Hi everyone!
I’m new to Qubes OS and really appreciate any help or guidance you can offer. ![]()
I recently updated my system via the Qubes Updater and rebooted, but unfortunately, my system hasn’t been booting properly since. After the GRUB screen, when trying to boot with the latest kernel version (6.6.54), I only see a blinking underscore, and nothing else happens.
Out of curiosity, I tried booting with an older kernel version through GRUB, and that got me back into my system. Originally, I was using kernel 6.6.48, which used to work fine, but now it also refuses to boot. The only kernel that somewhat works is 6.6.41.
Here’s what I’ve tried so far:
Kernel Reinstallation Attempts: Thinking 6.6.54 might not be compatible, I tried reinstalling kernel 6.6.48 using sudo dnf remove to clear out:
kernel-6.6.54-1.qubes.fc37.x86_64
kernel-modules-6.6.54-1.qubes.fc37.x86_64
kernel-qubes-vm-6.6.54-1.qubes.fc37.x86_64
kernel-devel-6.6.54-1.qubes.fc37.x86_64
I then rebooted and used sudo qubes-dom0-update kernel and also directly tried sudo qubes-dom0-update kernel-6.6.54, but this didn’t solve the problem.
Testing with Kernel 6.6.48: After the reinstallation attempts didn’t work, I also tried a similar approach with kernel 6.6.48, but had no luck there either.
I suspect I might be doing something wrong here, and that the issue isn’t actually with Qubes itself. I’m open to any advice or troubleshooting steps you can suggest. Thanks so much in advance for any tips or insights!
