Problem Kexec'ing from Linux to Xen on T430 with Heads BIOS
Greetings Qubes community, I am configuring a setup based on the one described here (Qubes OS Installation - Detached encrypted boot and header) with some minor changes. I am trying to implement what is described in this comment (My personal experience of attempt to harden qubes VM - #7 by zphaskqjrm), using a minimal Linux distribution installed onto a usb drive. The main drive that Qubes is installed uses LUKS full disk encryption and has a detached header so that the encrypted contents of the drive are indistinguishable from random data. The header and the keyfile needed to unlock it are embedded into the initramfs, which is stored on an encrypted partition on the usb drive along with vmlinuz and the Xen gzip archive. The computer boots the minimal Linux installation on the usb drive, which asks the user to enter in the password to unlock the encrypted partition with the initramfs. Then the initramfs, vmlinuz, and xen.gz are loaded into ram, the encrypted partition is closed, and kexec -e is ran to boot into Qubes. The purpose of this setup is to allow greater flexibility in encryption schemes and password input. I have already tested this setup using virtual machines but booting into Debian instead of Qubes. I’ve encountered smooth operation during testing with Debian.
The problem I am having with Qubes is that I am not able to kexec from a Linux installation into Qubes.
These are what I have ruled out as the likely issue:
The kexec-tools installation on the usb drive: I am able to kexec into Debian when testing with virtual machines.
The files loaded into ram or an error in the process of decrypting the main disk with the Qubes installation: I am able to load the files into ram and kexec successfully from the Heads recovery shell. The initramfs is able to decrypt the main disk and Qubes boots successfully. The trouble I am having is with doing this from the other Linux installation on the usb drive.
The Qubes installation itself: Qubes runs like normal with no problems when using kexec from the Heads recovery shell.
Video drivers or other programs on the usb Linux installation: I am still unable to kexec into Qubes even if no video drivers, Xorg, or other programs are installed on the usb Linux installation. Kexec is able to load the files into ram without issue, booting into Qubes fails.
When trying to boot into Qubes the screen goes completely black. After a short pause of a couple seconds the computer returns to the Heads BIOS menu. There are no error messages or other output shown.
These are the commands that are successful from the Heads recovery shell and fail when running from Linux.
kexec -l xen.gz --command-line=“placeholder console=none dom0_mem=min:1024M dom0_mem=max:4096M ucode=scan smt=off gnttab_max_frames=2048 gnttab_max_maptrack_frames=4096 no-real-mode edd=off” --module=“vmlinuz placeholder root=/dev/mapper/qubes_dom0-root ro rd.lvm.lv=qubes_dom0/root rd.lvm.lv=qubes_dom0/swap rd.lvm.lv=qubes_dom0/boot plymouth.ignore-serial-consoles i915.alpha_support=1 intel_iommu=igfx_off rd.driver.pre=btrfs rhgb quiet” --module=“initramfs.img”
kexec -l -t multiboot-x86 --append=“placeholder console=none dom0_mem=min:1024M dom0_mem=max:4096M ucode=scan smt=off gnttab_max_frames=2048 gnttab_max_maptrack_frames=4096 no-real-mode edd=off” --module=“vmlinuz placeholder root=/dev/mapper/qubes_dom0-root ro rd.lvm.lv=qubes_dom0/root rd.lvm.lv=qubes_dom0/swap rd.lvm.lv=qubes_dom0/boot plymouth.ignore-serial-consoles i915.alpha_support=1 intel_iommu=igfx_off rd.driver.pre=btrfs rhgb quiet” --module=“initramfs.img” xen.gz
Booting without no-real-mode fails even from the Heads recovery shell
Interestingly, the following command succeeds in booting into Qubes from Linux, but Qubes is not functional due to missing the xen.gz file. This makes me think the problem is with Xen, and not the Heads BIOS.
