Suspend/resume half works, it resumes, I have to restart AppVM after resume because they don’t display anything
the desktop is very responsive and fast, even 3D programs works (using llvmpipe) to some extent of course (tested with stellarium, openscad, blender, minetest)
144 hz screen works
Audio over HDMI works
Network works
System is installed on a NVME drive (I have 2 of them, not found by the HCL program) without issues
keyboard / mouse in USB, working fine
I tried with an NVIDIA 1060 GTX, I had to install the NVIDIA driver to avoid a sluggish desktop and hard reboots, the procedure is complicated and not really secure. I didn’t have audio over HDMI working with this nvidia card. No 144 Hz, locked at 70 Hz
Thank you @solene for your HCL report, which is online now!
I have changed works from yes to partial due to the resume issues you mentioned. I also shortened the remark to “resume issues” because of the table layout. The full information that is important and you have thankfully provided is linked from the table to this thread. Finally I added the common / marketing name of your motherboard to make it easier to find for others.
It works really great, but there is an akward limitation you need to know beforehand. If you add the second M2 SSD, this disables the second PCI express x16 slot!
You can’t use 2 dedicated GPUs when you have 2 M2 SSD
