Ubuntu 24.04.3 LTS standalone qube doesn't recognize sys-whonix network
I tried a solution introduced in This link about the same issue, but unfortunately, for my case, the issue isn’t resolved.
I don’t know why but the connection to sys-firewall works well.
Could you outline exactly how you configured networking in the Ubuntu qube?
In Settings-Network-Wired,
There are three devices:
netplan-zz-all-en
netplan-zz-all-eth
netplan-enX0
Select one of them, and in the IPv4 menu,
Check Manual for IPv4 method.
and edit
Address : 10.137.0.43
Netmask: 255.0.0.0 (I tried 255.255.255.0 already.)
Gateeway:10.137.0.12
DNS: 10.139.1.1, 10.139.1.2
This address can be checked from the settings menu of standalone qube if I set net-vm as sys-whonix.
If I set net-vm as sys-firewall, then Gateway is different, and I need to change it.
