Anyone elses NetworkManager applet staying in white colour after updating from R4.0.4 to R4.1-beta ? Is this a known issue on Github somewhere? Any fix?
Thanks for the amazing work you all do Qubes Team (core team/mods/volunteers).
This is a bug in qubes-gui-daemon 4.1.16 update. There is already 4.1.17 with this issue fixed.
Thank you for replying @marmarek how do I apply the fix?
The update is currently in testing repository, see How to install software in dom0 | Qubes OS
Thanks so much @marmarek have a great day!
I’m using KDE desktop and i finally have an icon for network manager! I don’t care that its white…simple things
@marmarek In the dom0 terminal I executed the following command:
sudo qubes-dom0-update --enablerepo=qubes-dom0-current-testing
After updating, I rebooted my machine and the Network Manager tray icons are still white. The tray icons for other apps in running VMs are also white.
Thoughts?
( I installed Qubes with the 4.1.0-rc2 iso image and updated the DM to KDE following advice from @Sven in KDE - changing the way you use Qubes - #8 by Sven)
