Well, I have the same issue as this topic, https://forum.qubes-os.org/t/rc1-failed-in-initial-setup-qvm-template-install-fedora-34/6888
Which I can’t reply.
I got the same message during installation after reboot.
I can login dom0, but there is no qubes at all. No sys-net, no sys-firewall, and no template at all. I cant do anything.
Data mount point was /var/lib/qubes
as the automatic button does.
Interesting. Do you mind running in a dom0 terminal (XFCE Terminal) the command sudo journalctl -u qubesd and either screenshotting and uploading here or copying the text?
If you have a github account or don’t mind creating one, please continue the conversation on the associated github issue, so the developers more easily see it.