kexec -l vmlinuz --append=‘root=/dev/mapper/qubes_dom0-root ro rd.lvm.lv=qubes_dom0/boot rd.lvm.lv=qubes_dom0/root rd.lvm.lv=qubes_dom0/swap plymouth.ignore-serial-consoles i915.alpha_support=1 intel_iommu=igfx_off rd.driver.pre=btrfs rhgb quiet’ --initrd=initramfs.img
kexec -e is used to boot for all commands
Can anyone help me solve this issue? Hopefully the solution is something simple like a command line parameter. It would be nice if I could even get some error messages to help me debug this instead of just a blank screen. Can the xen.gz file be loaded once in Qubes? It would also work if Heads can boot into the files loaded by kexec after a full shutdown and reboot.
the above guide is for uefi + gpt drive, you may check here for mbr + legacy Qubes OS Installation - BTRFS w/ Detached encrypted boot and header
you can notice we have different kernel parameter, this is the parameter in legacy, full command on link above.
cryptdevice=aa7332a5-e4ac-442c-9328-cdbd4a0b42e8:luks-aa7332a5-e4ac-442c-9328-cdbd4a0b42e8
also im not familiar with how heads boot, so try hard.
Thank you for replying. I’ve tried your suggestion but it seems to have no effect.
I’ve attached the debug output from the first kexec command, both when it succeeds from the Heads recovery shell and when it fails when “kexec -e” is ran in Linux. They seem similar except for the end where it lists the segments.
Heads (successful)
Try gzip decompression.
kernel: 0x7fd50ca00020 kernel_size: 0x224c0c
MEMORY RANGES
0000000000001000-000000000009ffff (0)
00000000000a0000-00000000000fffff (1)
0000000000100000-000000007fec9fff (0)
0000000080000000-00000000829fffff (1)
00000000f0000000-00000000f3ffffff (1)
00000000fed40000-00000000fed44fff (1)
00000000fed90000-00000000fed91fff (1)
0000000100000000-000000047d5fffff (0)
sym: sha256_starts info: 12 other: 00 shndx: 1 value: 1120 size: 48
sym: sha256_starts value: 2120 addr: 1002
R_X86_64_64
sym: sha256_update info: 12 other: 00 shndx: 1 value: 3cb0 size: 19
sym: sha256_update value: 4cb0 addr: 100f
R_X86_64_64
sym: sha256_regions info: 11 other: 00 shndx: 8 value: 40 size: 100
sym: sha256_regions value: 6040 addr: 101a
R_X86_64_64
sym: sha256_regions value: 6140 addr: 1044
R_X86_64_64
sym: sha256_finish info: 12 other: 00 shndx: 1 value: 3cd0 size: 15e
sym: sha256_finish value: 4cd0 addr: 105b
R_X86_64_64
sym: sha256_digest info: 11 other: 00 shndx: 8 value: 20 size: 20
sym: sha256_digest value: 6020 addr: 106f
R_X86_64_64
sym:     memcmp info: 12 other: 00 shndx: 1 value: 599 size: 21
sym: memcmp value: 1599 addr: 1079
R_X86_64_64
sym: .rodata.str1.1 info: 03 other: 00 shndx: 5 value: 0 size: 0
sym: .rodata.str1.1 value: 4f40 addr: 108d
R_X86_64_64
sym:     printf info: 12 other: 00 shndx: 1 value: 4ba size: a0
sym: printf value: 14ba addr: 109b
R_X86_64_64
sym: .rodata.str1.1 value: 4f70 addr: 10a5
