balin1
August 19, 2024, 9:13am
1
For the last couple of weeks I cannot manage to update any Debian or Arch based templates (neither manually by e.g. apt-get nor through salt, which I commonly use to maintain my system. This extends to the whonix templates as well.
I am puzzled, as Fedora-based templates seem not to experience any such problem, nor does dom0. May this be an issue with apt-cacher-ng?
No amount of searchengining has helped so far, so I’m turning here for advise.
Some details:
QubesOS 4.2
Default update proxy and whonix update proxy both set to sys-whonix
debian-12 example error produced by apt-get update: Reading from proxy failed - read (115: Operation now in progress) [IP: 127.0.0.1 8082]
Example error when targeting debian-12 using salt: ----------
Function: pkg.uptodate
Result: False
Comment: E: Failed to fetch https://deb.debian.org/debian/dists/bookworm/InRelease Reading from proxy failed - read (115: Operation now in progress) [IP: 127.0.0.1 8082]
E: Failed to fetch https://deb.debian.org/debian-security/dists/bookworm-security/InRelease Reading from proxy failed - read (115: Operation now in progress) [IP: 127.0.0.1 8082]
E: Failed to fetch https://deb.qubes-os.org/r4.2/vm/dists/bookworm/InRelease Reading from proxy failed - read (115: Operation now in progress) [IP: 127.0.0.1 8082]
E: Some index files failed to download. They have been ignored, or old ones used instead.
Started: 11:11:07.032379
Duration: 7670.156 ms
Changes:
Please chime in whith hints on how to remedy and/or troubleshoot.
Maybe it’s this issue with IPv6 in your update proxy qube:
opened 03:48AM - 25 Jul 24 UTC
T: bug
C: Debian/Ubuntu
P: default
needs diagnosis
C: updates
C: networking
affects-4.2
[How to file a helpful issue](https://www.qubes-os.org/doc/issue-tracking/)
#… ## Qubes OS release
4.2.2
### Brief summary
TemplateVMs, debian-based, fail to update when ipv6 is enabled in `sys-net`
### Steps to reproduce
enable IPv6 in sys-net
qubes-update-gui --log DEBUG --target debian-12-xcfe
### Expected behavior
I expect it to succeed.
### Actual behavior
It fails.
Updating debian-12-xfce
Refreshing package info
Refreshing packages.
Fail to refresh InRelease: https://deb.qubes-os.org/r4.2/vm bookworm InRelease from https://deb.qubes-os.org/r4.2/vm/dists/bookworm/InRelease
Fail to refresh InRelease: https://deb.debian.org/debian bookworm InRelease from https://deb.debian.org/debian/dists/bookworm/InRelease
Fail to refresh InRelease: https://deb.debian.org/debian-security bookworm-security InRelease from https://deb.debian.org/debian-security/dists/bookworm-security/InRelease
Refreshed.
E:Failed to fetch https://deb.debian.org/debian/dists/bookworm/InRelease Reading from proxy failed - select (115: Operation now in progress) [IP: 127.0.0.1 8082], E:Failed to fetch https://deb.debian.org/debian-security/dists/bookworm-security/InRelease Reading from proxy failed - select (115: Operation now in progress) [IP: 127.0.0.1 8082], E:Failed to fetch https://deb.qubes-os.org/r4.2/vm/dists/bookworm/InRelease Reading from proxy failed - select (115: Operation now in progress) [IP: 127.0.0.1 8082], E:Some index files failed to download. They have been ignored, or old ones used instead.
