I have a script. It does stuff.
- Copies my default AppVM to a create a new AppVM, sets sys-whonix as a temporary netVM
- Launches a terminal where i can drop a docker-compose.yml and start the container once to fetch it
- Makes the container persistent
- Creates stuff to autostart the container when the AppVM starts.
- Sets the production netvm to none
Here is the code, maybe it is of some use to others:
#!/bin/bash
# This script creates a new docker AppVM
# Usage <name>
# Parameter
# <name> the name of the new Docker AppVM
DOCKER_BASE_SOURCE="debian-11-app"
DOCKER_COLOR="gray"
DOCKER_INSTALL_NETVM="sys-whonix"
DOCKER_PRODUCTION_NETVM="none"
TERMINAL_COMMAND="\"gnome-terminal --wait\""
# Clone the source
qvm-clone $DOCKER_BASE_SOURCE $1
# Set netvm for installation
qvm-prefs --set $1 netvm $DOCKER_INSTALL_NETVM
# Remove the dispvm-template flag if it is enabled
qvm-prefs --set $1 template_for_dispvms False
# Make /var/lib/docker persistant
qvm-run -p -u root $1 'mkdir -p /rw/config/qubes-bind-dirs.d'
qvm-run -p -u root $1 'echo "binds+=( /var/lib/docker ) " >> /rw/config/qubes-bind-dirs.d/>
# Enable docker service on startup
qvm-run -p $1 'echo "sudo systemctl start docker" >> ~/.profile'
# Restart
qvm-shutdown --wait $1
# Open Terminal, so user can install stuff
qvm-run -p $1 "gnome-terminal --wait"
# User is done with installing, we can change the netvm to whatever she wants
qvm-prefs --set $1 netvm $DOCKER_PRODUCTION_NETVM
This needs to be run in dom0.
This does not install docker! It only automates the steps described above, so you need to have docker (and docker-compose if you want that) installed in your template.
