Please Help! How do I use my bluetooth headphones with sys-net in other qubes?
Hi. I have some Bluetooth headphones. I successfully use Bluetooth Manager via blueman after attaching my bluetooth device to sys-net.
However, I can’t listen to audio via my bluetooth headphones in other qubes, as the bluetooth manager is only in sys-net. How do I make sys-net my audio qube, or get the bluetooth headphones to work in all other qubes? Thanks!
You need to either set up an audio qube, pass your bluetooth adapter there, and connect your headphones, or pass your bluetooth adapter into the qube that you want to listen to.
It has salt config version, check the end of the guide!