R_X86_64_64
sym: .rodata.str1.1 value: 4f60 addr: 10b3
R_X86_64_64
sym: .rodata.str1.1 value: 4f76 addr: 10d3
R_X86_64_64
sym: sha256_digest value: 6020 addr: 10e1
R_X86_64_64
sym: .rodata.str1.1 value: 4f78 addr: 10ef
R_X86_64_64
sym: .rodata.str1.1 value: 4f70 addr: 1105
R_X86_64_64
sym: .rodata.str1.1 value: 4f76 addr: 1117
R_X86_64_64
sym: .rodata.str1.1 value: 4f88 addr: 1136
R_X86_64_64
sym: printf value: 14ba addr: 1142
R_X86_64_64
sym: setup_arch info: 12 other: 00 shndx: 1 value: 762 size: 56
sym: setup_arch value: 1762 addr: 114f
R_X86_64_64
sym: skip_checks info: 11 other: 00 shndx: 8 value: 0 size: 4
sym: skip_checks value: 6000 addr: 115b
R_X86_64_64
sym: verify_sha256_digest info: 12 other: 00 shndx: 1 value: 0 size: 134
sym: verify_sha256_digest value: 1000 addr: 116a
R_X86_64_64
sym: post_verification_setup_arch info: 12 other: 00 shndx: 1 value: 7f0 size: 58
sym: post_verification_setup_arch value: 17f0 addr: 117c
R_X86_64_64
sym:    putchar info: 12 other: 00 shndx: 1 value: d8e size: 124
sym: putchar value: 1d8e addr: 118f
R_X86_64_64
sym: .rodata.str1.1 value: 4f9a addr: 12d1
R_X86_64_64
sym:   vsprintf info: 12 other: 00 shndx: 1 value: 187 size: 29d
sym: vsprintf value: 1187 addr: 14a0
R_X86_64_64
sym: vsprintf value: 1187 addr: 1540
R_X86_64_64
sym:    entry32 info: 10 other: 00 shndx: 1 value: 5c0 size: 0
sym: entry32 value: 15bc addr: 15cd
R_X86_64_PC32
sym: entry32 value: 15bc addr: 15e2
R_X86_64_PC32
sym:      .data info: 03 other: 00 shndx: 8 value: 0 size: 0
sym: .data value: 615c addr: 15fd
R_X86_64_PC32
sym: .data value: 613c addr: 1604
R_X86_64_PC32
sym:    .rodata info: 03 other: 00 shndx: 3 value: 0 size: 0
sym: .rodata value: 4e54 addr: 160a
R_X86_64_PC32
sym: .data value: 61ac addr: 1610
R_X86_64_PC32
sym: .rodata value: 4e2c addr: 1616
R_X86_64_PC32
sym: .rodata value: 4ec1 addr: 1649
R_X86_64_PC32
sym: .rodata value: 4ed0 addr: 1650
R_X86_64_PC32
sym: .rodata value: 4edb addr: 1657
R_X86_64_PC32
sym: .rodata value: 4ee6 addr: 165e
R_X86_64_PC32
sym: .rodata value: 4ef1 addr: 1665
R_X86_64_PC32
sym: .rodata value: 4efc addr: 166c
R_X86_64_PC32
sym: .rodata value: 4f07 addr: 1673
R_X86_64_PC32
sym: .rodata value: 4ef6 addr: 167a
R_X86_64_PC32
sym: .data value: 6271 addr: 1681
R_X86_64_PC32
sym: .rodata value: 4eec addr: 1693
R_X86_64_PC32
sym: .rodata value: 4f1c addr: 16a9
R_X86_64_PC32
sym: .rodata value: 4e5c addr: 16bc
R_X86_64_PC32
sym: .rodata value: 4e64 addr: 16c3
R_X86_64_PC32
sym: .rodata value: 4e6c addr: 16ca
R_X86_64_PC32
sym: .rodata value: 4e74 addr: 16d1
R_X86_64_PC32
sym: .rodata value: 4e7c addr: 16d8
R_X86_64_PC32
sym: .rodata value: 4e84 addr: 16df
R_X86_64_PC32
sym: .rodata value: 4e8c addr: 16e6
R_X86_64_PC32
sym: .rodata value: 4e94 addr: 16ed
R_X86_64_PC32
sym: .rodata value: 4e9c addr: 16f4
R_X86_64_PC32
