I have exactly the same problem, setting default disposable vm helped, but now i can not convert more then 50 pages. I tried with fedora and debian disposable vms too. I get
There’s an open issue about converting PDFs - I’m really hampered
because I cant duplicate any of these issues.
Would it be at all possible for you to provide a sample that creates
this error? (It wont help but I often convert PDFs longer than 50 pages)
Try using a much smaller batch number. like:
qvm-convert-pdf -b 2 foo.pdf
I’m finding the PIL.save() function fails without being caught as an error when the append_images list is too long. May be an issue with my version of the pillow library if others aren’t able to replicate it. For now, just using a really tiny batch size fixes the issue, even if it does take a lot longer.
