I’m trying to apply a Salt state to a template cloned from the fedora-40 templates in 4.2, and get the following error. The state file is simple, as follows:
deb-dev-packages.installed:
pkg.installed:
- pkgs:
- autoconf
- automake
Note I had a similar error in 4.1 when updating the fedora-39 template, whereas in the 4.2 case updating the template with qubes-update-gui does not show that error.
This seems a bit similar to Error updating fedora-39-minimal, but it would be strange that the official templates would lack such a dependency?
[root@dom0 ~]# qubesctl --show-output --skip-dom0 --targets=fedora-40-dev state.apply qvm.fedora-dev
fedora-40-dev:
_error:
Failed to return clean data
retcode:
1
stderr:
File "/var/tmp/.root_dd8a91_salt/salt-call", line 27, in <module>
salt_call()
File "/var/tmp/.root_dd8a91_salt/pyall/salt/scripts.py", line 438, in salt_call
import salt.cli.call
File "/var/tmp/.root_dd8a91_salt/pyall/salt/cli/call.py", line 3, in <module>
import salt.cli.caller
File "/var/tmp/.root_dd8a91_salt/pyall/salt/cli/caller.py", line 12, in <module>
import salt.channel.client
File "/var/tmp/.root_dd8a91_salt/pyall/salt/channel/client.py", line 13, in <module>
import salt.crypt
File "/var/tmp/.root_dd8a91_salt/pyall/salt/crypt.py", line 26, in <module>
import salt.payload
File "/var/tmp/.root_dd8a91_salt/pyall/salt/payload.py", line 12, in <module>
import salt.loader.context
File "/var/tmp/.root_dd8a91_salt/pyall/salt/loader/__init__.py", line 23, in <module>
import salt.utils.event
File "/var/tmp/.root_dd8a91_salt/pyall/salt/utils/event.py", line 67, in <module>
import salt.ext.tornado.iostream
File "/var/tmp/.root_dd8a91_salt/pyall/salt/ext/tornado/iostream.py", line 41, in <module>
from salt.ext.tornado.netutil import ssl_wrap_socket, ssl_match_hostname, SSLCertificateError, _client_ssl_defaults, _server_ssl_defaults
File "/var/tmp/.root_dd8a91_salt/pyall/salt/ext/tornado/netutil.py", line 57, in <module>
import backports.ssl_match_hostname
ModuleNotFoundError: No module named 'backports'
[ERROR ] An un-handled exception was caught by Salt's global exception handler:
salt_call()
import salt.crypt
import salt.payload
stdout:
With the idea of adding the seemingly-missing package, I went the following way, and I’m puzzled by apparently not having the official QubesOS key registered in the official Fedora template - and the forum search on feels strangely silent for something I had already noticed quite some time ago. What is wrong here?
[root@dom0 ~]# qvm-run -p fedora-40 "dnf search backports"
Fedora 40 - x86_64 5.4 MB/s | 20 MB 00:03
Fedora 40 openh264 (From Cisco) - x86_64 1.3 kB/s | 1.4 kB 00:01
Fedora 40 - x86_64 - Updates 2.7 MB/s | 9.8 MB 00:03
Qubes OS Repository for VM (updates) 2.1 kB/s | 833 B 00:00
Qubes OS Repository for VM (updates) 2.3 MB/s | 2.4 kB 00:00
Importing GPG key 0x8E34D89F:
Userid : "Qubes OS Release 4.2 Signing Key"
Fingerprint: 9C88 4DF3 F810 64A5 69A4 A9FA E022 E58F 8E34 D89F
From : /etc/pki/rpm-gpg/RPM-GPG-KEY-qubes-4.2-primary
Is this ok [y/N]: n
Qubes OS Repository for VM (updates) 2.3 kB/s | 833 B 00:00
Error: Failed to download metadata for repo 'qubes-vm-r4.2-current': repomd.xml GPG signature verification error: Signing key not found
[root@dom0 ~]#
I don’t like accepting the key in the template, but I can reinstall it later. That search does not seem to give anything like what I’d expect. Can anyone shed light on what Salt is expecting and why it does not work?
