Printer settings - start service doesn't work
I try to install a printer within a templateVM and I read some tutorials, but it doesn’t work.
printer settings show “not connected”, if I try to start the service, it doesn’t start. If I try to connect to CUPS, I get “failed to connect to server”. So I can not add anything.
I try it on regular fedora 41 template.
There are also no printer settings under the system settings of the template.
cheers
qun
Did you read this
oh, nope, thanks! Will try it!
