I’m working on a project where files are exported from a vm to an offline ‘viewer’ VM, and then copied from there to an ‘encrypt’ VM which will encrypt the files and then copied to a ‘send’ VM.
I have 4 VMs:
app (online, tor only, don’t want to install any extra software)
view (offline, with libre office etc installed)
encrypt (offline)
send (online)
I’ve got everything working, my only problem is that I’d like the view/encrypt VMS to discard any files that were processed after the Qube is restarted.
I thought there might be some way of marking my ‘view’ and ‘encrypt’ VMs as ‘disposable’ but as far as I can tell you only get a disposable VM if you specifically ask to open a file or copy a file to a disposable VM - by default /home is persisted.
Does anyone have any suggestions on how to proceed? My current thought is to have some kind of custom script that just does rm -rf /home/user/QubesIncoming on shutdown/startup but that seems a bit crude.
Sorry I wasn’t clear enough. I don’t actually want any data to persist between reboots. I do however need the vms to be able to be sent multiple files per session, so a workflow could be:
User on app vm reading lists of files, exports a few of them to viewer vm (by clicking an export button which runs qrexec-client-vm view-vm qubes.FileCopy) - there will be more than one export operation per session
User views some files on view vm and sends a few to encrypt VM - again in multiple operations
I think disposable VMs would be good for this but I need to be able to predict the name of the VM so that the ‘app’ VM is able to qvm-copy commands (the name of the ‘view’ VM is currently hard coded into the ‘app’ codebase). Since disposable VMs tend to be called e.g. disp1234 I’m not sure how that could work. I also have a user policy that allows copying from app to view to encrypt, I’m not sure whether you can write user policies for disposable vms.
Thanks so much, that will definitely work! I’ve got a second question I guess which is if I don’t care about any persistence between reboots is there a way of using disposable VMs for this task?
In this case, you should be able to set up a named disposable VM, similar to how sys-net and sys-usb can be disposable. This will also allow for the name of the VM to be consistent and known.
