I really hope someone can help me cos this is a bit serious.
I just got in, put my qubes machine on and selected the boot menu to get into qubes. I get the graphics there so I can tell from that there is no issue with my display equipment. After I choose the qubes os from the menu it just goes.to a black screen, no dialogue box to decrypt my hard disk or anything.
If I put the type the key in the disk drive light shows activity.and I can hear the drive working but there is nothing on the screen.
Would really appreciate help as I use this machine for work.
Update
I managed to get in by going to the advanced options on the boot menu and selecting a previous version of the hypervisor.
It would be nice if it just worked like it did prior to the latest dom0 update, which I remember I updated last night, any workarounds or commands I need to run? Now I’m able to interact with my system I can give more technical info
What’s the Xen and kernel version that works for you and that’s not working for you?
Maybe you can try to remove the kernel that is not working for you and update the dom0 again so it’ll be reinstalled in case there was an issue during the installation.
What is the machine hardware (CPU/GPU)?
I’ve been experiencing this since kernel 6.10.7 (6.10.6 and earlier works), same for the 6.6 series starting with 6.6.48.
It’s still not fixed, unfortunately.
I’ve been building my kernels with the buggy commit reverted and have never had a problem since. For normal users, I guess keeping the latest working kernel is the only solution, unless a revert patch is added to the Qubes kernel repository until it is properly fixed (@marmarek).
I’ve tried every stable release since 6.10.7, it never worked for me unless I reverted the original buggy commit. I tried booting the latest kernel available in the qubes repo (6.11.6) today and still get the same thing. I’m currently on 6.11.7 with the reverted commit and it works fine.
linux kernel 6.6.54 and 6.6.48 still cause the same issues. 6.6.42 is the only one that works now.
if the next kernel upgrade doesnt fix this and i chose to go ahead with the upgrade, my qubes will no longer be accessible (the last 3 kernels are only available in the grub menu)
I wouldnt have thought it would take this long to fix
I have not been able to use my GPU at all since the 6.6.48