If I `qvm-run -u root debian-12-xfce xterm` and then manually update:
root@debian-12-xfce:~# apt update
0% [Connecting to HTTP proxy (http://127.0.0.1:8082)] [Connecting to HTTP proxy (http://127.0.0.1:8082)]
Ign:1 https://deb.qubes-os.org/r4.2/vm bookworm InRelease
Ign:2 https://deb.debian.org/debian bookworm InRelease
Ign:3 https://deb.debian.org/debian-security bookworm-security InRelease
Err:1 https://deb.qubes-os.org/r4.2/vm bookworm InRelease
Err:2 https://deb.debian.org/debian bookworm InRelease
Err:3 https://deb.debian.org/debian-security bookworm-security InRelease
Reading package lists... Done
E: Failed to fetch https://deb.debian.org/debian/dists/bookworm/InRelease Reading from proxy failed - select (115: Operation now in progress) [IP: 127.0.0.1 8082]
E: Failed to fetch https://deb.debian.org/debian-security/dists/bookworm-security/InRelease Reading from proxy failed - select (115: Operation now in progress) [IP: 127.0.0.1 8082]
E: Failed to fetch https://deb.qubes-os.org/r4.2/vm/dists/bookworm/InRelease Reading from proxy failed - select (115: Operation now in progress) [IP: 127.0.0.1 8082]
If I open a terminal on `sys-net`:
root@nuc13:/home/user# systemctl status qubes-updates-proxy
● qubes-updates-proxy.service - Qubes updates proxy (tinyproxy)
Loaded: loaded (/lib/systemd/system/qubes-updates-proxy.service; enabled; preset: enabled)
Active: active (running) since Thu 2024-07-25 13:20:56 AEST; 2s ago
Main PID: 2177 (tinyproxy)
Tasks: 3 (limit: 381)
Memory: 1.2M
CPU: 7ms
CGroup: /system.slice/qubes-updates-proxy.service
└─2177 /usr/bin/tinyproxy -d -c /etc/tinyproxy/tinyproxy-updates.conf
Jul 25 13:20:56 nuc13.wtf.com systemd[1]: Started qubes-updates-proxy.service - Qubes updates proxy (tinyproxy).
Jul 25 13:20:56 nuc13.wtf.com tinyproxy-wrapper[2177]: Found tinyproxy at /usr/bin/tinyproxy
Jul 25 13:20:56 nuc13.wtf.com tinyproxy[2177]: Initializing tinyproxy ...
Jul 25 13:20:56 nuc13.wtf.com tinyproxy[2177]: Reloading config file
Jul 25 13:20:56 nuc13.wtf.com tinyproxy[2177]: Reloading config file finished
root@nuc13:/home/user# vi /etc/tinyproxy/tinyproxy-updates.conf
If I attempt to interact directly with the proxy:
root@debian-12-xfce:~# time curl -v --proxy http://127.1:8082/ https://www.example.com/
* Trying 127.0.0.1:8082...
* Connected to 127.0.0.1 (127.0.0.1) port 8082 (#0)
* allocate connect buffer
* Establish HTTP proxy tunnel to www.example.com:443
> CONNECT www.example.com:443 HTTP/1.1
> Host: www.example.com:443
> User-Agent: curl/7.88.1
> Proxy-Connection: Keep-Alive
It outputs the above promptly, and then hangs.
< HTTP/1.0 200 Connection established
< Proxy-agent: tinyproxy/1.11.1
* CONNECT phase completed
* CONNECT tunnel established, response 200
* ALPN: offers h2,http/1.1
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
* CAfile: /etc/ssl/certs/ca-certificates.crt
* CApath: /etc/ssl/certs
* TLSv1.3 (IN), TLS handshake, Server hello (2):
* TLSv1.3 (IN), TLS handshake, Encrypted Extensions (8):
* TLSv1.3 (IN), TLS handshake, Certificate (11):
* TLSv1.3 (IN), TLS handshake, CERT verify (15):
* TLSv1.3 (IN), TLS handshake, Finished (20):
* TLSv1.3 (OUT), TLS change cipher, Change cipher spec (1):
* TLSv1.3 (OUT), TLS handshake, Finished (20):
* SSL connection using TLSv1.3 / TLS_AES_256_GCM_SHA384
* ALPN: server accepted h2
* Server certificate:
* subject: CN=example.com
* start date: Jun 11 02:44:21 2024 GMT
* expire date: Sep 9 02:44:20 2024 GMT
* subjectAltName: host "www.example.com" matched cert's "*.example.com"
* issuer: C=US; O=Google Trust Services; CN=WE1
* SSL certificate verify ok.
