Help messed up permissions with dom0
I messed up my policies and permissions because I made the mistake of again trying to modify things that shouldn’t be modified.
I tried to change the policy and permissions surrounding copy and paste in dom0 which didn’t work, but then after I didn’t remove the stuff that I tried to change and now there’s an issue with dom0, permissions, and I’m guessing maybe a little bit of policies but mainly permissions.
when I go to update or even open certain apps like feather app vm for example, it will say something about update connect denied syswhonix-dom0
then notifications will flash about whonix gateway needs to be on to perform any updates make sure that whonix gateway exists… it exists
it basically isn’t working because dom0 or something happened where the permissions im suppsoed to have are non existent i used two different AIs to try to reset permissions and policies and they did i know it worked, but the permissions will not reset and the policies won’t matter as long as the permissions surrounding them won’t change.
please help me for I am trying to configure my pi 4 and marauder and this is getting in the way BIG TIME
please help, ill be super good and not mess with dom0 permissions and policies anymore.
i dont trust nonpaid versions of chat gpt and grok telling me to reset with a back up i feel like chat gpt is trying to sabotage me because ive been cursing at it so much. like ill go to back up after reinstalling and itll just be a blank 010101 picture of a giant middle finger.
thanks
I can’t understand clearly what you was trying to achieve in dom0 but why you don’t just reinstall Qubes ? You will loose more time trying to debug than reinstall the system from scratch
Also if you provide more details about what you did in dom0 we could maybe help you
I spent SO much time making mullvad a vpn with all the proper dns settings etc, same with all 10+ other app vms and templates.
all AI’s are basically fking me hard, so I’m wondering if I can safely back them up without backing up whatever is wrong.
I changed the policies back but the permissions remain that I cannot change the qubes manager settings when trying to reset clipboard settings.
ill go to restore to default and it says permission denied.
That basically sums it all up or when i launch my feather app
"denied qubeswindowiconupdater
denied sdwdate-guiconnectcheck from feather to sys whonix
(a million notifications) and thats just one app, when i open another itll say the same thing with that app vm
i want to reset the permissions in dom0 and reset the policies without erasing my app and template vms, or back up and restore them without backing up the misconfiguration
i want to reset my permissions and policies globally, or be able to back up my app and template and system vms without messing them up and also transferring whateer i did wrong with dom0
when i turn on an app that has to do with sys whonix as the network vm it displays
denied qubes notifications
denied qubes norification from feather to dom0
denied sdwdate-gui connect check from feather to sys whonix (a million times)
and im guessing itll do the same for any app vm connected to sys whonix
As far i understand it look like you compromised your whonix template and dom0 you should consider your system broken and compromised
I recommend you to backup your file content settings in Bitwarden for example if there is a file you must keep.
Don’t backup your system just reinstall Qubes on your PC. If you use Qubes Backup your broken/compromised appvm/template will be there and the problem will still be here it’s not worth it trying to debug the system like i said earlier.
Have you tried to do Reinstall Qubes-Whonix Templates ? It look like you did something wrong in whonix-gateway-template
Permissions of what ? Also for the policies if you’re talking about File access , url handling you can change it in Qubes Global config gui menu
@ilikeitinmybackdoor please stop the duplicate messages. If something is waiting moderation review, just let us take a look (we’re volunteers and may not be able to attend to it immediately)
I don’t if its correct but you can try reinstalling this
sudo dnf reinstall qubes-core-qrexec-dom0
Then reboot the system.
