr cec rfkill serio_raw i2c_piix4 floppy ata_generic pata_acpi xen_privcmd xen_gntdev xen_gntalloc xen_blkback xen_evtchn parport_pc drm ppdev fuse lp parport bpf_preload ip_tables overlay xen_blkfront
[2023-06-03 12:48:01] [    2.639619] CR2: 000000000000003c
[2023-06-03 12:48:01] [    2.639628] ---[ end trace aa7c7612e68c6c1f ]---
[2023-06-03 12:48:01] [    2.639640] RIP: 0010:rtw_pci_probe+0x1da/0x1f2 [rtw88_pci]
[2023-06-03 12:48:01] [    2.639653] Code: 00 00 48 c7 c1 80 a8 3d c0 e8 62 6a d9 e0 5a 85 c0 0f 85 89 02 00 00 48 83 c4 08 5b 5d 41 5[2023-06-03 12:48:01] c 41 5d 41 5e 41 5f c3 cc cc cc cc <66> 81 7b 3c 86 80 0f 85 65 ff ff ff c6 85 20 7a 00 00 01 e9 59 ff
[2023-06-03 12:48:01] [    2.639692] RSP: 0018:ffffb2fd003c7bf0 EFLAGS: 00010246
[2023-06-03 12:48:01] [    2.639704] RAX: 0000000000000000 RBX: 0000000000000000 RCX: 0000000000000000
[2023-06-03 12:48:01] [    2.639721] RDX: ffff8b750c065453 RSI: ffff8b750c062b32 RDI: ffff8b750c06233e
[2023-06-03 12:48:01] [    2.639738] RBP: ffff8b750c062020 R08: 0000000000000000 R09: 0000000000000003
[2023-06-03 12:48:01] [    2.639754] R10: ffff8b750c065453 R11: ffff8b750c062b32 R12: ffff8b750c066cd8
[2023-06-03 12:48:01] [    2.639771] R13: ffff8b7501bde000 R14: ffff8b750c060820 R15: ffff8b750c067658
[2023-06-03 12:48:01] [    2.639788] FS:  0000758a1215e8c0(0000) GS:ffff8b751d200000(0000) knlGS:0000000000000000
[2023-06-03 12:48:01] [    2.639806] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[2023-06-03 12:48:01] [    2.639820] CR2: 000000000000003c CR3: 0000000002f80003 CR4: 0000000000770ef0
[2023-06-03 12:48:01] [    2.639837] PKRU: 55555554
[2023-06-03 12:48:01] [    2.639843] Kernel panic - not syncing: Fatal exception
[2023-06-03 12:48:01] [    2.639905] Kernel Offset: 0x20000000 from 0xffffffff81000000 (relocation range: 0xffffffff80000000-0xffffffffbfffffff)
Seems like a problem with kernel module as you’ve stated:
You need to add blacklist.conf in sys-net template.
That actually did the trick. For anyone facing the same, try adding the following line to /etc/modprobe.d/blacklist.conf inside the template used for the sys-net qube:
blacklist rtw88_8821ce
The problem now, though, is that without the driver the WiFi does not work.
More for the sake of having a completed answer, do you have any suggestions where to go from here? The reference above said:
I’m having trouble coming up with a way to do this without internet connectivity. Also, I tried a USB-Ethernet connection and it also would not work (maybe because I don’t have a sys-usb qube?)
The suggestion in your quote is the way to go. But without network access in Qubes it’ll be tricky for sure.
What exactly did you try?
Can you create the sys-usb?
Or pass your USB controller to sys-net to use the USB-Ethernet adapter there?
I ran the following command as per the qubes docs to create sys-usb. It ran without errors:
sudo qubesctl state.sls qvm.sys-usb
After that I tried powering it on in the Management panel, and got this error:
Volume group "qubes_dom0" not found.
Cannot process volume group qubes_dom0
Trying to open it again yields a different error:
volume qubes_dom0/vm-fedora-37-root missing
Do you have Qubes installed on USB drive?
I’m installing it on an external SSD.
Is it connected over USB?
It is.
I had attempted booting it on the internal drive but gave up due to the sys-net errors. I thought maybe the drive was faulty so that’s why I used an external SSD this time around.
Since you’re using USB drive then after calling:
Since it doesn’t know that you’re booting from USB drive it’ll by default create the sys-usb that would contain all your USB controllers including the one to which your USB drive is connected. So when you start sys-usb it’ll remove USB controllers from dom0 and your dom0 will lose it’s drive with filesystem.
You need to determine which USB controller is used by your USB drive and remove it from the list of passed through PCI devices in sys-usb.
You’ll need to reboot Qubes and disable your VMs autostart to prevent sys-usb starting:
Autostart troubleshooting | Qubes OS
Thank you for all your help.
Since I only have one USB controller and it seemed far too complex to figure out how to separate my usb-to-ethernet adapter to allow ethernet connectivity, I just installed qubes on the main drive, unlocking sys-usb and therefore internet connectivity via ethernet. I’ll try to manually compile the broken driver from here, but this is already a massive improvement.
Thanks again and if I can buy you a coffee let me know :wink:
Hey, so I’m having more or less the same issue here and can’t seem to find the file mentioned here; for context I installed normally and anything related to sys-net causes a crash (so non-internet stuff works), am not that versed in Linux (beginner-intermediate), and installed on a Thinkpad with S/N PF-1EV5A7 (Chinese model) with a Windows partition I’ll delete soon. What now?
Do you mean /etc/modprobe.d/blacklist.conf?
It doesn’t exists by default, you need to create it and add the needed line.
Just to be clear, are there any downsides to doing this?
Also my network controller is Realtek 8821CE Wireless LAN 802.11ac PCI-E NIC, if that helps (I’m really not sure)
In blacklisting the WiFi kernel module?
There are no downsides, it just won’t be used.
