Networking issues with Ubuntu 25.10 in a standalone qube using sys-whonix
I have installed Ubuntu 25.10 in a standalone Qube and configured it to use sys-whonix for networking. However, I’m experiencing issues, as I am unable to access the web or install packages via the terminal.
The wired connection in Ubuntu is active, and I can confirm that it recognizes the MAC address when I execute the command ip link show. Additionally, I created another standalone Qube using a Debian template with sys-whonix for networking, and that works without any issues.
I am uncertain what might be wrong with the Ubuntu setup. Any guidance would be greatly appreciated.
Thank you very much.
How did you install Ubuntu in the SVM? Through the installation ISO? I think that in such a case you’ll need to manually set the IP address, gateway, DNS and netmask in your SVM’s network settings.
Yes.
But in case it matters, I didn’t select the file from another qube. I used the ‘From existing block device’ option and installed it from a bootable USB.
Thank you.
Standalone qube should run as HVM, not as PVM.
You can read more here:
It is running as HVM.
Quote:
Network configurations for post-installation will be similar to HVM - Networking.
Does that work?
Yes.
Thank you.
Unfortunately, I’m experiencing the same issue, but the solution in here doesn’t work…
Okay, I checked it only works when it uses sys-firewall as its net-vm.
It doesn’t work if I set sys-whonix as its net-vm.
Hey!
If that Ubuntu 25.10 standalone came from the ISO, that’s the issue.
It won’t talk to sys-whonix right without the qubes core agents. The template already has them, so Debian works.also By default, Ubuntu 25.10 uses netplan and systemd-networkd, which breaks DHCP in Qubes.
Change netplan to NetworkManager and install qubes-core-agent-networking and qubes-core-agent-network-manager.You shouldn’t have to set up IP/DNS by hand with sys-whonix.
If you do, the agents/NM aren’t set up correctly.
Thanks for advice. I have a question:
I’ve installed and change netplan to NetworkManager, but I can’t install neither qubes-core-agent-networking nor qubes-core-agent-network-manager via apt.
I guess I need to register the qubes repo in the source list, am I correct? or is there a guide for doing this?