* using HTTP/2
* h2h3 [:method: GET]
* h2h3 [:path: /]
* h2h3 [:scheme: https]
* h2h3 [:authority: www.example.com]
* h2h3 [user-agent: curl/7.88.1]
* h2h3 [accept: */*]
* Using Stream ID: 1 (easy handle 0x59751e801460)
> GET / HTTP/2
> accept: */*
* TLSv1.3 (IN), TLS handshake, Newsession Ticket (4):
* old SSL session ID is stale, removing
< HTTP/2 301
< date: Thu, 25 Jul 2024 03:31:16 GMT
< content-type: text/html
< content-length: 167
< location: https://example.com
< cache-control: max-age=3600
< expires: Thu, 25 Jul 2024 04:31:16 GMT
< report-to: {"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report\/v4?s=Msa1JxOFTYzmlkwVlgo%2BtRg%2BaRdWLA1e0HKVHTG02W%2FeMhEExiUSTabAg0g6BOBxWj%2Fnl2WKm%2BkfQZXjldLVqHVABKieKlVHBJ4S7sG4KvyC7m8WCZcSbnV%2FlV%2B95wiV"}],"group":"cf-nel","max_age":604800}
< nel: {"success_fraction":0,"report_to":"cf-nel","max_age":604800}
< server: cloudflare
< cf-ray: 8a89137e2f1355b1-SYD
< alt-svc: h3=":443"; ma=86400
<html>
<head><title>301 Moved Permanently</title></head>
<body>
<center><h1>301 Moved Permanently</h1></center>
<hr><center>cloudflare</center>
</body>
</html>
* Connection #0 to host 127.0.0.1 left intact
real 2m5.478s
user 0m0.051s
sys 0m0.023s
No matter what I try, it connects to the proxy promptly, and then it takes about 3 minutes to complete. Could be the `apt` gives up before 3 minutes. I note that `deb.debian.org` returns some stuff which is actually a re-direct, but if I edit the <whatever> file in `/etc` in the template to explicitly reference the `fastly` redirect, it still fails.
I just this morning accepted a `dom0` update, rebooted, and then attempted to apply the rest of the pending updates.
But since you have sys-whonix as your update qube then maybe it’s not the case.
Or did you maybe enable IPv6 in sys-whonix?
balin1
August 19, 2024, 10:30am
3
Did not fiddle with sys-whonix networking and ip a | grep inet6 comes up empty when run in sys-whonix.
Do you use apt-cacher-ng? Is it installed in sys-whonix?
Check the updates proxy service log in the sys-whonix:
sudo journalctl -b -u qubes-updates-proxy.service
balin1
August 19, 2024, 11:47am
5
Something not working here:
Aug 19 11:46:31 host systemd[1]: Starting qubes-updates-proxy.service - Qubes updates proxy (tinyproxy)...
Aug 19 11:46:31 host tinyproxy-config-patch[2554]: + set -e
Aug 19 11:46:31 host tinyproxy-config-patch[2554]: + true '/usr/lib/qubes-whonix/tinyproxy-config-patch: START'
Aug 19 11:46:31 host tinyproxy-config-patch[2554]: + append-once /etc/tinyproxy/tinyproxy-updates.conf '## BEGIN: auto-generated configuration by /usr/lib/qubes-whonix/tinyproxy-config-patch'
Aug 19 11:46:31 host tinyproxy-config-patch[2555]: /usr/lib/qubes-whonix/tinyproxy-config-patch: line 25: append-once: command not found
Aug 19 11:46:31 host systemd[1]: qubes-updates-proxy.service: Control process exited, code=exited, status=127/n/a
Aug 19 11:46:31 host systemd[1]: qubes-updates-proxy.service: Failed with result 'exit-code'.
Aug 19 11:46:31 host systemd[1]: Failed to start qubes-updates-proxy.service - Qubes updates proxy (tinyproxy).
Damien
August 19, 2024, 12:45pm
6
maybe your debian template runs out of space ?
unman
August 19, 2024, 1:00pm
7
Indeed, something is not working there.
This looks Whonix specific - as such, you are best advised to take it to
the Whonix Forums (as asked by the Whonix devs). You will get better
informed eyes on it there.
It seems that you’ve removed helper-scripts package in your Whonix Gateway template.
I guess you can reinstall the whonix-gateway-17 template to restore it to default state.
balin1
August 19, 2024, 7:56pm
9
Something did get seriously borked indeed. qvm-template resinstall whonix-gateway-17 seems to have done the trick.
Thank you for your patience and insight.
The interesting (scary?) question now is: why did updating apparently work for fedora-based templates!?
balin1
August 26, 2024, 7:40pm
10
More investigation ensued and here’s what I found:
Just running apt-get update && apt-get upgrade in the whonix-gateway-17 template recreates the problem, reuiring another fresh install of the template (qvm-template resinstall whonix-gateway-17)!?
This cannot be right. What is going wrong here.
@unman : do you have any insight into this?
Maybe you did something in sys-whonix qube?
