Permissions/Policies
Yes, I searched extensively.
I messed up my policies and permissions because I made the mistake of again trying to modify things that shouldn’t be modified.
I tried to change the policy and permissions surrounding copy and paste in dom0 which didn’t work, but then after I didn’t remove the stuff that I tried to change and now there’s an issue with dom0, permissions, and I’m guessing maybe a little bit of policies but mainly permissions.
when I go to update or even open certain apps like feather app vm for example, it will say something about update connect denied syswhonix-dom0
then notifications will flash about whonix gateway needs to be on to perform any updates make sure that whonix gateway exists… it exists
it basically isn’t working because dom0 or something happened where the permissions im suppsoed to have are non existent i used two different AIs to try to reset permissions and policies and they did i know it worked, but the permissions will not reset and the policies won’t matter as long as the permissions surrounding them won’t change.
please help me for I am trying to configure my pi 4 and marauder and this is getting in the way BIG TIME
please help, ill be super good and not mess with dom0 permissions and policies anymore.
i dont trust nonpaid versions of chat gpt and grok telling me to reset with a back up i feel like chat gpt is trying to sabotage me because ive been cursing at it so much. like ill go to back up after reinstalling and itll just be a blank 010101 picture of a giant middle finger.
thanks
thanks
will pay xmr 20 usd
Duplicate of Help messed up permissions with dom0
Closing.
@ilikeitinmybackdoor you post got hub up in the moderation queue. If this happens, please refrain from posting more. Just wait for mods to get back to it. Otherwise, it’s a bit of a mess to clean all the repetated posts.
