Hello everyone
i got the same issue for that topic I7-8700 - Qubes Installation states missing IOMMU/VT-d/AMD-Vi
and according to that comment
i can not find my hardware on the hcl list
so does that mean i can not install qubes ?
will i get issue with the vm/template i install later?
thanks for your time and have a nice day
Did you enable the virtualization features in the bios?
does anyone have comment about this?
sometimes reenable vtx vtd would work, it happen on my x230
thanks @51lieal for your suggestion i checked my hardware it does not have that option
that why i ask if it fine to proceed with installation or not and if i did what issue i could face later?
I don’t think you will be able to start any qubes, apart from dom0.
You can disable IOMMU, but that does degrade your security.
unsupported hardware detected error
thanks @renehoj then i will give it a shoot and see if whonix run fine there or not
hope i be able to add 2 instance of whonix
What motherboard are you using? Can you share the exact name of the model?
thanks @kommuni
i already checked it and it does have it so will follow the doc instruction
thanks again and have a nice day