Try to remove the sys-whonix qube and create it again.
balin1
August 28, 2024, 11:12am
12
Let me clarify:
qvm-template reinstall whonix-gateway-17 && qvm-stop sys-whonix && qvm-start sys-whonix → All template updates work
qvm-run --user root whonix-gateway-17 xterm, followed by apt-get update && apt-get upgrade therein and subsequently by qvm-stop sys-whonix && qvm-start sys-whonix → yields the inability of debian/based templates to update described above.
NO changes in the sys-whonix qube (other than the altered underlying template) involved.
apt-get update (in the fresh whonix-gateway-17 template) yields the following (maybe the last line is relevant)?
Get:1 https://deb.qubes-os.org/r4.2/vm bookworm InRelease [4,739 B]
Get:2 tor+https://deb.debian.org/debian bookworm InRelease [151 kB]
Get:3 tor+https://fasttrack.debian.net/debian bookworm-fasttrack InRelease [12.9 kB]
Get:4 tor+https://deb.kicksecure.com bookworm InRelease [62.0 kB]
Get:5 tor+https://deb.whonix.org bookworm InRelease [61.5 kB]
Get:6 https://deb.qubes-os.org/r4.2/vm bookworm/main amd64 Packages [37.9 kB]
Get:7 tor+https://fasttrack.debian.net/debian bookworm-fasttrack/non-free amd64 Packages [492 B]
Get:8 tor+https://deb.whonix.org bookworm/main amd64 Packages [13.8 kB]
Get:9 tor+https://deb.debian.org/debian bookworm-updates InRelease [55.4 kB]
Get:10 tor+https://deb.kicksecure.com bookworm/contrib amd64 Packages [509 B]
Get:11 tor+https://fasttrack.debian.net/debian bookworm-fasttrack/contrib amd64 Packages [7,120 B]
Get:12 tor+https://fasttrack.debian.net/debian bookworm-fasttrack/main amd64 Packages [5,096 B]
Get:13 tor+https://deb.whonix.org bookworm/non-free amd64 Packages [471 B]
Get:14 tor+https://deb.debian.org/debian-security bookworm-security InRelease [48.0 kB]
Get:15 tor+https://deb.kicksecure.com bookworm/non-free amd64 Packages [914 B]
Get:16 tor+https://deb.kicksecure.com bookworm/main amd64 Packages [36.5 kB]
Get:17 tor+https://deb.debian.org/debian bookworm-backports InRelease [56.6 kB]
Get:18 tor+https://deb.debian.org/debian bookworm/main amd64 Packages [8,788 kB]
Get:19 tor+https://deb.debian.org/debian bookworm/non-free amd64 Packages [97.3 kB]
Get:20 tor+https://deb.debian.org/debian bookworm/non-free-firmware amd64 Packages [6,216 B]
Get:21 tor+https://deb.debian.org/debian bookworm/contrib amd64 Packages [54.1 kB]
Get:22 tor+https://deb.debian.org/debian bookworm-updates/contrib amd64 Packages [768 B]
Get:23 tor+https://deb.debian.org/debian bookworm-updates/non-free-firmware amd64 Packages [616 B]
Get:24 tor+https://deb.debian.org/debian bookworm-updates/main amd64 Packages [13.8 kB]
Get:25 tor+https://deb.debian.org/debian bookworm-updates/non-free amd64 Packages [12.8 kB]
Get:26 tor+https://deb.debian.org/debian-security bookworm-security/main amd64 Packages [179 kB]
Get:27 tor+https://deb.debian.org/debian-security bookworm-security/contrib amd64 Packages [644 B]
Get:28 tor+https://deb.debian.org/debian bookworm-backports/non-free amd64 Packages [1,648 B]
Get:29 tor+https://deb.debian.org/debian bookworm-backports/contrib amd64 Packages [5,608 B]
Get:30 tor+https://deb.debian.org/debian bookworm-backports/main amd64 Packages [236 kB]
Fetched 9,951 kB in 17s (593 kB/s)
N: Repository 'tor+https://deb.debian.org/debian bookworm InRelease' changed its 'Version' value from '12.4' to '12.6'
apt-get upgrade (in the fresh whonix-gateway-17 template) yields
Building dependency tree... Done
Reading state information... Done
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
iptables libip6tc2 libopenjp2-7 libwpe-1.0-1 libwpebackend-fdo-1.0-1 python3-daemon python3-lockfile
Use 'apt autoremove' to remove them.
