Mine is desktop
Could be hardware issues not related to Qubes.
Thanks yes, sounds like a RAM problem but it tested fine back then. I’ll test again.
Check CPU:
Yes, I agree with that.
I can’t say I have noticed any GUI upgrades? New icons or something maybe but mostly I haven’t noticed any changes. I don’t have any Windows Qubes so I can’t compare there.
“Smoother” is vague to me.
Good idea. Not an option in my BIOS but maybe I’ll update the BIOS at some point.
I don’t know for all of you guys but i feel like debian template are far more slower than fedora template.
It does solves that actually, thanks. But I will keep the minimal-netvm anyways as it’s more secure this way. I don’t mind to wait 15sec to connect for the first time compare to trading security over it
It feels a little less responsive at times.
I wonder if reported crashes and the subjective experiences with the new version are related to Dom0 memory leaks. Feel free to monitor and report back.
while “sluggish” is a precisely measurable thing, right?! ![]()
I don’t want to convince you. This is just what I feel. And yes, it is not measurable, not even a technical term, and also very much subjective.
The whole point is to let others know, that not everybody feel the issue.
So in short - and an answer for the question in the topic title:
No, my Qubes 4.3 - on my device - is not ‘sluggish’.
It runs as 4.2 for me, except I now have a constant 20-30% CPU usage in dom0 (visible with xentop, it turns into 2-3% in the tray icon due to 10 VCPUs for dom0).
I have not dug enough (nothing obvious visible with top in a dom0 terminal) but I suspect that this usage drains battery power and now I have to plug my laptop sooner ![]()
Starting the System (Framework 13" AMD) takes much longer than with 4.2
Attaching mouse and keyboard takes sometimes more than 5 minutes. Often i disconnect both to be presented with the dom0 prompt upon disconnecting.
Attaching USB devices cameras, microphone and USB sticks work fine) take sometimes up to a minute.
So yes, imo it is much worse than 4.2.
Whonix and every other template became larger and heavier. There are ways to time startup of a qube, you can do this for a stopped anon-whonix:
time qvm-run -p --service anon-whonix qubes.WaitForSession
And from a running anon-whonix:
time qvm-run -p --service anon-whonix janondisttorbrowser.desktop
You can do this same experiment on R4.2 and R4.3 and compare the differences.
Can you expand on this a bit? How much RAM do you have? Is this the same report of not being able to start a disposable because the system doesn’t have enough RAM?
I agree with this. Somethings are not even related to Qubes, such as Torbrowser startup or AMD being unfriendly to work with when it needs patching the kernel. If you report numbers in a reproducible manner, showing the command being run and the output, alongside the resources being consumed by other qubes, some dom0 logs, such as qmemman and qubesd, I might be able to help or redirect to github issues if can’t help.
Your distribution of choice on domUs are becoming bloated each year, just compare the enlargement:
- Index of /r4.1/templates-itl/rpm/
- Index of /r4.2/templates-itl/rpm/
- Index of /r4.3/templates-itl/rpm/
One of the reasons minimal-(netvm|usbvm) was introduced, to prevent some services from starting in sys-(net|usb) (which can’t redistribute because memory management is disabled for qubes with PCI devices).
Therefore, I think it is important to distinguish speed of Qubes components from speed of domU components of your distro of choice.
A lot of performance tests were introduced recently, one of them is qube startup, execution and cleanup in case of disposables.
Unfortunately, this is the only test with graphs and the test doesn’t run on R4.2 openqa.
You can browser more:
Search for _perf@hw.
Fair enough.
The second command is wrong, should read:
time qvm-run -a --service anon-whonix qubes.StartApp+janondisttorbrowser
Anyway, thank you for taking time to look into this! The results of the timed commands are pasted below.
Note that the hardware is pretty much identical (same CPU, 32Gb of RAM) and I didn’t have anything else running, except for the 3 qubes necessary to start anon-whonix: sys-net, sys-firewall, and sys-whonix .