sym: .rodata value: 4ea4 addr: 16fb
R_X86_64_PC32
sym: .rodata value: 4eac addr: 1702
R_X86_64_PC32
sym: .rodata value: 4eb4 addr: 1709
R_X86_64_PC32
sym: .rodata value: 4ebc addr: 1710
R_X86_64_PC32
sym: .rodata value: 4ec4 addr: 1717
R_X86_64_PC32
sym: .rodata value: 4ecc addr: 171e
R_X86_64_PC32
sym: .rodata value: 4ed4 addr: 1725
R_X86_64_PC32
sym: .rodata value: 4edc addr: 172b
R_X86_64_PC32
sym: .rodata value: 4f1c addr: 1733
R_X86_64_PC32
sym: jump_back_entry info: 11 other: 00 shndx: 8 value: 2008 size: 8
sym: jump_back_entry value: 8004 addr: 174d
R_X86_64_PC32
sym:       .bss info: 03 other: 00 shndx: a value: 0 size: 0
sym: .bss value: 9ffc addr: 1754
R_X86_64_PC32
sym:  purgatory info: 12 other: 00 shndx: 1 value: 134 size: 53
sym: purgatory value: 1130 addr: 1759
R_X86_64_PLT32
sym:    entry64 info: 10 other: 00 shndx: 1 value: 690 size: 0
sym: entry64 value: 168c addr: 175e
R_X86_64_PLT32
sym:  reset_vga info: 11 other: 00 shndx: 8 value: 2012 size: 1
sym: reset_vga value: 8012 addr: 1764
R_X86_64_64
sym: x86_reset_vga info: 12 other: 00 shndx: 1 value: eb2 size: 232
sym: x86_reset_vga value: 1eb2 addr: 1773
R_X86_64_64
sym: legacy_pic info: 11 other: 00 shndx: 8 value: 2011 size: 1
sym: legacy_pic value: 8011 addr: 1780
R_X86_64_64
sym: x86_setup_legacy_pic info: 12 other: 00 shndx: 1 value: 10e4 size: 35
sym: x86_setup_legacy_pic value: 20e4 addr: 178f
R_X86_64_64
sym: legacy_pic value: 8011 addr: 179e
R_X86_64_64
sym: x86_setup_legacy_pic value: 20e4 addr: 17ad
R_X86_64_64
sym: cmdline_end info: 11 other: 00 shndx: 8 value: 2000 size: 8
sym: cmdline_end value: 8000 addr: 17ba
R_X86_64_64
sym: jump_back_entry value: 8008 addr: 17cc
R_X86_64_64
sym: .rodata.str1.1 value: 4fab addr: 17db
R_X86_64_64
sym:    sprintf info: 12 other: 00 shndx: 1 value: 424 size: 96
sym: sprintf value: 1424 addr: 17e5
R_X86_64_64
sym: panic_kernel info: 11 other: 00 shndx: 8 value: 2010 size: 1
sym: panic_kernel value: 8010 addr: 17f2
R_X86_64_64
sym: crashdump_backup_memory info: 12 other: 00 shndx: 1 value: cb3 size: 3e
sym: crashdump_backup_memory value: 1cb3 addr: 1801
R_X86_64_64
sym: jump_back_entry value: 8008 addr: 180e
R_X86_64_64
sym: x86_setup_jump_back_entry info: 12 other: 00 shndx: 1 value: 7b8 size: 38
sym: x86_setup_jump_back_entry value: 17b8 addr: 181e
R_X86_64_64
sym: jump_back_entry value: 8008 addr: 182d
R_X86_64_64
sym: x86_setup_jump_back_entry value: 17b8 addr: 183d
R_X86_64_64
sym: .data value: 8047 addr: 1867
R_X86_64_PC32
sym: .data value: 804f addr: 186d
R_X86_64_PC32
sym: .data value: 8075 addr: 188d
R_X86_64_PC32
sym: .data value: 807f addr: 1893
R_X86_64_PC32
sym: .data value: 8089 addr: 1899
R_X86_64_PC32
sym: .data value: 8093 addr: 189f
R_X86_64_PC32
sym: .data value: 8076 addr: 18a6
R_X86_64_PC32
sym: .data value: 808d addr: 18ad
R_X86_64_PC32
