After some help, I have set it to remember my account number, device name and connection status with the Mullvad App autolaunching at startup.
My objective is to have a mullvad-i, mullvad-ii and mullvad-iii, each with the same account number but different exit points, serving different qubes (e.g. workVM → mullvad-ii exiting in e.g. New York → sys-firewall → sys-net → world).
(Eventually I want the mullvad-x qubes to be named disposables, but it looks like I need to tackle this step-by-step).
Within mullvad-i, Mullvad Browser works fine. Its not quick, but it works.
However, even though the provides network to other qubes option is definitely checked in Settings, it lists in Q menu > Service and I can set another AppVM to use it as network, its not working:
There is no connectivity in the AppVM Firefox
ping 8.8.8.8 works
I have had problems with MTU before, but setting MTU to other values (as per here) has no effect, although it is currently working for other qubes using the original sys-mullvad.
I joined another qube (personal) to the mullvad-i. It fails to work.
Normally that qube uses the original sys-mullvad for netVM, as per unman’s design. It already has MTU=1380 set.
I rejoined personal to sys-mullvad, and it still failed. Turns out Mullvad had logged out the sys-mullvad app. I had to log it in again. Then pages loaded.
Then tried personal again on mullvad-i. It failed. Ranged up and down MTU values, from 500-1380. Nothing works.
Meanwhile, the AppVM I have just got working (above) with mullvad-i continues to work fine.
It seems really inconsistent. There’s another process that must be going on.
What’s odd is that I dont have these issues. Have you logged out and
logged back in to Mullvad to create a new device?
Cloning sys-mullvad seems to work for me, and I dont have reports from
other users of the issues you see.
It could be selection of endpoint, protocol, or effects of MTU.
If you create a new device on the clone and attach to the same
endpoint, do you have issues then?
Definitely created new devices on Mullvad. That’s quite transparent on the app (e.g. Awkward Aardvark, etc)
I am going to have to step away from the machine for several hours soon, but here are a couple of ‘niggling thoughts’ about how this machine might be a bit different.
its second hand hardware, and it was treated harshly. I refurbished it as best I could, but I have always wondered if something somewhere on the motherboard was slightly damaged.
I have had strange issues/glitches with earlier versions of Qubes (years ago and I can’t remember the details). Each new version - and a new SSD - brought less of that kind of weirdness.
my internet is a cellular hotspot. I think that’s why I need to adjust the MTU.
Recently I booted this machine into other live distros, including a couple of rescue systems. In subsequent Qubes-boots, I’ve noticed that I have at least one corrupted qube (I get a message about not reaching the kernel or something). I suspect one of the rescue distros made changes on the SSD.
my computing knowledge remains fairly low, so that’s always been the more likely explanation for divergent system behavior.
After a reboot, there is significantly better behavior from mullvad-i, i.e. it just works.
However, a clone of mullvad-i, mullvad-ii, doesn’t seem to work with a fresh dispVM set netVM->mullvad-ii’. It logs in (I think I logged it out in a different VM), but connectivity fails in the client dispVM. Playing with MTU values doesn’t work.
