Prime OS as standalone VM?
Hello,
I don’t use a smartphone but sometimes I need an app for verifying at some services. Now I want to try Prime OS for that and plan to install it as a standalone VM in Qubes OS and want to try if I can use smartphone apps on the PC.
Could someone please help me how I can install the Prime OS image as a standalone VM in Qubes?
Thank you very much.
Greetings.
To install a standalone qube, see the doc:
To use android, there are also other solutions.
e.g.
Android x86
https://github.com/unman/notes/blob/master/InstallingAndroid.md
Android Bliss
https://forum.qubes-os.org/t/alright-guys-i-got-us-this-far-lastest-android-bliss-v15-8-6-working/19357
There are a lot of thread in the forum:
https://forum.qubes-os.org/search?q=android
If you success installing and using Prime OS, report back. :slight_smile:
ps: can someone move this to user support.