sym: .data value: 806d addr: 1977
R_X86_64_PC32
sym: .data value: 8075 addr: 197d
R_X86_64_PC32
sym: .data value: 809b addr: 199d
R_X86_64_PC32
sym: .data value: 80a5 addr: 19a3
R_X86_64_PC32
sym: .data value: 80af addr: 19a9
R_X86_64_PC32
sym: .data value: 80b9 addr: 19af
R_X86_64_PC32
sym: .data value: 80e2 addr: 19f2
R_X86_64_PC32
sym: .data value: 812b addr: 1a35
R_X86_64_PC32
sym: backup_src_size info: 11 other: 00 shndx: 8 value: 2070 size: 8
sym: backup_src_size value: 8070 addr: 1cb5
R_X86_64_64
sym: backup_start info: 11 other: 00 shndx: 8 value: 2080 size: 8
sym: backup_start value: 8080 addr: 1cc7
R_X86_64_64
sym: backup_src_start info: 11 other: 00 shndx: 8 value: 2078 size: 8
sym: backup_src_start value: 8078 addr: 1cd9
R_X86_64_64
sym:     memcpy info: 12 other: 00 shndx: 1 value: 581 size: 18
sym: memcpy value: 1581 addr: 1ce6
R_X86_64_64
sym: serial_base info: 11 other: 00 shndx: 8 value: 2090 size: 2
sym: serial_base value: 8090 addr: 1cf3
R_X86_64_64
sym: .data value: 8088 addr: 1d00
R_X86_64_64
sym: serial_baud info: 11 other: 00 shndx: 8 value: 208c size: 4
sym: serial_baud value: 808c addr: 1d3a
R_X86_64_64
sym: .data value: 8088 addr: 1d69
R_X86_64_64
sym: console_vga info: 11 other: 00 shndx: 8 value: 2093 size: 1
sym: console_vga value: 8093 addr: 1d90
R_X86_64_64
sym: .data value: 8098 addr: 1da4
R_X86_64_64
sym: .data value: 8098 addr: 1e09
R_X86_64_64
sym: .data value: 8094 addr: 1e1e
R_X86_64_64
sym: .data value: 8094 addr: 1e37
R_X86_64_64
sym: .data value: 8094 addr: 1e6d
R_X86_64_64
sym: console_serial info: 11 other: 00 shndx: 8 value: 2092 size: 1
sym: console_serial value: 8092 addr: 1e81
R_X86_64_64
sym:      .text info: 03 other: 00 shndx: 1 value: 0 size: 0
sym: .text value: 1cf1 addr: 1e90
R_X86_64_64
sym: sha256_process info: 12 other: 00 shndx: 1 value: 1170 size: 2a25
sym: sha256_process value: 2170 addr: 4bef
R_X86_64_64
sym: memcpy value: 1581 addr: 4c53
R_X86_64_64
sym: sha256_process value: 2170 addr: 4c65
R_X86_64_64
sym: memcpy value: 1581 addr: 4c93
R_X86_64_64
sym: .text value: 4ba0 addr: 4cb7
R_X86_64_64
sym: .text value: 4ba0 addr: 4d1a
R_X86_64_64
sym: .data value: 80a0 addr: 4d27
R_X86_64_64
sym:    entry16 info: 10 other: 00 shndx: 1 value: 850 size: 0
sym: entry16 value: 1850 addr: 4e58
R_X86_64_64
sym: entry32 value: 15c0 addr: 4ee0
R_X86_64_64
sym: .rodata value: 4ef0 addr: 4ef2
R_X86_64_64
sym: .rodata value: 4f20 addr: 4f22
R_X86_64_64
sym: .text value: 1000 addr: 4fe8
R_X86_64_PC32
sym: .text value: 1134 addr: 501c
R_X86_64_PC32
sym: .text value: 1187 addr: 5050
R_X86_64_PC32
sym: .text value: 1424 addr: 509c
R_X86_64_PC32
sym: .text value: 14ba addr: 50b8
R_X86_64_PC32
sym: .text value: 155a addr: 50f0
R_X86_64_PC32
sym: .text value: 156d addr: 5104
R_X86_64_PC32
sym: .text value: 1581 addr: 5118
R_X86_64_PC32
sym: .text value: 1599 addr: 512c
