So I had a very similar issue years ago, the caveat is, the work around for it isn’t working here.
so I tried 4 different things, none worked, see the pastebin link (it was too long to put in the message here). I have also noticed that trying to install fairly mundane things like nfs-common in an appvm gives me a similar error:
[451/454] Removing glibc-0:2.42-12.fc43.x86_64 100% | 826.0 B/s | 100.0 B | 00m00s
[452/454] Removing glibc-minimal-langpack-0:2.42-12.fc43.x86_64 100% | 900.0 B/s | 100.0 B | 00m00s
[453/454] Removing glibc-gconv-extra-0:2.42-12.fc43.x86_64 100% | 1.3 KiB/s | 627.0 B | 00m00s
[454/454] Removing glibc-common-0:2.42-12.fc 100% [==================] | 0.0 B/s | 53.0 B | 00m00s
[454/454] Removing glibc-common-0:2.42-12.fc43.x86_64 100% | 0.0 B/s | 53.0 B | 04m55s
>>> Running %posttrans scriptlet: kernel-core-0:7.0.13-100.fc43.x86_64
>>> Finished %posttrans scriptlet: kernel-core-0:7.0.13-100.fc43.x86_64
>>> Scriptlet output:
>>> dracut[E]: Module 'systemd-cryptsetup' depends on module 'crypt', which can't be installed
>>> dracut[E]: Module 'systemd-pcrphase' depends on module 'tpm2-tss', which can't be installed
Complete!
Updating and loading repositories:
Repositories loaded.
Failed to resolve the transaction:
No match for argument: nfs-common
You can try to add to command line:
--skip-unavailable to skip unavailable packages
in looking through the forum I wasn’t able to find any other posts that seemed to be similar so alas, I am posting in hopes a guru can help
Thanks in advance.
PS When i logout or reboot and then check the DE option, XFCE is the only thing that comes up.
