Pulling YUBIKEY triggers shutdown
Hi I am using a YUBIKEY as described in this link:
https://forum.qubes-os.org/t/luks-with-yubikey-2fa-chal-resp-on-qubes-4-2-0/23119
When I pull the YUBIKEY out it triggers a shutdown. Does anyone know what triggers that behaviour?
So to give a little more context. When I fire up the machine the key is read and triggers the decryption of my ssd. When the machine is up, I can see the YUBIKEY in my sys-usb. So it should be detached from dom0.
Make it a feature.
Bind the Yubikey to your hand, and if your switched on laptop gets stolen by friendly police or airport staff, it changes into safe state which is shut down :slight_smile:
Indeed it could be a feature…nevertheless I´d like to know what trigger´ s it…I have the suspicion that it is triggered through using the usb-c ports which also are thunderbolt 4 configured…
Hello
Is this a proper shutdown, or is the computer powering off instantly?
I have seen a similar product - Buskill USB Kill Cord :+1:
So after some tinkering and using a usbc => usba adapter I was able to use it as intended - no shutdown, just unlocking and unplugging.
Apparently the Thunderbolt 4 on my usbc slot triggers that shutdown when I am unplugging…
