Mic not working for Headset(direct into monitor) Urgent
Im trying to use my Headset which has a builtin mic but I get no audio for the mic, Ive tested with Discord and attempted some troubleshooting from previous older posts which did not resolve my issue.
The closest Ive found to my issue was How to use microphone with Bluetooth headphones however Im using a audio cable of course so the blueman factor is not relatable nor the use of a audio qube(direct from dom0)
I usually use a blue yeti but just like my sys-usb Sys-usb freezes/crashes system(Broke after dom0 update) - #3 by Zamm after the dom0 update my blue yeti gave out and I am left with two major issues which I need to resolve as I have two very important meetings today & tomorrow.
Quiet urgent so any help would be great :pray:
Not sure if it helps, but to get working my mic connected to the mic input of my motherboard, I had to start pavucontrol in dom0 and tweak the profile in the “configuration” section.
I have attempted starting & tweaks from an article/git issue from 3 years ago but didnt work.
Can you link me to the post you referred to for support?
can you share the link so we can figure what you already tried?
It would also help if you identified the headset and what sort of
connection it uses.
Apologies for the delay, I accidentally started sys-usb when was in process of replying so had to power off.
I spent sometime looking for the post I referred to but cant seem to find it(I was not signed in when I was originally troubleshooting)
I have however found the github post I read over if it helps.
I did ultimately revert the changes I made as troubleshooting I attempted from the post didn’t work if there was any concern.
Are you referring to the brand? Also I have mentioned I’m using an aux cable directly into the monitor if this is what you are asking?
