PGP / GPG Recommendations
Hi. What PGP software are you guys using?
I am using Kgpg
I see theres other choices like kleopatra
What is good for qubesos?
Port to Sequoia-PGP (gpg replacement) (OpenPGP) work in progress for Kicksecure, Whonix.
gpg-from-sq to make applications at least use sequoia-chameleon-gnupg.
So nowadays I suggest to Sequoia-PGP (sq) and not gpg.
Qubes is also porting to Sequoia-PGP. Example use case of sq here:
Related:
https://gpg.fail/
Unspecific to Qubes.
These are graphical frontends that use gpg or gpg library as a backend. I don’t recommend using any graphical frontends. Unfortunately, it seems much better using the command line. I don’t know yet if any graphical frontends are compatible with sequoia-chameleon-gnupg or made for sq.