R4.2.4 timings
[user@dom0 ~]$ cat /etc/qubes-release
Qubes release 4.2.4 (R4.2)
[user@dom0 ~]$
[user@dom0 ~]$
[user@dom0 ~]$ qvm-ls -t --running
NAME STATE CLASS LABEL TEMPLATE NETVM
dom0 Running AdminVM black - -
sys-net Running AppVM red default-net-dvm -
└─sys-firewall Running DispVM green default-net-dvm sys-net
└─sys-whonix Running AppVM black whonix-gateway-17 sys-firewall
[user@dom0 ~]$
[user@dom0 ~]$
[user@dom0 ~]$ time qvm-run -p --service anon-whonix qubes.WaitForSession
real 0m9.240s
user 0m0.059s
sys 0m0.050s
[user@dom0 ~]$
[user@dom0 ~]$
[user@dom0 ~]$ qvm-shutdown --wait anon-whonix
[user@dom0 ~]$
[user@dom0 ~]$
real 0m9.424s
user 0m0.093s
sys 0m0.070s
[user@dom0 ~]$
[user@dom0 ~]$
[user@dom0 ~]$
[user@dom0 ~]$
[user@dom0 ~]$ time qvm-run -a --service anon-whonix qubes.StartApp+janondisttorbrowser
Running 'qubes.StartApp+janondisttorbrowser' on anon-whonix
real 0m9.660s
user 0m0.061s
sys 0m0.040s
real 0m10.385s
user 0m0.056s
sys 0m0.035s
[user@dom0 ~]$
R4.3.0 timings
user@dom0:~$ cat /etc/qubes-release
Qubes release 4.3.0 (R4.3)
user@dom0:~$
user@dom0:~$ qvm-ls -t --running
sys-net Running DispVM red default-net-dvm -
└─sys-firewall Running DispVM green default-dvm sys-net
└─sys-whonix Running AppVM black whonix-gateway-18 sys-firewall
user@dom0:~$
user@dom0:~$
user@dom0:~$ time qvm-run -p --service anon-whonix qubes.WaitForSession
real 0m16.693s
user 0m0.118s
sys 0m0.066s
user@dom0:~$
user@dom0:~$
user@dom0:~$ qvm-shutdown --wait anon-whonix
user@dom0:~$
user@dom0:~$
real 0m13.668s
user 0m0.112s
sys 0m0.065s
user@dom0:~$
user@dom0:~$
user@dom0:~$
user@dom0:~$
user@dom0:~$ time qvm-run -a --service anon-whonix qubes.StartApp+janondisttorbrowser
real 0m14.642s
user 0m0.104s
sys 0m0.041s
user@dom0:~$
user@dom0:~$
user@dom0:~$
user@dom0:~$
real 0m14.418s
user 0m0.099s
sys 0m0.041s
user@dom0:~$
user@dom0:~$
R4.3.0 feels sluggish!
Actually, there are differences between the R4.2.4 and R4.3.0 installs:
- the latter is a fresh install
- the latter uses a combined, disposable, sys-net + sys-usb
- because of #2, there exists a qvm-features/qubesdb-read construct to pass info to the disposable sys-net (wifi credentials)
I’ll reinstall R430 in a clean, simple, configuration and run the timings again.
Are you using the same version of Whonix in both 4.2 and 4.3?
I generally have 16GB RAM, with some tweaks in the system. I find that
preloading generally does not provide a benefit for me. That is, heavy
use of disposables reduces the claimed benefit and impacts work adversely.
I see that there have been changes to address some issues, but they do
not seem to have resolved the basic issue. For occasional use, a preloaded
disposable starts somewhat faster, but that is not how I use them. (Also,
it pains me to have multiple qubes sitting about unused.)
Thanks.
On R4.2, you used -a on qvm-run, while on R4.3, you used -p. The -p as I suggested, is not so nice for .desktop, because it holds until the app closes manually, while -p makes sense for qubes.WaitForSession.
This is from automatic tests:
- https://openqa.qubes-os.org/tests/165816/file/system_tests-dispvm_perf-whonix-workstation-18_graph_00_specs.png
- https://openqa.qubes-os.org/tests/165816/file/system_tests-dispvm_perf-whonix-workstation-18_graph_04_line_01_05_response_gui-small.png
From these tests, it took ~9 seconds for the “Dom0 runs GUI app in a disposable (API)”.
Automatic tests have increased the memory (initial memory to boot before qmemman starts) from 400 to 500 and maxmem from 4000 to 5000. Can you please try it and report?
qvm-prefs anon-whonix maxmem 5000
qvm-prefs anon-whonix memory 500
I followed the same steps as you, same qubes running.
- With
400-4000, I got 12s onqubes.WaitForSession. - With
500-5000, I got 10-11s onqubes.WaitForSession. - With
800-5000, I got 9.5s onqubes.WaitForSession.
You may increase memory even more to see different results. No need to increase maxmem beyong 4000 or 5000 though.
Also, please don’t hold qui-domains open or place your mouse over the system tray, there is something there that makes it spike on CPU.
My first anon-whonix with 400-4000 memory, took 14s, but, on subsequent tries (after shutting it down), it took 9.5 seconds. I think this is because the browser is creating a cache.
Can you share a bit more about how you use disposables, so maybe we could improve your workflow? Also, there was a new feature introduced, preload-dispvm-delay, please see man qvm-features. It adds a delay in seconds to start another disposables after one has been used.
(Also,
They normally consume between 320-400 MiB and can’t be redistributed after pause. Which I understand, that in memory constrained systems, might be too much.
