Keepassxc scaling problem
Hi, I have a problem with scaling the KeepassXC application on the Fedora template — it appears to be too large. (Current QubesOS version, ThinkPad T480.) Could someone help? This problem does not occur on Debian.
not helped, my t480 is FullHD
I don’t have a solution, but I am having the same issue. Also a Fedora template on a T480.
You can fix this by adjusting the font and font size using qt5ct. To apply the settings system-wide, copy ~/.config/qt5ct to /etc/xdg/ in the Template VM.
Or just uninstall qt5ct. In this scenario, fonts and font sizes will follow xfce’s settings.