R_X86_64_PC32
sym: .text value: 1762 addr: 5158
R_X86_64_PC32
sym: .text value: 17b8 addr: 5178
R_X86_64_PC32
sym: .text value: 17f0 addr: 518c
R_X86_64_PC32
sym: .text value: 1cb3 addr: 51c8
R_X86_64_PC32
sym: .text value: 1cf1 addr: 51f8
R_X86_64_PC32
sym: .text value: 1d8e addr: 520c
R_X86_64_PC32
sym: .text value: 1eb2 addr: 5248
R_X86_64_PC32
sym: .text value: 20e4 addr: 5278
R_X86_64_PC32
sym: .text value: 2120 addr: 52a8
R_X86_64_PC32
sym: .text value: 2170 addr: 52bc
R_X86_64_PC32
sym: .text value: 4ba0 addr: 5308
R_X86_64_PC32
sym: .text value: 4cb0 addr: 536c
R_X86_64_PC32
sym: .text value: 4cd0 addr: 5380
R_X86_64_PC32
sym: .data value: 6140 addr: 6142
R_X86_64_64
kexec_load: entry = 0x1730 flags = 0x3e0000
nr_segments = 6
segment[0].buf   = 0x982120
segment[0].bufsz = 0x1000
segment[0].mem   = 0
segment[0].memsz = 0x1000
segment[1].buf   = 0x97b020
segment[1].bufsz = 0x70e0
segment[1].mem   = 0x1000
segment[1].memsz = 0x9000
segment[2].buf   = 0x7fd50d4b1d00
segment[2].bufsz = 0x249
segment[2].mem   = 0xa000
segment[2].memsz = 0x1000
segment[3].buf   = 0x7fd50ca000a0
segment[3].bufsz = 0x224ad0
segment[3].mem   = 0x200000
segment[3].memsz = 0x35f000
segment[4].buf   = 0x7fd50c17d020
segment[4].bufsz = 0x881fe0
segment[4].mem   = 0x55f000
segment[4].memsz = 0x882000
segment[5].buf   = 0x7fd508f63020
segment[5].bufsz = 0x3219f65
segment[5].mem   = 0xde1000
segment[5].memsz = 0x321a000
Linux (fails)
kernel: 0x7fdd0f621010 kernel_size: 0x224c0c
MEMORY RANGES
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PLT32
R_X86_64_PLT32
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_64
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_PC32
R_X86_64_64
nr_segments = 6
segment[0].buf   = 0x563f17a46510
segment[0].bufsz = 0xc0
segment[0].mem   = (nil)
segment[1].buf   = 0x563f17a3f1d0
segment[2].buf   = 0x563f17a46750
segment[2].bufsz = 0x229
segment[3].buf   = 0x7fdd0f621090
segment[4].buf   = 0x7fdd0ed9f010
segment[5].buf   = 0x7fdd0bb85010
After many hours of research and testing I have finally figured it out. The files need to be loaded at a lower memory address. Maybe this is because that is what Xen is expecting or maybe this is due to different permissions at lower memory addresses, I don’t know exactly why.
This is the working command:
kexec --mem-min=0000000000001000 --mem-max=0000000500000000 -d -l xen.gz --command-line="placeholder console=none dom0_mem=min:1024M dom0_mem=max:4096M ucode=scan smt=off gnttab_max_frames=2048 gnttab_max_maptrack_frames=4096 no-real-mode" --module="vmlinuz placeholder root=/dev/mapper/qubes_dom0-root ro rd.lvm.lv=qubes_dom0/root rd.lvm.lv=qubes_dom0/swap rd.lvm.lv=qubes_dom0/boot plymouth.ignore-serial-consoles i915.alpha_support=1 intel_iommu=igfx_off rd.driver.pre=btrfs rhgb quiet rd.qubes.hide_all_usb" --module="initramfs.img"