The following packages have been kept back:
helper-scripts kicksecure-dependencies-cli kicksecure-recommended-cli
The following packages will be upgraded:
anon-apps-config anon-apt-sources-list anon-connection-wizard anon-gw-anonymizer-config anon-gw-base-files apparmor-profile-dist apparmor-profile-torbrowser apparmor-profiles-kicksecure base-files bash bind9-dnsutils bind9-host bind9-libs bootclockrandomization bsdextrautils bsdutils bubblewrap curl desktop-config-dist dist-base-files distro-info-data dnsutils fdisk gir1.2-gdkpixbuf-2.0 gstreamer1.0-plugins-base
hardened-malloc icon-pack-dist kicksecure-desktop-applications-xfce legacy-dist less libaom3 libarchive-tools libarchive13 libblkid1 libc-bin libc-dev-bin libc-l10n libc6 libc6-dev libcryptsetup12 libcurl3-gnutls libcurl4 libdav1d6 libde265-0 libfdisk1 libfreetype6 libgdk-pixbuf-2.0-0 libgdk-pixbuf2.0-common libglib2.0-0 libglib2.0-bin libglib2.0-data libgnutls30 libgssapi-krb5-2 libgstreamer-gl1.0-0
libgstreamer-plugins-bad1.0-0 libgstreamer-plugins-base1.0-0 libisl23 libjavascriptcoregtk-4.1-0 libk5crypto3 libkrb5-3 libkrb5support0 libltdl7 libmount1 libpam-systemd libpython3.11 libpython3.11-minimal libpython3.11-stdlib libqrexec-utils2 libqt5core5a libqt5dbus5 libqt5gui5 libqt5network5 libqt5printsupport5 libqt5sql5 libqt5test5 libqt5widgets5 libqt5xml5 libqubes-pure0 libqubes-rpc-filecopy2 libqubesdb librpm9
librpmbuild9 librpmio9 librpmsign9 libseccomp2 libsmartcols1 libssl3 libsystemd-shared libsystemd0 libudev1 libuuid1 libuv1 libvchan-xen1 libvpx7 libwebkit2gtk-4.1-0 libxencall1 libxendevicemodel1 libxenevtchn1 libxenforeignmemory1 libxengnttab1 libxenhypfs1 libxenmisc4.17 libxenstore4 libxentoolcore1 libxentoollog1 linux-libc-dev locales mount msgcollector msgcollector-gui nano onion-grater openssl python3-idna
python3-qrexec python3-qubesdb python3-rpm python3.11 python3.11-minimal qubes-core-agent qubes-core-agent-dom0-updates qubes-core-agent-nautilus qubes-core-agent-networking qubes-core-agent-passwordless-root qubes-core-agent-thunar qubes-core-qrexec qubes-gui-agent qubes-input-proxy-sender qubes-kernel-vm-support qubes-usb-proxy qubes-utils qubes-vm-dependencies qubes-whonix qubes-whonix-gateway
qubes-whonix-gateway-packages-recommended qubes-whonix-shared-packages-recommended qubesdb qubesdb-vm repository-dist repository-dist-wizard rpm rpm-common rpm2cpio sdwdate sdwdate-gui security-misc setup-dist setup-wizard-dist systemcheck systemd systemd-sysv tar timesanitycheck tinyproxy tinyproxy-bin tor tor-control-panel tor-geoipdb tzdata udev usability-misc usbutils usr-is-merged util-linux util-linux-extra
vm-config-dist whonix-base-files whonix-firewall whonix-gateway-default-applications-gui whonix-gateway-packages-dependencies-cli whonix-gateway-packages-dependencies-pre whonix-gateway-shared-packages-shared-meta whonix-gw-network-conf whonix-shared-default-applications-gui whonix-shared-packages-dependencies-cli whonix-shared-packages-recommended-cli xen-utils-4.17 xen-utils-common xen-utils-guest xenstore-utils
xserver-common xserver-xorg-core xserver-xorg-input-qubes xserver-xorg-qubes-common xserver-xorg-video-dummyqbs zsh
186 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
Need to get 123 MB of archives.
After this operation, 11.1 MB of additional disk space will be used.
Do you want to continue? [Y/n]
balin1
August 28, 2024, 11:27am
13
Ha! Found it. I needed an apt-get dist-upgrade rather than plain apt-get upgrade! Following that, whonix-gateway-17 keeps working as expected!
