I have a qube on which I’m planning to install Discord (not private, but so many people use it…)
I add the free and non-free RPM repositories
However, when I try to
sudo dnf install discord
I am told that no such package can be found
How have y’all installed Discord on Qubes OS please?
Villa
November 10, 2025, 1:35pm
2
Good evening,
You’ll need to install it via flatpak – I’m running Discord, Element, and Signal on a dedicated Fedora 42 xfce template where I setup flatpak onto.
Make sure to follow @solene guide on how to properly setup flatpaks on Qubes:
Thank you for the quick response
sudo dnf install flatpak
went OK
export all_proxy=http://127.0.0.1:8082/
gave no output after I restarted the qube
flatpak remote-add --if-not-exists flathub https://dl.flathub.org/repo/flathub.flatpakrepo
gives me
error: Can't load uri https://dl.flathub.org/repo/flathub.flatpakrepo: While fetching https://dl.flathub.org/repo/flathub.flatpakrepo: [7] Could not connect to server
Atrate
November 10, 2025, 7:05pm
4
Don’t reboot between the export command and the flatpak one
Flatpak already installed
No output
gives
No restarts involved after the first command
Atrate
November 12, 2025, 9:08pm
6
Try:
export http_proxy=http://127.0.0.1:8082/
export https_proxy=http://127.0.0.1:8082/
before trying to add the remote.
If you want to automate this for future Flatpak operations:
Add
if [ "$(qubesdb-read /type)" = "TemplateVM" ]
then
fi
to /etc/profile.d/qubes-flatpak-proxy.sh in your TemplateVM and reboot.
Thank you - still no joy
I have found that I cannot ping 6.6.6.6 from this qube
However, I can ping 1.1.1.1, so I infer that I can access the Internet from this qube…
I was able to install the Discord app via their tar.gz download on their website.
I actually ended up using it in the browser though. It’s a bit lighter so it saves me some RAM
I have a Discord qube I use to chat with some family who are big Discord users. Here was my process, more or less:
Clone debian-12-minimal to template-discord or whatever name, and then within that new template:
Install unlisted Discord dependencies: pulseaudio-qubes qubes-core-agent-networking libatk1.0-0 libatk-bridge2.0-0 libgtk-3-0
Install the discord-repo_1.1_all.deb package from here: GitHub - palfrey/discord-apt: APT repository for Discord (warning: non-official) to add the /etc/apt entry for Discord
apt update and apt install discord
Shutdown template-discord
Then create a new qube with template template-discord, set the netvm to whatever makes sense. Should work, at least it does for me
Atrate
November 13, 2025, 5:31pm
10
If you use Discord in the browser, you can utilize the following .desktop file to make it as seamless as possible (no bars, and ability to launch from the Qubes app menu if you put it in the template):
[Desktop Entry]
Version=1.0
Type=Application
Name=Discord-Kiosk
GenericName=Discord (Kiosk)
Comment=Open Discord in Firefox kiosk mode (no browser chrome)
Exec=firefox -kiosk "https://discord.com/channels/@me"
TryExec=firefox
Terminal=false
StartupNotify=true
Icon=discord
Categories=Network;InstantMessaging;WebBrowser;
Keywords=discord;chat;voice;video;gaming;messages;
StartupWMClass=firefox
Hi, if you’re still having the problem, I made a simple updated guide for installing Flatpak. Cheers.
Flatpak Template Installation (Updated November 2025)
Target: Debian 12/13 - XFCE template
Disclaimer: This guide resolves the problems I encountered installing Flatpak support in my templates while reasonably adhering to current Qubes OS security guidelines. The guide covers installing Flatpak containers in the system workspace (templateVM) and in user space (AppVM, StandaloneVM). This guide aims to be as simple and user-friendly as possible.
Thanks to KitsuneNoBaka and solene for their he…
leni1
November 17, 2025, 7:09pm
12
I used snap to install Discord.
The alternative would be to download the package for Linux directly from the Discord site and then manually install it via the terminal.
Fatima
November 17, 2025, 7:40pm
13
I am no expert, but this worked on my PC.
I got a template for general use (Brave, Zoom, Discord).
I installed like this:
download the .deb file from Discord’s web page
sudo apt install ./discord-0.0.113.deb
It works fine.
Setting up a fresh qube, this time a non-XFCE Fedora rather than a Fedora XFCE, has enabled me to dnf install without issue
I am not complaining. Thank you to each of you who contributed solutions
It would have been better to install it via Flatpak; I hope that package gets updated on Fedora. Cheers.
It includes solutions for vulnerabilities discovered after the version was installed, performance improvements, new features, and generally everything important about having the latest version of the program.
I think everything is compromised, or there are active tools/vulnerabilities not disclosed to the general public that can be exploited, so real security doesn’t exist. The risk of intrusion can only be mitigated to a greater or lesser degree.
